VIVO WDM Linux
Hei!
Jeg har et Gainward GeForce 7800GT kort. Og jeg vil bruke Tv-in delen på dette kortet.
Nå har jeg lett, lett og lett etter WDM drivere til dette kortet. Først brukte jeg Windows XP Pro 64bit, men Nvidia har ikke giddet å lage en driver enda. Og nå har jeg installert Ubuntu 5.10 (tenkte jeg skulle vente til dapper, men det var for lang tid ;)) . Jeg har installert "tvtime", og jeg har installert nvidiadriverne fra nvidia.com .
Hvordan kan jeg legge inn /dev/video* ?
Håper noen skønner problemet mitt. Takk for alle svar :)
0000:00:00.0 Memory controller: nVidia Corporation CK804 Memory Controller (rev a3)
0000:00:01.0 ISA bridge: nVidia Corporation CK804 ISA Bridge (rev a3)
0000:00:01.1 SMBus: nVidia Corporation CK804 SMBus (rev a2)
0000:00:02.0 USB Controller: nVidia Corporation CK804 USB Controller (rev a2)
0000:00:02.1 USB Controller: nVidia Corporation CK804 USB Controller (rev a3)
0000:00:04.0 Multimedia audio controller: nVidia Corporation CK804 AC'97 Audio Controller (rev a2)
0000:00:06.0 IDE interface: nVidia Corporation CK804 IDE (rev f2)
0000:00:07.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev f3)
0000:00:08.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev f3)
0000:00:09.0 PCI bridge: nVidia Corporation CK804 PCI Bridge (rev a2)
0000:00:0a.0 Bridge: nVidia Corporation CK804 Ethernet Controller (rev a3)
0000:00:0b.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
0000:00:0c.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
0000:00:0d.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
0000:00:0e.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
0000:00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
0000:00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
0000:00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
0000:00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
0000:01:00.0 VGA compatible controller: nVidia Corporation GeForce 7800 GT (rev a1)
0000:05:06.0 FireWire (IEEE 1394): Texas Instruments TSB43AB22/A IEEE-1394a-2000 Controller (PHY/Link)
Rivatv skal fungere med nvidia kort. Men det er visst flere enn meg som sliter med dette. Har lest og lest i Rivatv-help (newsgroup), men finner ingen enkel løsning.
Jeg ønsker kompabilitet i verden. Må jeg virkelig gå til det skrittet og installere Windows 2000/XP 32bit? =/
Like thats gonna make any difference ..
Har lest rundt på forum, og det er mange som har klaget og spurt om de ikke skal lage x64 drivere (nå er det snakk om WinXP-64bit) til VIVO-delen, men ingen har fått svar. De har jo laget video-ut drivere, men ingen video-inn drivere enda :( Jeg blir litt frustrert. Må nok koste på meg et ordentlig tv-kort gitt, hvis jeg skal klare å ta opp tv i neste fremtid.
