erlnico Skrevet 31. mars 2006 Rapporter Del Skrevet 31. mars 2006 (endret) Hei, Eg har programmert ei side med css script, men det ser ut til å være ein eller fleire feil i scriptet. Kan noen hjelpe meg?? Du finner heimesiden på http://erlendsn.com/bfme2thirdage/ Her er koden min for index.php <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" /> <title>Untitled Document</title> <link href="default.css" rel="stylesheet" type="text/css" /> </head> <body> <div id="container"> <div id="header"><img src="gfx/overskrift.gif" alt="Header" /></div> <div id="mainContent"> <div id="navigation"> <img src="gfx/main_menu.gif" alt="main_menu" /> <ul> <li>Home</li> <li>Guestbook</li> <li>Forum</li> <li>Downloads</li> <li>Links</li> <li>Contact</li> </ul> <img src="gfx/downloads.gif" alt="downloads" /> </div> <div id="right"> <img src="gfx/poll.gif" alt="poll" /> </div> <div id="mainBody"> <p> <a href="http://jigsaw.w3.org/css-validator/"> <img style="border:0;width:88px;height:31px" src="http://jigsaw.w3.org/css-validator/images/vcss" alt="Valid CSS!" /> </a> </p> </div> </div> <div id="footer"><img src="gfx/bottom.gif" alt="Bottom" /></div> </div> </body> </html> og for css #container { padding: 0px; width: 1024px; margin-top: 0px; margin-right: auto; margin-bottom: 0px; margin-left: auto; } body { background-color: #000000; margin: 0px; padding: 0px; } #navigation { float: left; padding: 0px; margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 30px; } #right { float: right; padding: 0px; margin-top: 0px; margin-right: 40px; margin-bottom: 0px; margin-left: 0px; clear: none; } #mainBody { padding: 0px; margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 170px; float: none; background-color: #FFFFFF; } #mainBody p { margin: 0px; padding-top: 0px; padding-right: 0px; padding-bottom: 1.2em; padding-left: 0px; font-family: Arial, Helvetica, sans-serif; font-size: 12px; } #header { margin: 0px; padding: 0px; width: 1000px; } #footer { margin: 0px; padding: 0px; width: 1000px; } #mainContent { background-image: url(gfx/background.gif); background-repeat: repeat-y; background-position: center top; padding: 0px; width: 1000px; margin: 0px; } #navigation ul { font-family: Arial, Helvetica, sans-serif; color: #000000; padding: 0px; margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 20px; } Endret 31. mars 2006 av fistersn Lenke til kommentar
Arne Skrevet 31. mars 2006 Rapporter Del Skrevet 31. mars 2006 Ein god start kan jo vere å forteje korleis du vil den skal vere. Lenke til kommentar
erlnico Skrevet 31. mars 2006 Forfatter Rapporter Del Skrevet 31. mars 2006 Som dere kan si på sida mi, så vil eg at det grå feltet skal gå helt ned til bunn på venstre og høgre side. I tillegg så skal det være kvit farge i midtfeltet... Noe som det ikkje er nå Lenke til kommentar
qualbeen Skrevet 2. april 2006 Rapporter Del Skrevet 2. april 2006 (endret) har ikke tittet så nøye på css'en din, men hva med å legge inn følgende helt øverst i css-dokumentet *{ margin:0; padding:0; } Edit: så nå at du har spesifisert det meste av margin/padding. Tviler derfor på at mitt svar vil hjelpe :/ Endret 2. april 2006 av qualbeen Lenke til kommentar
funkweb Skrevet 2. april 2006 Rapporter Del Skrevet 2. april 2006 Du har nå 2 doctyper, enkelte steder har du dobbel av <html><head> ovs.. rens koden din. Lenke til kommentar
