Hvorfor/hvordan kjører viften fortere når...
TheOats
Er ikke helt sikker her, men tror det er noe slikt:
Når du tar hånden nært viften få klarer ikke viften å dra like mye luft som vanlig, som et resultat av dette blåser den mindre luft, og dermed blir det mindre mottrykk for viften.
Samme effekten forekommer når du støvsuger og noe blokkerer slangen.
EDIT:
Power is needed for higher air flow during normal use. In fact, what surprises a lot of people is that a vacuum cleaner uses the least amount of power when you block the air flow (you will notice that the motor speeds up). Producing strong suction without air flow (i.e. lifting a bowling ball) is much less challenging than providing high air flow during normal vacuuming. Contrary to popular belief, it takes more power to properly vacuum up dust mites than to lift a bowling ball! A better indicator of suction power is a direct measurement where suction is measured in "inches of water lift" using a manometer. A better vacuum will have suction measuring greater than 70 inches of water lift with excellent airflow measuring greater than 120 CFM.
>Another thing I've wondered about is why a vacuum cleaner motor speeds up
>when you block the hose. It seems to me that restricting the flow of air
>should slow it down, not speed it up.
1. a) The resonance in the whistling mechanism has a higher frequency in
lower-density air.
b) The angle of approach increases unless the bomb falls on you, in which case
you don't remember the pitch at all.
2. The fan blades 'cavitate', in the sense that they are pushing a mass of air
round and round doing little work. Similar to a motorboat prop cavitating except
that there is no 'air bubble in water', just an 'air bubble in air'.
Endret av Patz
Når du setter hånden foran viften, vil den gå lettere(fortere) fordi den som nevnt over ikke har like mye luft å "jobbe med". Akkurat som støvsugeren når du setter hånden foran sugeåpningen. Dette er helt normalt å skjer på alle vifter og pumper som virker etter sentrifugal prinsippet.
Litt off topic:
Er ganske sikker på at jeg hører en forandring i lyden fra pcen når jeg for eksempel trykker inn høyre muse knapp får å lage en strek eller noe i adobe. Blir liksom en litt skarpere høyfrekvent (sikkert ikke riktig staving) lyd fra den.
