Ni kon Skrevet 18. april 2006 Del Skrevet 18. april 2006 Kom over noe av den beste testen ever på nettet (Nå mener jeg at alt som har med damer å gjøre er viktig og bra!) Uansett her har du den: Hvordan damer liker du? Svar ærlig folkens! Selv fikk jeg: Skinny and Cute Raw score: 14% Big Breasts, 36% Big Ass, and 72% Cute! Thanks for taking the T and A and C test! Based on your selections, the results are clear: you show an attraction to smaller breasts, smaller asses, and cuter composure than others who've taken the test. Note that you scored low on both breast and ass size. This means you appreciate thinner, harder bodies. You are most likely to appreciate a super-model. Relatively, you are less attracted to round, soft, sloppy women. My third variable, "cuteness" is a mostly objective measure of how innocent a given model looked. It's determined by a combination of a lot of factors: lack of dark eye makeup, facial expression, posture, etc. If you scored high on that variable, you are either really nice OR you're into deflowering teens. If you scored low, you are attracted to raunchier, sexier, women. In your case, your higher than average score suggests you appreciate a cuter, more innocent look. Kudos! Recommended Celebrities: Jessica Alba, an absolute goddess, and Natalie Portman, if you can handle her acting. Stemmer rimelig bra på meg, og de som vet hvordan damer jeg liker kan bekrefte dette (babethreaden) Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/
BeNeFit Skrevet 18. april 2006 Del Skrevet 18. april 2006 (endret) Genial test! Må si dette stemmer meget bra Curvy and Naughty Raw score: 62% Big Breasts, 54% Big Ass, and 52% Cute! Thanks for taking the T and A and C test! Based on your selections, the results are clear: you show an attraction to larger breasts, larger asses, and sexier composures than others who've taken the test. Note that you like women overall curvier than average. My third variable, "cuteness" is a mostly objective measure of how innocent a given model looked. It's determined by a combination of a lot of factors: lack of dark eye makeup, facial expression, posture, etc. If you scored high on that variable, you are either really nice OR you're into deflowering teens. If you scored low, you are attracted to raunchier, sexier, women. In your case, your lower than average score suggests you appreciate a sexier, naughtier look. Kudos! Recommended Celebrities: Supermodel Laetitia Casta and Actress Angelina Jolie. You scored higher than 78% on tit-size You scored higher than 66% on ass-size You scored higher than 30% on cuteness Endret 18. april 2006 av BeNeFit Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5941995
JR Ewing Skrevet 18. april 2006 Del Skrevet 18. april 2006 Asses Wild Raw score: 44% Big Breasts, 54% Big Ass, and 40% Cute! Note that because you scored small on breasts but large on ass size, it might appear you like girls bottom heavy. That's probably not the case. What's more likely is that you notice curvy, voluptuous asses, and they turn you on. Breasts are hit or miss, though, and besides, extremely large ones are just saggy and gross, in your opinion. My third variable, "cuteness" is a mostly objective measure of how innocent a given model looked. It's determined by a combination of a lot of factors: lack of dark eye makeup, facial expression, posture, etc. If you scored high on that variable, you are either really nice OR you're into deflowering teens. If you scored low, you are attracted to raunchier, sexier, women. In your case, your lower than average score suggests you appreciate a sluttier look. Kudos! Recommended Celebrity: J-Lo, when she's looking extra sexy. Probably not when she's acting. Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942000
BeNeFit Skrevet 18. april 2006 Del Skrevet 18. april 2006 Post med bilde dere får opp da Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942015
Melvin Snerken Skrevet 18. april 2006 Del Skrevet 18. april 2006 Curvy and Naughty Raw score: 59% Big Breasts, 54% Big Ass, and 52% Cute! Thanks for taking the T and A and C test! Based on your selections, the results are clear: you show an attraction to larger breasts, larger asses, and sexier composures than others who've taken the test. Note that you like women overall curvier than average. My third variable, "cuteness" is a mostly objective measure of how innocent a given model looked. It's determined by a combination of a lot of factors: lack of dark eye makeup, facial expression, posture, etc. If you scored high on that variable, you are either really nice OR you're into deflowering teens. If you scored low, you are attracted to raunchier, sexier, women. In your case, your lower than average score suggests you appreciate a sexier, naughtier look. Kudos! Recommended Celebrities: Supermodel Laetitia Casta and Actress Angelina Jolie. You scored higher than 75% on tit-size You scored higher than 68% on ass-size You scored higher than 28% on cuteness Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942018
reds Skrevet 18. april 2006 Del Skrevet 18. april 2006 (endret) Curvy and Naughty Raw score: 59% Big Breasts, 50% Big Ass, and 52% Cute! Thanks for taking the T and A and C test! Based on your selections, the results are clear: you show an attraction to larger breasts, larger asses, and sexier composures than others who've taken the test. Note that you like women overall curvier than average. My third variable, "cuteness" is a mostly objective measure of how innocent a given model looked. It's determined by a combination of a lot of factors: lack of dark eye makeup, facial expression, posture, etc. If you scored high on that variable, you are either really nice OR you're into deflowering teens. If you scored low, you are attracted to raunchier, sexier, women. In your case, your lower than average score suggests you appreciate a sexier, naughtier look. Kudos! Recommended Celebrities: Supermodel Laetitia Casta and Actress Angelina Jolie. Endret 18. april 2006 av Marius E Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942037
alexander91 Skrevet 18. april 2006 Del Skrevet 18. april 2006 Raw score: 33% Big Breasts, 31% Big Ass, and 80% Cute! fikk samme dame Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942043
Zlatzman Skrevet 18. april 2006 Del Skrevet 18. april 2006 (endret) Cute & Small Boobs Raw score: 22% Big Breasts, 45% Big Ass, and 84% Cute! Thanks for taking the T and A and C test! Based on your selections, the results are clear: you show an attraction to smaller breasts, larger asses, and sexier composure than others who've taken the test. Note that because you scored small on breasts but large on ass size, it might appear you like girls bottom heavy. That's probably not the case. What's more likely is that you notice curvy, voluptuous butts, and you don't like big, fake boobs. Big real boobs are even worse because of the sag. Anyway, my third variable, "cuteness" is a mostly objective measure of how innocent a given model looked. It's determined by a combination of a lot of factors: lack of dark eye makeup, facial expression, posture, etc. If you scored high on that variable, you are either really nice OR you're into deflowering teens. If you scored low, you are attracted to raunchier, sexier, women. In your case, your higher than average score suggests you appreciate a cuter, nicer look. Kudos! Recommended Celebrity: Hilary Duff, because she is the ultimate in cute! Especially since she lost that baby fat! This test tracked 3 variables. How the score compared to the other people's: Higher than 4% on tit-size Higher than 43% on ass-size Higher than 97% on cuteness Stemmer bra det der. Liker litt korte og skikkelig søte jenter. Endret 18. april 2006 av Zlatzman Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942044
Republic3D Skrevet 18. april 2006 Del Skrevet 18. april 2006 Curvy and Naughty Raw score: 59% Big Breasts, 68% Big Ass, and 56% Cute! Hehe.. d jeg visste. Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942047
Melvin Snerken Skrevet 18. april 2006 Del Skrevet 18. april 2006 Marius E: Akkurat som meg! Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942048
reds Skrevet 18. april 2006 Del Skrevet 18. april 2006 Marius E: Akkurat som meg! 5942048[/snapback] We like it curvy and naughty. Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942059
TanglewoodD Skrevet 18. april 2006 Del Skrevet 18. april 2006 Asses Wild Raw score: 44% Big Breasts, 54% Big Ass, and 60% Cute! KJendis ; J-Lo Ja, hun er grise digg Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942061
pessimisten Skrevet 18. april 2006 Del Skrevet 18. april 2006 You scored higher than 45% on tit-size You scored higher than 69% on ass-size You scored higher than 49% on cuteness fikk angelina jolie Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942070
BeNeFit Skrevet 18. april 2006 Del Skrevet 18. april 2006 Marius E: Akkurat som meg! 5942048[/snapback] We like it curvy and naughty. 5942059[/snapback] Oh yeah :!: Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942074
Zappza Skrevet 18. april 2006 Del Skrevet 18. april 2006 Har tatt denne før, men husker ikke hva jeg fikk, bare at det stemte veldig ______________________________ Curvy and Cute Raw score: 48% Big Breasts, 59% Big Ass, and 64% Cute! Den er jeg ikke helt enig i da Thanks for taking the T and A and C test! Based on your selections, the results are clear: you show an attraction to larger breasts, larger asses, and cuter composures than others who've taken the test. Note that you like women overall curvier than average. Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942126
Kadmium Skrevet 18. april 2006 Del Skrevet 18. april 2006 (endret) Skinny and CuteRaw score: 14% Big Breasts, 36% Big Ass, and 72% Cute! http://is0.okcupid.com/graphics/chicken_pot_pie/alba.jpg Thanks for taking the T and A and C test! Based on your selections, the results are clear: you show an attraction to smaller breasts, smaller asses, and cuter composure than others who've taken the test. Note that you scored low on both breast and ass size. This means you appreciate thinner, harder bodies. You are most likely to appreciate a super-model. Relatively, you are less attracted to round, soft, sloppy women. My third variable, "cuteness" is a mostly objective measure of how innocent a given model looked. It's determined by a combination of a lot of factors: lack of dark eye makeup, facial expression, posture, etc. If you scored high on that variable, you are either really nice OR you're into deflowering teens. If you scored low, you are attracted to raunchier, sexier, women. In your case, your higher than average score suggests you appreciate a cuter, more innocent look. Kudos! Recommended Celebrities: Jessica Alba, an absolute goddess, and Natalie Portman, if you can handle her acting. 5941889[/snapback] Jepp! Endret 18. april 2006 av Agressive Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942127
nerd-light Skrevet 18. april 2006 Del Skrevet 18. april 2006 (endret) Top-Heavy! Raw score: 70% Big Breasts, 40% Big Ass, and 52% Cute! Thanks for taking the T and A and C test! Based on your selections, the results are clear: you show an attraction to larger breasts, smaller asses, and sexier composures than others who've taken the test. Note that you like women thin and top-heavy. This is best achieved with plastic surgery, but some specimens do exist in nature. My third variable, "cuteness" is a mostly objective measure of how innocent a given model looked. It's determined by a combination of a lot of factors: lack of dark eye makeup, facial expression, posture, etc. If you scored high on that variable, you are either really nice OR you're into deflowering teens. If you scored low, you are attracted to raunchier, sexier, women. In your case, your lower than average score suggests you appreciate a sluttier look. Kudos! Recommended Celebrity: Angelina Jolie, Pamela Anderson, . You scored higher than 85% on tit-size You scored higher than 32% on ass-size You scored higher than 33% on cuteness stemte veldig bra, kunne sikkert fått høyere tit score, men er ikke så veldig glad i blondiner Endret 18. april 2006 av nerd-light Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942257
Ustedalen Skrevet 18. april 2006 Del Skrevet 18. april 2006 Cute & Small Boobs Raw score: 33% Big Breasts, 59% Big Ass, and 72% Cute! Thanks for taking the T and A and C test! Based on your selections, the results are clear: you show an attraction to smaller breasts, larger asses, and sexier composure than others who've taken the test. Note that because you scored small on breasts but large on ass size, it might appear you like girls bottom heavy. That's probably not the case. What's more likely is that you notice curvy, voluptuous butts, and you don't like big, fake boobs. Big real boobs are even worse because of the sag. Anyway, my third variable, "cuteness" is a mostly objective measure of how innocent a given model looked. It's determined by a combination of a lot of factors: lack of dark eye makeup, facial expression, posture, etc. If you scored high on that variable, you are either really nice OR you're into deflowering teens. If you scored low, you are attracted to raunchier, sexier, women. In your case, your higher than average score suggests you appreciate a cuter, nicer look. Kudos! Recommended Celebrity: Hilary Duff, because she is the ultimate in cute! Especially since she lost that baby fat! My test tracked 3 variables How you compared to other people your age and gender: You scored higher than 19% on tit-size You scored higher than 77% on ass-size You scored higher than 79% on cuteness Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942279
Juleniss1 Skrevet 18. april 2006 Del Skrevet 18. april 2006 Skinny and Cute Raw score: 33% Big Breasts, 36% Big Ass, and 76% Cute! Stemmer vel greit nok. Men gikk vel litt for raskt, så "big ass" kunne nok vært skrudd ned en del hakk. Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942284
darkness| Skrevet 18. april 2006 Del Skrevet 18. april 2006 Tok testen for jenter jeg da: Classic scorcher You scored 65% masculine, 82% athletic, 36% exotic, and 56% refined! You have picked my personal favorite type of man. Yes, man, not boy. The all-American and then some. You admire a buff body and manly features but someone who knows how to bathe himself and even though he's a scorcher, you could still bring him home to mom - as long as she keeps her hands off! Someone this hot would be......Victor Webster. But let's face it, the whole point of this was to look at a bunch of hot guys. If you liked what you saw, please rate my test! Lenke til kommentar https://www.diskusjon.no/topic/565995-hvilken-type-damer-liker-du-test/#findComment-5942286
