eLang Skrevet 4. april 2006 Del Skrevet 4. april 2006 (endret) hvordan boote damn small linux fra en usb penn? edit: leif Endret 4. april 2006 av eLang Lenke til kommentar
Lidskjalv Skrevet 4. april 2006 Del Skrevet 4. april 2006 Først må du være sikker på at du har støtte for boot usb på Hovedkortet. Eller du må lage en boot-floppy. Dette finner du masse info om på Google. som: http://www.google.com/search?hs=bjt&hl=en&...ive&btnG=Search Lenke til kommentar
gnom1 Skrevet 5. april 2006 Del Skrevet 5. april 2006 Har ikke peil på Damn Small, men http://puppyos.com/ er en live-cd med et greit script som installere til en usb-penn, bruker syslinux, etc Lenke til kommentar
Anonym5656 Skrevet 5. april 2006 Del Skrevet 5. april 2006 "Ah Ha! I have finally figured out a lot more about the DSL CD! I did some more reading at the DSL forum and ran across something interesting! Easier to install to the pen drive than I could have imagined! Going to the menu, after doing a Live CD load of DSL, I can go to Applications>Tools and there are a dozen choices as to what you want to do. You can do frugal installs, HD installs or whatever. Among those choices is to install to a pen drive. There are also options for making a boot floppy drive and so forth. I haven't tried it yet, until I get a few more details, but it appears I can merely install DSL to the pen drive, right from that group of options. If I merely wanted to make a floppy boot disk, I could do so there, but I'm trying to find more info on installing QEMU, to see if I couldn't do that and merely start DSL, directly from inside a Windows computer. I'll most more as I find out. If you are going to exclusively use DSL from inside a running Windows operating system, then you should download the dsl-embedded version and unzip the contents into your USB pendrive." Lenke til kommentar
kyrsjo Skrevet 7. april 2006 Del Skrevet 7. april 2006 http://www.linuxguiden.no/index.php/USB_boot Lenke til kommentar
Lidskjalv Skrevet 7. april 2006 Del Skrevet 7. april 2006 (endret) Eller du kjører IDE og Compact Flash på denne. CP kan nå fåes i 1Gb størrelse. Link:http://www.komplett.no/k/ki.asp?sku=317198 Endret 7. april 2006 av pwd3679 Lenke til kommentar
Goscinny Skrevet 7. april 2006 Del Skrevet 7. april 2006 Eller du kjører IDE og Compact Flash på denne. CP kan nå fåes i 1Gb størrelse. Link:http://www.komplett.no/k/ki.asp?sku=317198 5883519[/snapback] Trodde du kunne få dei på 4 GB, jeg . Eller var det kanskje MS eller SD? Lenke til kommentar
Lidskjalv Skrevet 7. april 2006 Del Skrevet 7. april 2006 Ja de stemmer jo. 4GB skal det være. Lenke til kommentar
Solow Skrevet 7. april 2006 Del Skrevet 7. april 2006 Hvordan er hastigheten på CF i forhold til HD? Hvis hastigheten er høyere og volumet stillere (som den seff er) må jo dette være en god permanent løsning!? Prisen med 4GB ville blitt rundt 1500 for CF og kortleseren. Lenke til kommentar
Lidskjalv Skrevet 7. april 2006 Del Skrevet 7. april 2006 (endret) Hvorfor slite med USB disker? Det er passè allerede. Bildet er lånt fra denne siden:http://www.multigame.com/CF.html Endret 7. april 2006 av pwd3679 Lenke til kommentar
Lidskjalv Skrevet 4. mai 2006 Del Skrevet 4. mai 2006 Hvorfor slite med USB disker? Det er passè allerede. Bildet er lånt fra denne siden:http://www.multigame.com/CF.html 5885902[/snapback] Noen som har prøvd dette oppsettet? Lenke til kommentar
