Nerd, geek or dork? (TEST)
Ni kon
Joe Normal
17 % Nerd, 34% Geek, 39% Dork
For The Record:
A Nerd is someone who is passionate about learning/being smart/academia.
A Geek is someone who is passionate about some particular area or subject, often an obscure or difficult one.
A Dork is someone who has difficulty with common social expectations/interactions.
You scored less than half in all three, earning you the title of: Joe Normal.
This is not to say that you don't have some Nerd, Geek or Dork inside of you--we all do, and you can see the percentages you have right above. This is just to say that none of those qualities stand out so much as to define you. Sure, you enjoy an episode of Star Trek now and again, and yeah, you kinda enjoyed a few classes back in the day. And, once in a while, you stumble while walking down the street even though there was nothing there to cause you to trip. But, for the most part, you look and act fairly typically, and aren't much of an outcast.
I'd say there's a fair chance someone asked you to take this test. In any event, fairly normal.
You scored higher than 3% on nerdiness
You scored higher than 38% on geekosity
You scored higher than 15% on dork points
Pure Nerd
69 % Nerd, 39% Geek, 30% Dork
For The Record:
You scored better than half in Nerd, earning you the title of: Pure Nerd.
The times, they are a-changing. It used to be that being exceptionally smart led to being unpopular, which would ultimately lead to picking up all of the traits and tendences associated with the "dork." No-longer. Being smart isn't as socially crippling as it once was, and even more so as you get older: eventually being a Pure Nerd will likely be replaced with the following label: Purely Successful.
Congratulations!
Pure Nerd ja seff teh pro ^^
Joe Normal
30 % Nerd, 26% Geek, 26% Dork
For The Record:
Ja, det var skremmende mange Joe Normal her.
5894395[/snapback]
Kanskje ikke så rart når spørsmålene er ting som;
Can you read, write or speak any specialized, "non-traditional" language? (A few possibilities: Tolkien's Elvish, Klingon, l33t, Celtic Runes, Esperanto, etc.)
:p
Hvem er det som kan slikt?
Meg:
Joe Normal.
You scored higher than 22% on nerdiness
You scored higher than 20% on geekosity
You scored higher than 8% on dork points
