virus på maskinen rdriv.sys
har ei fil som heter "C:\WINDOWS\system32\rdriv.sys" Som ikke hører til der det er et "TROJ_ROOTKIT.E" Får meld fra tren micro om "Unable to clean infected file. The file was quarantined." å den kommer opp hele tiden noen som vet hva som kan gjøres?
TROJ_ROOTKIT.E
MANUAL REMOVAL INSTRUCTIONS
Note: Systems affected by this malware are also usually infected by a BOT worm. Be sure to scan your system for any related malware and to follow the corresponding removal instructions.
Restarting in Safe Mode
• On Windows NT (VGA mode)
Click Start>Settings>Control Panel.
Double-click the System icon.
Click the Startup/Shutdown tab.
Set the Show List field to 10 seconds and click OK to save this change.
Shut down and restart your computer.
Select VGA mode from the startup menu.
• On Windows 2000
Restart your computer.
Press the F8 key, when you see the Starting Windows bar at the bottom of the screen........
Klikk Her for å lese hele
