Anonym5656 Skrevet 15. april 2006 Del Skrevet 15. april 2006 Har google'a litt og prøvd og redigert xorg filen min til og funke med to skjermer, men står litt fast. Når jeg starter X for jeg "no screens found". Hvor ligger feilen? Xorg: # /etc/X11/xorg.conf (xorg X Window System server configuration file) # # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the /etc/X11/xorg.conf manual page. # (Type "man /etc/X11/xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # If you have edited this file but would like it to be automatically updated # again, run the following command: # sudo dpkg-reconfigure -phigh xserver-xorg Section "Files" FontPath "/usr/share/X11/fonts/misc" FontPath "/usr/share/X11/fonts/cyrillic" FontPath "/usr/share/X11/fonts/100dpi/:unscaled" FontPath "/usr/share/X11/fonts/75dpi/:unscaled" FontPath "/usr/share/X11/fonts/Type1" FontPath "/usr/share/X11/fonts/CID" FontPath "/usr/share/X11/fonts/100dpi" FontPath "/usr/share/X11/fonts/75dpi" # paths to defoma fonts FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID" EndSection Section "Module" Load"i2c" Load"bitmap" Load"ddc" #Load"dri" Load"extmod" Load"freetype" Load"glx" Load"int10" Load"type1" Load"vbe" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "kbd" Option "CoreKeyboard" Option "XkbRules" "xorg" Option "XkbModel" "pc105" Option "XkbLayout" "no" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ImPS/2" Option "Emulate3Buttons" "true" Option "ZAxisMapping" "4 5" EndSection Section "Device" Identifier "Videocard0" Driver "nvidia" BusID "PCI:1:0:0" Option "AllowGLXWithComposite" "true" Option "RenderAccel" "true" Option "NvAGP" "2" Option "NoLogo" "1" Option "RenderAccel" "0" Option "CursorShadow" "1" Option "Coolbits" "1" Option "ConnectedMonitor" "dfp, dfp" Option "NoPowerConnectorCheck" Option "TwinView" "1" Option "Metamodes" "1280x1024,1280x1024; 1024x768,1024x768; 1280x1024,NULL; 1024x768,NULL" Option "SecondMonitorHorizSync" "31-82" Option "SecondMonitorVertRefresh" "56-76" #Option "NoTwinViewXineramaInfo" EndSection Section "Monitor" Identifier "Monitor0" VendorName "Planar" Option "DPMS" HorizSync 30-65 VertRefresh 50-75 EndSection Section "Screen" Identifier "Screen0" Device "Videocard0" Monitor "Monitor0" DefaultDepth 24 SubSection "Display" Depth 1 Modes "1280x1024" "1024x768" EndSubSection SubSection "Display" Depth 4 Modes "1280x1024" "1024x768" EndSubSection SubSection "Display" Depth 8 Modes "1280x1024" "1024x768" EndSubSection SubSection "Display" Depth 15 Modes "1280x1024" "1024x768" EndSubSection SubSection "Display" Depth 16 Modes "1280x1024" "1024x768" EndSubSection SubSection "Display" Depth 24 Modes "1280x1024" "1024x768" EndSubSection EndSection Section "ServerLayout" Identifier "TwinView Configuration" Screen 0 "Screen0" 0 0 InputDevice "Configured Mouse" InputDevice "Generic Keyboard" Option "Xinerama" "Off" EndSection Section "DRI" Mode0666 EndSection Section "Extensions" Option "Composite" "true" EndSection Lenke til kommentar
Palme Skrevet 16. april 2006 Del Skrevet 16. april 2006 Du kan bruke min som en liten mal visst du vil: # /etc/X11/xorg.conf (xorg X Window System server configuration file) # # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the /etc/X11/xorg.conf manual page. # (Type "man /etc/X11/xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # If you have edited this file but would like it to be automatically updated # again, run the following command: # sudo dpkg-reconfigure -phigh xserver-xorg Section "Files" FontPath "/usr/share/X11/fonts/misc" FontPath "/usr/share/X11/fonts/cyrillic" FontPath "/usr/share/X11/fonts/100dpi/:unscaled" FontPath "/usr/share/X11/fonts/75dpi/:unscaled" FontPath "/usr/share/X11/fonts/Type1" FontPath "/usr/share/X11/fonts/CID" FontPath "/usr/share/X11/fonts/100dpi" FontPath "/usr/share/X11/fonts/75dpi" # paths to defoma fonts FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID" EndSection Section "Module" Load "i2c" Load "bitmap" Load "ddc" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "type1" Load "vbe" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "kbd" Option "CoreKeyboard" Option "XkbRules" "xorg" Option "XkbModel" "pc105" Option "XkbLayout" "no" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ImPS/2" Option "Emulate3Buttons" "true" Option "ZAxisMapping" "4 5" EndSection Section "Device" Identifier "NVIDIA Corporation NV41 [GeForce 6800]1" Driver "nvidia" BusID "PCI:4:0:0" Screen 1 EndSection Section "Device" Identifier "NVIDIA Corporation NV41 [GeForce 6800]0" Driver "nvidia" BusID "PCI:4:0:0" Screen 0 EndSection Section "Monitor" Identifier "Monitor1" Option "DPMS" # HorizSync 28-80 # VertRefresh 43-60 EndSection Section "Monitor" Identifier "Monitor0" Option "DPMS" # HorizSync 28-80 # VertRefresh 43-60 EndSection Section "Screen" Identifier "Screen1" Device "NVIDIA Corporation NV41 [GeForce 6800]1" Monitor "Monitor1" DefaultDepth 24 SubSection "Display" Depth 1 Modes "1600x1200" "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 4 Modes "1600x1200" "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 8 Modes "1600x1200" "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 15 Modes "1600x1200" "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 16 Modes "1600x1200" "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 24 Modes "1600x1200" "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" EndSubSection EndSection Section "Screen" Identifier "Screen0" Device "NVIDIA Corporation NV41 [GeForce 6800]0" Monitor "Monitor0" DefaultDepth 24 SubSection "Display" Depth 1 Modes "1600x1200" "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 4 Modes "1600x1200" "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 8 Modes "1600x1200" "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 15 Modes "1600x1200" "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 16 Modes "1600x1200" "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 24 Modes "1600x1200" "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" EndSubSection EndSection Section "ServerLayout" Identifier "Default Layout" Screen 0 "Screen0" Screen 1 "Screen1" leftOf "Screen0" InputDevice "Generic Keyboard" InputDevice "Configured Mouse" EndSection Lenke til kommentar
AudunSæther Skrevet 16. april 2006 Del Skrevet 16. april 2006 Min og, bare for å vise meg frem http://izte.net/~izte/shit/xorg.conf Lenke til kommentar
Anonym5656 Skrevet 16. april 2006 Forfatter Del Skrevet 16. april 2006 Min og, bare for å vise meg frem http://izte.net/~izte/shit/xorg.conf 5928667[/snapback] Ser du bruker GeForce FX 5200 samme som meg, men jeg får rosa skjær over bildet på der jeg bruker DVI-VGA adapter. Får du no lignende? eller hvilket adapter bruker du evt. Takk for begge Lenke til kommentar
olear Skrevet 16. april 2006 Del Skrevet 16. april 2006 Har hatt FX5200 og den fungerte fint med adapter. Prøvd med et annet adapter? litt OT: Ser at dere bruker ZAxisMapping, er egentlig den aktuell lengre? Jeg bruker ikke ZAxisMapping og scolling osv fungerer perfekt (bruker X.org 6.9). Her er min config, ikke så relevant for de som bruker nVIDIA, men kanskje for andre. Lenke til kommentar
AudunSæther Skrevet 16. april 2006 Del Skrevet 16. april 2006 ZAxisMapping har vært i configen min helt siden dinosaurene vandret på jorden, men om jeg trenger det enda er ikke sikkert Gakkakk: jeg fikk med adapter med FX5200-kortet mitt og har ikke hatt noen problemer. Lenke til kommentar
Anonym5656 Skrevet 16. april 2006 Forfatter Del Skrevet 16. april 2006 Følgte Izte sin xorg fil, og det funker som bare det Men det adapteret kjøpte jeg på Biltema, så kan det hende det rett og slett bare er dårlig kvalitet? Kan jeg få kjøpt sånn adapter på elkjøp\spaceworld\expert mon tro? Lenke til kommentar
