johann Skrevet 29. mars 2006 Rapporter Del Skrevet 29. mars 2006 Hei, har noen spørsmål som jeg gjerne skulle fått svar på. Hva er forskjellen på WINS og DNS? Hva betyr "Mixed mode" i et WLAN? Forklar betegnelsen SSID. Forklar betegnelsen WEP. Hva er Auto "fallback" i et WLAN? Hva er kryptering? Takker for alle svar. Lenke til kommentar
Pengu Skrevet 29. mars 2006 Rapporter Del Skrevet 29. mars 2006 Dette var et dårlig kamuflert forsøk på å få andre til å gjøre leksene dine. Gjør skoleoppgaven din selv du! :!: Lenke til kommentar
tommy_89 Skrevet 29. mars 2006 Rapporter Del Skrevet 29. mars 2006 (endret) Google er en fin ting SSID Service set identifierFrom Wikipedia, the free encyclopedia (Redirected from SSID) In Wi-Fi Wireless LAN computer networking, a service set identifier (SSID) is a code attached to all packets on a wireless network to identify each packet as part of that network. The code consists of a maximum of 32 alphanumeric characters. All wireless devices attempting to communicate with each other must share the same SSID. Apart from identifying each packet, SSID also serves to uniquely identify a group of wireless network devices used in a given "Service Set". There are two major variants of the SSID. Ad-hoc wireless networks (IBSS) that consist of client machines without an access point use the IBSS ID (Independent Basic Service Set Identifier); whereas on an infrastructure network which includes an access point (BSS) or possibly an (ESS), the BSS ID or ESS ID (E for Extended) is used instead. The naming is for convention only as the IEEE 802.11 standard dictates that an IBSS, BSS, and ESS are each defined by an SSID, otherwise known as a "Network Name". A Network Name is commonly set to the name of the network operator, such as a company name. Equipment manufacturers have liberally used all of the above SSID naming conventions to essentially describe the same thing. In some instances, the convention is wrong, as in the case of BSSID. An extremely weak form of wireless network security is to turn off the broadcast of the SSID: to the average user there does not appear to be a network in use; it is however still readily available to crackers using the appropriate tools. This should not be the only form of defence to protect a wireless network. Other forms of encryption and authentication should also be used, WEP at the very least but preferably some form of WPA. WEP Wired Equivalent Privacy (WEP) is a scheme to secure wireless networks (WiFi). Because a wireless network broadcasts messages using radio, it is particularly susceptible to eavesdropping. WEP was intended to provide comparable confidentiality to a traditional wired network, hence the name. Several serious weaknesses were identified by cryptanalysts, and WEP was superseded by Wi-Fi Protected Access (WPA) in 2003, and then by the full IEEE 802.11i standard (also known as WPA2) in 2004. Despite the weaknesses, WEP provides a level of security that can deter casual snooping. Endret 29. mars 2006 av tommy_89 Lenke til kommentar
johann Skrevet 29. mars 2006 Forfatter Rapporter Del Skrevet 29. mars 2006 Skulle helst ha hatt det i sånn 2-3 setninger på hvert spm. OG på norsk. Lenke til kommentar
tommy_89 Skrevet 29. mars 2006 Rapporter Del Skrevet 29. mars 2006 Skulle helst ha hatt det i sånn 2-3 setninger på hvert spm. OG på norsk. 5831508[/snapback] Du greier å forkorte det selv Håper du forstår engelsk Lenke til kommentar
Jørgen Sørheim Skrevet 29. mars 2006 Rapporter Del Skrevet 29. mars 2006 Skulle helst ha hatt det i sånn 2-3 setninger på hvert spm. OG på norsk. 5831508[/snapback] Gjør dine egne lekser. Stenges. Lenke til kommentar
