TES: 360 Kontroller på PC med Oblivion [LØST]
bte
Er det noen som har prøvd å spille Oblivion på PC med kablet xbox 360 kontroller?
Jeg vet at det fungerer på enkelte spill. Og siden PC oblivion og Xbox Oblivion er helt likt så burde det vel funke?
EDIT:
Har funnet en løsning på dette spørsmålet.
Game Pad Functionality
Although the PC version of Oblivion handles best when played with a keyboard and mouse, it is possible to play the game with an assortment of game pads as well. Due to the variance in these game pads, it may be necessary to make a few changes to the Oblivion.ini file located in My Documents\My Games\Oblivion. Below is a list of the settings that can be changed to make a Xbox 360 controller attached to a PC, function better with Oblivion. It should be noted however, that because the PC version of the game was optimized to play with a keyboard and mouse, the experience will NOT be the same, as using a 360 controller on the Xbox 360 version of the game. Additionally, these settings can be applied to other game pads, but the values represented may need to be tweaked further. Finally, the mapping of the buttons will need to be determined when entering the game, and can be changed in Options - Controls, from the Main Menu - Do NOT map the directional controls (Forward, Backward, Left, Right), as this will overwrite certain changes made in the Oblivion.ini file.
These are the default settings in the Oblivion.ini:
;X = 1, Y = 2, Z = 3, XRot = 4, YRot = 5, ZRot = 6
iJoystickMoveFrontBack=2
iJoystickMoveLeftRight=1
fJoystickMoveFBMult=1.0000
fJoystickMoveLRMult=1.0000
iJoystickLookUpDown=6
iJoystickLookLeftRight=3
fJoystickLookUDMult=0.0020
fJoystickLookLRMult=0.0020
Change to these values to get better functionality from a 360 game pad connected to a PC.
fJoystickMoveFBMult=2.0000
fJoystickMoveLRMult=2.0000
iJoystickLookUpDown=5
iJoystickLookLeftRight=4
fJoystickLookUDMult=0.7500
fJoystickLookLRMult=0.7500
Make sure the settings are saved. Note, changes to the Oblivion.ini file will not be saved if Oblivion is running when the changes are made.
Endret av bte
  • 2 uker senere...
