Sideveklslingsfil, hva er det for noe?
Northcity
Hei, jeg lurte på noe angånede sidevekslingsfil eller virtuelt minne som det heter.
hos meg står det angitt til 1536 mens anbefalt står på 1534.
jeg har satt opp til 1540, kan det øke ytelsen til spill men er det ikke så at det er minne som windows bruker.
kan jeg decrease det mye eller bør det være angitt det som anbefales?
Man bør ha den på rundt 1,5*mengde minne man har.
5940869[/snapback]
Sikkert riktig hvis du fremdeles kjører win 95 eller win 98.
Fra THE TWEAKGUIDES TWEAKING COMPANION
Note that the common advice about the pagefile being 1.5 x RAM or some other multiple is not intuitively
correct. Consider the situation where you only have 128MB of RAM: setting the maximum pagefile size to
1.5 x 128MB = a 192MB pagefile, which when combined with your 128MB of system RAM gives Windows
only 320MB of total available memory for Windows XP which is obviously not anywhere near enough
memory for modern games and applications. In effect it is about how much total memory (RAM + Pagefile)
that should be made available for Windows to operate efficiently.
EDIT:
For most people however accurately working out which is the most memory intensive application or game,
and more importantly predicting the amount of memory future software will require is tedious if not
impossible. Therefore I provide a simple general recommendation which is both safe to use on all systems,
regardless of how much RAM you have, and provides good performance:
Set the Initial and Maximum pagefile sizes to 2560MB each ‐ i.e. allocate 2.5GB for the pagefile.
This may seem like quite a lot, but the reason for this is that recent games now require a lot more real and
virtual memory to function correctly, even if you have 2GB of RAM. Having a larger pagefile size does not
hurt performance as such; it only takes up a bit of additional disk space. So on balance my recommendation
is to play it safe.
Endret av bobafett
