Feil med routeren eller ISP?
Jeg opplever at internett faller ut flere ganger for dag. Den blir ute i bare noen sekunder, men det er nok til at overføring av data stopper opp og lager problemer for meg.
Jeg er usikker på om det er noe galt med routeren/modemet eller en feil som ISPen min, MTULink, står for.
Jeg har en 3com OfficeConnect ADSL Wireless 11g Firewall Router, med siste firmwareoppdatering. Her er et utdrag fra loggen:
2006.04.01 14:08:07 192.168.1.174 login success
2006.04.01 14:08:02 User from 192.168.1.174 timed out
2006.04.01 12:05:26 NTP Date/Time updated.
2006.04.01 10:30:09 sending ACK to 192.168.1.111
2006.04.01 06:02:03 NTP Date/Time updated.
2006.04.01 00:13:04 sending ACK to 192.168.1.2
2006.04.01 00:13:04 sending OFFER to 192.168.1.2
2006.04.01 00:13:00 sending OFFER to 192.168.1.2
2006.03.31 23:58:39 NTP Date/Time updated.
2006.03.31 23:08:13 If(PPPoE1) PPP connection ok !
2006.03.31 23:08:12 PPPoE1 get IP:213.151.140.77
2006.03.31 23:08:12 Username and Password: OK
2006.03.31 23:08:12 PPPoE1 start PPP
2006.03.31 23:08:12 PPPoE receive PADS
2006.03.31 23:08:11 PPPoE send PADR
2006.03.31 23:08:11 PPPoE receive PADO
2006.03.31 23:08:11 PPPoE send PADI
2006.03.31 23:08:06 PPPoE receive PADS
2006.03.31 23:08:06 PPPoE send PADR
2006.03.31 23:08:06 PPPoE receive PADO
2006.03.31 23:08:06 PPPoE send PADI
2006.03.31 23:08:06 ADSL Media Up !
2006.03.31 23:07:36 PPPoE stop
2006.03.31 23:07:36 PPPoE1 stop PPP
2006.03.31 23:07:36 ADSL Media Down !
2006.03.31 21:26:41 If(PPPoE1) PPP connection ok !
2006.03.31 21:26:40 PPPoE1 get IP:213.151.140.77
2006.03.31 21:26:40 Username and Password: OK
2006.03.31 21:26:39 PPPoE1 start PPP
2006.03.31 21:26:39 PPPoE receive PADS
2006.03.31 21:26:39 PPPoE send PADR
2006.03.31 21:26:39 PPPoE receive PADO
2006.03.31 21:26:39 PPPoE send PADI
2006.03.31 21:26:34 PPPoE receive PADS
2006.03.31 21:26:34 PPPoE send PADR
2006.03.31 21:26:34 PPPoE receive PADO
2006.03.31 21:26:34 PPPoE send PADI
2006.03.31 21:26:34 ADSL Media Up !
2006.03.31 21:26:01 PPPoE stop
2006.03.31 21:26:01 PPPoE1 stop PPP
2006.03.31 21:26:00 ADSL Media Down !
2006.03.31 21:23:55 sending ACK to 192.168.1.2
2006.03.31 21:18:10 If(PPPoE1) PPP connection ok !
2006.03.31 21:18:08 PPPoE1 get IP:213.151.140.77
2006.03.31 21:18:08 Username and Password: OK
Jeg hadde samme type problem med min gamle router, som forøvrig også var en 3com router. Derfor tror jeg at det er MTULink som har en ustabil linje.
Er det noe mer info dere trenger for å hjelpe meg litt?
Mvh
Yngve
