får ikke til dhcpd i FreeBSD
Heisann.
Jeg skal sette opp min freebsd server som router, isteden for linux serveren. Har confa dhcpd.conf slik som dette:
# dhcpd.conf
# Configuration file for ISC dhcpd (see 'man dhcpd.conf')
default-lease-time 86400;
max-lease-time 9200;
option subnet-mask 255.255.255.0;
option broadcast-address 192.168.0.255;
option routers 192.168.0.1;
option domain-name-servers 193.213.112.4, 130.67.60.68, 195.159.0.100;
option domain-name "home";
subnet 192.168.0.0 netmask 255.255.255.0 {
range 192.168.0.10 192.168.0.254;
ddns-update-style ad-hoc;
Å når jeg prøver å starte den kommer:
freebsd# dhcpd re0
Internet Systems Consortium DHCP Server V3.0.3
Copyright 2004-2005 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
Wrote 0 leases to leases file.
re0: not found
Skal jeg ikke kunne starte den med "dhcpd <dev>" ?
I linux bruker jeg:
ifconfig eth1 192.168.1.1 # router
echo 1 > /proc/sys/net/ipv4/ip_forward # router
iptables -t nat -F # router
iptables -t nat -A POSTROUTING -d ! 192.168.1.0/24 -o eth0 -j MASQUERADE #router
dhcpd eth1 # router
For og starte dhcpd.
Noen som vet feilen ?
Takker for svar.
Har aldri vært borti verken BSD eller dhcpd, men googlet litt, og fant denne siden:
http://www.mydigitallife.info/2005/11/18/i...cpd-on-freebsd/
Once you have finished writing your dhcpd.conf, you can proceed to start the server by issuing the following command:
# /usr/local/etc/rc.d/isc-dhcpd.sh start
Should you need to make changes to the configuration of your server in the future, it is important to note that sending a SIGHUP signal to dhcpd does not result in the configuration being reloaded, as it does with most daemons. A SIGTERM signal to stop the process, and then restart it using the command above. For example:
# ps wax | grep dhcpd
pid of dhcpd will be shown
# kill -15 (pid of dhcpd)
  • 1 måned senere...
