Ny begynner. noen spørsmål om musover
Se på koden:
<?php
    require($_SERVER["DOCUMENT_ROOT"]."/musikk_ny/files/config/db_conn.php");
    $db = mysql_connect($db_host, $db_user, $db_password, $db_name) or die ("Kunne ikke koble til MySQL");
    mysql_select_db($db_name, $db) or die ("Kunne ikke koble til databasen");
<html>
<head>
<title>Liste etter cd tittel</title>
              <script type="text/javascript">
              function cdinfo()
               cden.style.fontSize="200%"
               cden.style.color="blue"
               cden.style.fontFamily="Times"
              function vanlig()
               cden.style.fontSize="100%"
               cden.style.color="black"
              </script>
</head>
<body>
<table border="0" width="100%" cellspacing="1" cellpading="2">
     <tr align="center">
 <td width="4%" bgcolor="#cccccc">CD id</td>
 <td width="25%" bgcolor="#EEEEEE">CD tittel</td>
 <td width="25%" bgcolor="#cccccc">Artist / Gruppe</td>
 <td width="5%" bgcolor="#EEEEEE">Utgivelse år</td>
 <td width="15%" bgcolor="#cccccc">Plateselskap</td>
 <td width="6%" bgcolor="#EEEEEE">Sjanger</td>
 <td width="10%" bgcolor="#cccccc">Registrert dato</td>
 <td width="5%" bgcolor="#EEEEEE">Registrert kl.</td>
</tr>
<?php
$sql = mysql_query("select * from cd order by CDTittel");
    for($i = 0; $i < mysql_num_rows($sql); $i++)
      //cd tabellen
      $CDID = mysql_result($sql, $i, "CDID");
      $cd = mysql_result($sql, $i, "CDTittel");
      $artist = mysql_result($sql, $i, "Artist");
      $utgitt = mysql_result($sql, $i, "UtgivelsesAar");
      $plate = mysql_result($sql, $i, "Plateselskap");
      $cdtype = mysql_result($sql, $i, "CDType");
      $dato = mysql_result($sql, $i, "Dato");
      $kl = mysql_result($sql, $i, "Kl");
      //cd informasjon
      $Rank = mysql_result($sql, $i, "Kl");
      $CDMerknad = mysql_result($sql, $i, "Kl");
      //artist informasjon
      $Nasjonalitet = mysql_result($sql, $i, "Kl");
      $Land = mysql_result($sql, $i, "Kl");
      $Sted = mysql_result($sql, $i, "Kl");
      if ($i % 2)
        $bg_farge = "#f4f4f4";
      else
        $bg_farge = "#a4a4a4";
Print'
       <tr>
                 <td width="4%" bgcolor="'.$bg_farge.'">
   '.$CDID.'
                 </td>
                 <td width="25%" bgcolor="'.$bg_farge.'">';
                 <p id="cden" onMouseOver="cdinfo()" onMouseOut="vanlig()"><?php echo $cd; ?></p>
                 </td>
                 <td width="25%" bgcolor="<?php echo $bg_farge ?>">
                 <?php echo $artist; ?>
<?php
Print '           </td>
                 <td width="5%" bgcolor="'.$bg_farge.'">
                     '.$utgitt.'
                 </td>
                 <td width="15%" bgcolor="'.$bg_farge.'">
                     '.$plate.'
                 </td>
                 <td width="6%" bgcolor="'.$bg_farge.'">
                     '.$cdtype.'
                 </td>
                 <td width="10%" bgcolor="'.$bg_farge.'">
                     '.$dato.'
                 </td>
                     '.$kl.'
                 </td>';
<center><a href="/musikk_ny/index.htm">Gå tilbake til framsiden her.</a></center>
</tr></table>
</body>
</html>
Jeg får fram en tabell med informasjonen jeg har i hentet ut fra en database.
Jeg ønsker nå å hente ut informasjon fra tabell "cdinfo" fra databasen (MySQL) og når jeg fører musen over cd tittelen skal denne informajonen vises i der. Samme med artisten.
Kan noen hjelpe meg med det?
Gjerne gi meg en løsning :D:D:D
Sier tusen tusen takk for hjelpen på forhånd
