x360 modchip 06/06/06
I sist uke annonserte Devil360.com at de vil lansere et produkt til xbox 360 den 6. juni 2006.
Det finnes lite detaljer om produktet, men kilder fra devil360 teamet røper at det vil være et innovativt produkt til konsollen.
Jeg tror at det er en av to ting:
1. Det er en faktisk gruppe med folk som har jobbet bak låste dører på enten en ny firmware - eller kansje noe bedre?
2. Det er en slags casemod/ICE mod til selve boxen eller kontrollen.
Selvfølgelig, siden -ingen- har hørt om dette "crewet" før, kan det jo være noen PR-Kåte drittunger som skaper en masse hype.
Men, som logoen på siden foreslår, er det nok en ICE mod. (ring of light lys mod f.eks)
Uansett, det har fanget oppmerksomheten min, om bare litt isåfall.
Noen andre tanker?
Edit:
Fisket frem noe mer info:
* What about the security of this M$ product?
-M$ worked on it a little bit at least.
According to findarticles.com, Chipworks is an internationally recognized technical services company that analyzes the circuitry and physical composition of semiconductors devices and electronic systems for a wide range of applications in intellectual property licensing, patenting and competitive study. Chipworks has successfully helped leading-edge semiconductor and electronics organizations achieve their goals by supporting research and development efforts in strategic product development and patent portfolio management. At the end of 2005, Chipworks analyzed the main chip of the 360 console and created a commercial report (see here).
-Playing pirated games or hacking the Xbox 360 security core?
Recently (mid march 2006) a hacker called "The specialist" published one weakness and a lot of people are now working on hacking the DVD firmware.
Using a fast FPGA card, it is possible to insert a parser/driver between the motherboard and the optical reader... we let the reader conclude by himself (sed -e 's/DVDFAKE/DVDXBOX/g Input > Output ;-)). What about the SATA HD?... wait and see. Maybe another time when few things would have been detailed.
Figure: The Hynix (T) memory containing the encrypted boot code.
We first de-capped Xbox 360 components as Chipworks did and we analyzed the console (Some chips have nine levels of metal).
Now we can confirm a lot of bunnie's assumptions and sometimes even worse.
Devil 360
Jeg tror mer og mer på at de tuller med litt firmwaren. Dette blir spennende å se.
Men som jeg nevnte, kan jo bare være noen PR-kåte tullinger.
Kilder:
- http://www.xbox-scene.com
- http://www.devil360.com
Endret av dark by design
Forsøkte meg på en Whois på de som har registrert domenenavnet. Tenkte først det var MS selv som hadde registrert det for å skape blest om et eller annet. Devil nanvet funker kanskje dårlig i USA der det kristne til tider er LITT fanatiske. Da blir vel MS kastet ut av det gode selskap og blir bannet av ymse kirkeorganer.
Kunne vært interessant å trålet Whois søket inn på hvem som faktisk har registert dette domenet. Jeg kjente ikke igjen navnet. Noen som har gjort noe research på det?
Xbox360 vil bli hacket før eller senere. Kan også regne med at MS vil sette alle kluter til for å hindre at det kommer modchipper i salg. Egentlig rart at de kunne holde på med det på xbox og ps2. Rart ingen copyright lov om tukling med hardware kommer inn i bildet. De er jo ellers flinke til å buste ymse wareznettverk.
Endret av Mazeking
IP address: 217.73.17.126
Reverse DNS: [No reverse DNS entry per ns.vnet.sk.]
Reverse DNS authenticity: [unknown]
ASN: 29405
ASN Name: VNET-AS (VNET ISP Bratislava, Slovakia, SK)
IP range connectivity: 2
Registrar (per ASN): RIPE
Country (per IP registrar): SK [slovakia]
Country Currency: SKK [slovakia Koruny]
Country IP Range: 217.73.16.0 to 217.73.31.255
Country fraud profile: High
City (per outside source): Unknown
Private (internal) IP? No
IP address registrar: whois.ripe.net
Known Proxy? No
Well pretty much all i know is they have a high fraud profile.. What ever that means ;-P the company that hosts devil 360 or at least owns the IP address is..
http://ns.vnet.sk/ so there ya go.. Off to bed.. Gnite
Det vil si at enten er de flinke til å bounce over hele verden, ellers holder de faktisk til i Slovakia..
Men, har de datamaskiner der da?
06/06/06, 666 the number of the beast.Bare sprøyt spør du meg, men desto mer moro om det virkelig er noe revolusjonerende.
5959853[/snapback]
Yeah, som jeg sier "pr-kåte drittunger".
Uansett, har meldt meg på mailinglista Deres. (som de sikker bare selger når de har fått nok adresser)
Men kommer det noe nyttig info der, skyter jeg det inn her med en gang såklart.
Men, 666 ja, litt fjortis aktig.
Det er ENORME penger å tjene for første mann ut med en slik chip.
Det har det visst seg både på PS2, XBOX og GameCube..
Hadde de hatt noe klart, hadde de sluppet det fortest mulig. ikke ventet til 06 06 06.. Det er ivertfall mine 2 cent :)
5960071[/snapback]
Veldig godt poeng. Men kan være de er litt forsiktige med tanke på at MS kjører hardt på pirater. Husker de fikk stengt Isonews.com fordi at den sida solgte PRE-MODDED xbox.
Hvem vet. Uansett, spennende.
