MeSs Skrevet 26. mars 2006 Del Skrevet 26. mars 2006 (endret) Har fått noen skikkelige errors på noe brenning idag, har prøvd 4 pakker med dvd-r disks, 3 forskjellige programmer.. Har fått TO (samme iso fil) velykket dvd, av 7.. Mistenker hardware feil, når jeg har prøvd 4 forskjellige pakker med dvder, selv om det er samme merke, Thats Write.. Fikk iallfall litt info ut av alcohol 120% da.. Noen som vet hva som er feil?? plagsomt ########################### System Information ########################### Windows XP Professional 5.1 Service Pack 2 (Build 2600) Processor info: AMD Athlon XP 2200+ (2697MHz) Memory Available to Windows: 1 310 192 KB ############################ Program Information ########################### File Name: C:\Program Files\Alcohol Soft\Alcohol 120\Alcohol.exe Company Name: Alcohol Soft Development Team Description: Alcohol 120% Original: alcohol.exe Product: Alcohol 120% Trademarks: Alcohol Soft Development Team Copyright: Copyright© 2002-2005 Alcohol Soft Development Team Version: 1.9.5 ( Build 3105 ) Date: 2005/12/18 Size: 1517568 Bytes Hash: f27dd3aebc8a914a498f636d15b56c79 Hash(1): Hash(2): File Name: C:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll Description: Alcohol virtual device control library Original: alcoholx.dll Copyright: Copyright © 2000-2004 Version: 3.47.0 ( Build 0 ) Date: 2004/08/12 Size: 74752 Bytes Hash: 1b7083f2ca3a98bb3c14c3a08ad5c2d2 File Name: C:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll Company Name: Alcohol Soft Development Team Description: Alcohol Software Device Capability Library Original: devsupp.dll Product: Alcohol Software Device Capability Library Copyright: Copyright© 2002-2003 Alcohol Soft Development Team Version: 2.4.0 ( Build 627 ) Date: 2005/06/27 Size: 42496 Bytes Hash: 4e112134e74179bf3f0f69a93603131b ########################### User Information ########################### Licensed to: ************** Registered User ID: 0000 ########################### Options Setting ########################### Devices control interface: Default Driver Control Interface CPU Priority Level: High Memory Buffer Size (MB): 128 Examine the accuracy of data read from physical device: Yes Turn off "Auto-Select best write speed" function if possible: No Overburn disc(s): No Fill memory buffer before recording discs: Yes Ignore Media Type: Yes RMPS (Recordable Media Physical Signature) Emulation: No BAD Sectors Emulation: No Sub-Channel Data Fixed & Emulation: No Laserlock Emulation: No Current Language: English ############################ Device(s) List ############################ (H:) HL-DT-ST DVDRAM GSA-4120B (atapi, Port 0, Bus 0, Target 1, Lun 0) (F:) SCSIVAX DVD/CD-ROM (Vax347s, Port 2, Bus 0, Target 0, Lun 0) ##################### Installed Device Drivers List ##################### ACPI.sys afd.sys ALCXWDM.SYS amdk7.sys AnyDVD.sys ATMFD.DLL audstub.sys Beep.SYS blueletaudio.sys BOOTVID.dll BTHidMgr.sys btnetdrv.sys Camdrl.sys Cdfs.SYS cdrom.sys CLASSPNP.SYS ctlfacem.sys d347bus.sys d347prt.sys disk.sys DLKRTS.SYS dmio.sys dmload.sys drmk.sys dump_atapi.sys dump_WMILIB.SYS Dxapi.sys dxg.sys dxgthk.sys ElbyCDFL.sys ElbyCDIO.sys ElbyDelay.sys emu10k1m.sys fdc.sys Fips.SYS fltMgr.sys Fs_Rec.SYS ftdisk.sys gameenum.sys GEARAspiWDM.sys hal.dll HIDCLASS.SYS HIDPARSE.SYS hidusb.sys HTTP.sys i8042prt.sys imapi.sys ipnat.sys ipsec.sys isapnp.sys kbdclass.sys KDCOM.DLL kmixer.sys ks.sys KSecDD.sys lvsvf2.sys lvusbsta.sys mc21.tmp mnmdd.SYS Modem.SYS mouclass.sys mouhid.sys MountMgr.sys mrxdav.sys mrxsmb.sys Msfs.SYS msgpc.sys mssmbios.sys Mup.sys NDIS.sys ndistapi.sys ndisuio.sys ndiswan.sys NDProxy.SYS netbios.sys netbt.sys Npfs.SYS ntdll.dll Ntfs.sys ntoskrnl.exe Null.SYS nv4_disp.dll nv4_mini.sys parport.sys PartMgr.sys ParVdm.SYS pci.sys PCIIDEX.SYS portcls.sys prodrv06.sys prohlp02.sys prosync1.sys psched.sys ptilink.sys PxHelp20.sys rasacd.sys rasl2tp.sys raspppoe.sys raspptp.sys raspti.sys rdbss.sys RDPCDD.sys rdpdr.sys redbook.sys RootMdm.sys SCSIPORT.SYS secdrv.sys serenum.sys serial.sys sfdrv01.sys sfhlp01.sys sfhlp02.sys sfmanm.sys sfsync02.sys sfsync03.sys sfvfs02.sys sptd.sys SPTD4621.SYS sr.sys srv.sys STREAM.SYS swenum.sys sysaudio.sys tcpip.sys TDI.SYS termdd.sys Udfs.SYS update.sys usbaudio.sys usbccgp.sys USBD.SYS usbehci.sys usbhub.sys USBPORT.SYS usbuhci.sys Vax347b.sys Vax347s.sys vbtenum.sys VComm.sys VcommMgr.sys vga.sys viaide.sys VIDEOPRT.SYS viaagp.sys viaagp1.sys VolSnap.sys wanarp.sys watchdog.sys wdmaud.sys win32k.sys WmBEnum.sys WMILIB.SYS WmXlCore.sys ################## Detailed Information of Device(s) ################## /////////////////////////////////////////////////////////////////////// (H:) HL-DT-ST DVDRAM GSA-4120B(0:1) detail information. /////////////////////////////////////////////////////////////////////// Vendor Identification: HL-DT-ST Product Identification: DVDRAM GSA-4120B Production Revision Level: A102 Location: atapi, Port 0, Bus 0, Target 1, Lun 0 Support recording method: DAO, RAW DAO(96), TAO, DVD DAO BURN-Free Technology: BURN-Proof Auto-Select best write speed: Not Supported -* Note: This information below is provided by the unit, it might be inaccurate. *- -* This software does not use this information! *- Removable media: Yes Version: ATAPI (INF-8090i/INF-8020i/INF-8028i) Response Data Format: 02h CD-R Read/Write: Yes/Yes CD-RW Read/Write: Yes/Yes Read CD-R Fixed Packet: Yes Test Write: Yes DVD-ROM Read: Yes DVD-R Read/Write: Yes/Yes DVD-RAM Read/Write: Yes/Yes Audio Play: Yes Composite Audio and Video Data Stream: No Digital output (IEC958) on port 1 Supported: No Digital output (IEC958) on port 2 Supported: No Mode 1 Form 2: Yes Mode 2 Form 2: Yes Multi-Session: Yes BUF: Yes CD-DA Commands supported: Yes CD-DA Stream is Accurate: Yes R-W Supported: No R-W De-interleaved and Corrected: No C2 Pointers Support: Yes ISRC Supported: Yes UPC Supported: Yes Read Bar Code: No Lock media into the drive: Yes Currently drive Lock state: Unlocked Prevent Jumper: No Eject Command: Yes Separate volume levels: Yes Separate channel mute: Yes Changer Supports Disc Present: No Software slot selection: No Side change capable: No P through W in Lead-In: Yes ####################################################################### ###################### Source Disc/Image Information ###################### Type: Unknown Path: E:\Downloads\Filmer\Ferdig\****************\ Name: ********.dvdr.img Size: 4426.26 MB Session: 1 Track: 1 Session 01: Track 01: DVD, Length: 2266244(4.32 GB), Address: 000000 ############################################################################# ####################### Dumping/Recording Progress Log ####################### 22:43:03 Processor info: AMD Athlon XP 2200+ (1733MHz) 22:43:03 Memory Available to Windows: 1 310 192 KB 22:43:03 Memory Buffer size: 128 MB 22:43:04 Image file loading: E:\Downloads\Filmer\Ferdig\*****************.dvdr.img 22:43:04 DVD Source Info: Session: 1, Track: 1, Length: 4.32 GB / 503:36:44 22:43:10 (H:) HL-DT-ST DVDRAM GSA-4120B(0:1): Recording Method/Speed 22:43:10 Recording - DVD DAO - 4.0X (5540 KB/Sec) (H:) HL-DT-ST DVDRAM GSA-4120B(0:1) - Media format: DVD-R 22:53:50 (H:) HL-DT-ST DVDRAM GSA-4120B(0:1) - [Write ERROR] LBA: 1652736, Length: 16 S:KEY - 04/09/01 - "Tracking Servo Failure" 22:53:50 (H:) HL-DT-ST DVDRAM GSA-4120B(0:1): Recording failed! 22:53:50 Error message: [04/09/01] - Tracking Servo Failure 22:53:50 (H:) HL-DT-ST DVDRAM GSA-4120B(0:1): Recording failed! 22:53:50 Image file loading aborted! 22:53:52 Something is wrong with the recording procedure! Please check the log file and report any errors to Technical Support. ############################################################################## Endret 26. mars 2006 av MeSs Lenke til kommentar
Psh Skrevet 27. mars 2006 Del Skrevet 27. mars 2006 Platene du bruker er absolutt ikke å annbefale, That's Write bør du styre unna neste gang. Jeg tror det burde hjelpe å oppdatere firmware på brenneren. Firmwaren du bruker (A102) er meget gammel, nyeste firmware (A117) finner du her. Lenke til kommentar
MeSs Skrevet 27. mars 2006 Forfatter Del Skrevet 27. mars 2006 (endret) Platene du bruker er absolutt ikke å annbefale, That's Write bør du styre unna neste gang.Jeg tror det burde hjelpe å oppdatere firmware på brenneren. Firmwaren du bruker (A102) er meget gammel, nyeste firmware (A117) finner du her. 5818864[/snapback] Har ikke hatt noen problemer med di platene før, har brent 500 stk før nå.. Men skal prøve ny firmware Takk for svar.. Mvh Marius EDIT: åssen legger man inn ny firmwarE? Endret 27. mars 2006 av MeSs Lenke til kommentar
MeSs Skrevet 27. mars 2006 Forfatter Del Skrevet 27. mars 2006 fikk samme meldinga etter jeg har oppdatert platene ser like ut bak og, er igjen ca 8mm som det ikke er brent på.. Lenke til kommentar
MeSs Skrevet 31. mars 2006 Forfatter Del Skrevet 31. mars 2006 (endret) En annen logg fra en annen brenning som ikke ble velykket ########################### System Information ########################### Windows XP Professional 5.1 Service Pack 2 (Build 2600) Processor info: AMD Athlon XP 2200+ (1733MHz) Memory Available to Windows: 1 310 192 KB ############################ Program Information ########################### File Name: C:\Program Files\Alcohol Soft\Alcohol 120\Alcohol.exe Company Name: Alcohol Soft Development Team Description: Alcohol 120% Original: alcohol.exe Product: Alcohol 120% Trademarks: Alcohol Soft Development Team Copyright: Copyright© 2002-2005 Alcohol Soft Development Team Version: 1.9.5 ( Build 3105 ) Date: 2005/12/18 Size: 1517568 Bytes Hash: f27dd3aebc8a914a498f636d15b56c79 Hash(1): Hash(2): File Name: C:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll Description: Alcohol virtual device control library Original: alcoholx.dll Copyright: Copyright © 2000-2004 Version: 3.47.0 ( Build 0 ) Date: 2004/08/12 Size: 74752 Bytes Hash: 1b7083f2ca3a98bb3c14c3a08ad5c2d2 File Name: C:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll Company Name: Alcohol Soft Development Team Description: Alcohol Software Device Capability Library Original: devsupp.dll Product: Alcohol Software Device Capability Library Copyright: Copyright© 2002-2003 Alcohol Soft Development Team Version: 2.4.0 ( Build 627 ) Date: 2005/06/27 Size: 42496 Bytes Hash: 4e112134e74179bf3f0f69a93603131b ########################### User Information ########################### Licensed to: ********** Registered User ID: 0000 ########################### Options Setting ########################### Devices control interface: Default Driver Control Interface CPU Priority Level: High Memory Buffer Size (MB): 128 Examine the accuracy of data read from physical device: Yes Turn off "Auto-Select best write speed" function if possible: No Overburn disc(s): No Fill memory buffer before recording discs: Yes Ignore Media Type: Yes RMPS (Recordable Media Physical Signature) Emulation: No BAD Sectors Emulation: No Sub-Channel Data Fixed & Emulation: No Laserlock Emulation: No Current Language: English ############################ Device(s) List ############################ (H:) HL-DT-ST DVDRAM GSA-4120B (atapi, Port 0, Bus 0, Target 1, Lun 0) (F:) SCSIVAX DVD/CD-ROM (Vax347s, Port 2, Bus 0, Target 0, Lun 0) ##################### Installed Device Drivers List ##################### ACPI.sys afd.sys ALCXWDM.SYS amdk7.sys AnyDVD.sys ATMFD.DLL audstub.sys Beep.SYS blueletaudio.sys BOOTVID.dll BTHidMgr.sys btnetdrv.sys Camdrl.sys Cdfs.SYS cdrom.sys CLASSPNP.SYS ctlfacem.sys d347bus.sys d347prt.sys disk.sys DLKRTS.SYS dmio.sys dmload.sys drmk.sys dump_atapi.sys dump_WMILIB.SYS Dxapi.sys dxg.sys dxgthk.sys ElbyCDFL.sys ElbyCDIO.sys ElbyDelay.sys emu10k1m.sys fdc.sys Fips.SYS fltMgr.sys Fs_Rec.SYS ftdisk.sys gameenum.sys GEARAspiWDM.sys hal.dll HIDCLASS.SYS HIDPARSE.SYS hidusb.sys HTTP.sys i8042prt.sys imapi.sys ipnat.sys ipsec.sys isapnp.sys kbdclass.sys KDCOM.DLL kmixer.sys ks.sys KSecDD.sys lvsvf2.sys lvusbsta.sys mc21.tmp mnmdd.SYS Modem.SYS mouclass.sys mouhid.sys MountMgr.sys mrxdav.sys mrxsmb.sys Msfs.SYS msgpc.sys mssmbios.sys Mup.sys NDIS.sys ndistapi.sys ndisuio.sys ndiswan.sys NDProxy.SYS netbios.sys netbt.sys Npfs.SYS ntdll.dll Ntfs.sys ntoskrnl.exe Null.SYS nv4_disp.dll nv4_mini.sys parport.sys PartMgr.sys ParVdm.SYS pci.sys PCIIDEX.SYS portcls.sys prodrv06.sys prohlp02.sys prosync1.sys psched.sys ptilink.sys PxHelp20.sys rasacd.sys rasl2tp.sys raspppoe.sys raspptp.sys raspti.sys rdbss.sys RDPCDD.sys rdpdr.sys redbook.sys RootMdm.sys SCSIPORT.SYS secdrv.sys serenum.sys serial.sys sfdrv01.sys sfhlp01.sys sfhlp02.sys sfmanm.sys sfsync02.sys sfsync03.sys sfvfs02.sys sptd.sys SPTD4621.SYS sr.sys srv.sys STREAM.SYS swenum.sys sysaudio.sys tcpip.sys TDI.SYS termdd.sys update.sys usbaudio.sys usbccgp.sys USBD.SYS usbehci.sys usbhub.sys USBPORT.SYS usbuhci.sys Vax347b.sys Vax347s.sys vbtenum.sys VComm.sys VcommMgr.sys vga.sys viaide.sys VIDEOPRT.SYS viaagp.sys viaagp1.sys VolSnap.sys wanarp.sys watchdog.sys wdmaud.sys win32k.sys WmBEnum.sys WMILIB.SYS WmXlCore.sys ################## Detailed Information of Device(s) ################## /////////////////////////////////////////////////////////////////////// (H:) HL-DT-ST DVDRAM GSA-4120B(0:1) detail information. /////////////////////////////////////////////////////////////////////// Vendor Identification: HL-DT-ST Product Identification: DVDRAM GSA-4120B Production Revision Level: A117 Location: atapi, Port 0, Bus 0, Target 1, Lun 0 Support recording method: DAO, RAW DAO(96), TAO, DVD DAO BURN-Free Technology: BURN-Proof Auto-Select best write speed: Not Supported -* Note: This information below is provided by the unit, it might be inaccurate. *- -* This software does not use this information! *- Removable media: Yes Version: ATAPI (INF-8090i/INF-8020i/INF-8028i) Response Data Format: 02h CD-R Read/Write: Yes/Yes CD-RW Read/Write: Yes/Yes Read CD-R Fixed Packet: Yes Test Write: Yes DVD-ROM Read: Yes DVD-R Read/Write: Yes/Yes DVD-RAM Read/Write: Yes/Yes Audio Play: Yes Composite Audio and Video Data Stream: No Digital output (IEC958) on port 1 Supported: No Digital output (IEC958) on port 2 Supported: No Mode 1 Form 2: Yes Mode 2 Form 2: Yes Multi-Session: Yes BUF: Yes CD-DA Commands supported: Yes CD-DA Stream is Accurate: Yes R-W Supported: No R-W De-interleaved and Corrected: No C2 Pointers Support: Yes ISRC Supported: Yes UPC Supported: Yes Read Bar Code: No Lock media into the drive: Yes Currently drive Lock state: Unlocked Prevent Jumper: No Eject Command: Yes Separate volume levels: Yes Separate channel mute: Yes Changer Supports Disc Present: No Software slot selection: No Side change capable: No P through W in Lead-In: Yes ####################################################################### ###################### Source Disc/Image Information ###################### Type: Standard ISO Image file Path: *************************\ Name: ***.iso Size: 4448.54 MB Session: 1 Track: 1 Session 01: Track 01: DVD, Length: 2277651(4.34 GB), Address: 000000 ############################################################################# ####################### Dumping/Recording Progress Log ####################### 14:11:05 Processor info: AMD Athlon XP 2200+ (1733MHz) 14:11:05 Memory Available to Windows: 1 310 192 KB 14:11:05 Memory Buffer size: 128 MB 14:11:05 Image file loading: E:\*************************\.iso 14:11:05 DVD Source Info: Session: 1, Track: 1, Length: 4.34 GB / 506:08:51 14:11:09 (H:) HL-DT-ST DVDRAM GSA-4120B(0:1): Recording Method/Speed 14:11:09 Recording - DVD DAO - 5.0X (6925 KB/Sec) (H:) HL-DT-ST DVDRAM GSA-4120B(0:1) - Media format: DVD-R 14:21:47 (H:) HL-DT-ST DVDRAM GSA-4120B(0:1) - [Write ERROR] LBA: 1652608, Length: 16 S:KEY - 04/09/01 - "Tracking Servo Failure" 14:21:47 (H:) HL-DT-ST DVDRAM GSA-4120B(0:1): Recording failed! 14:21:47 Error message: [04/09/01] - Tracking Servo Failure 14:21:47 (H:) HL-DT-ST DVDRAM GSA-4120B(0:1): Recording failed! 14:21:47 Image file loading aborted! 14:21:50 Something is wrong with the recording procedure! Please check the log file and report any errors to Technical Support. ############################################################################## Endret 31. mars 2006 av MeSs Lenke til kommentar
Psh Skrevet 31. mars 2006 Del Skrevet 31. mars 2006 Hvilken Mediacode har "That's Crap" platene dine? De skifter produsent ofte... Har du prøvd å brenne på noen kvalitets plater, for å sjekke om det funker? Lenke til kommentar
MeSs Skrevet 1. april 2006 Forfatter Del Skrevet 1. april 2006 Hvilken Mediacode har "That's Crap" platene dine? De skifter produsent ofte...Har du prøvd å brenne på noen kvalitets plater, for å sjekke om det funker? 5846177[/snapback] Haha! thats crap faktisk Jeg tror jeg har funnet feilen.. TROR.. Brant samme fila om igjen på alcohol 120% på MAX speed, istedenfor 5x.. Da gikk 2 plater, tester mer idag.. Hvor står mediacoden? Lenke til kommentar
Wipeout Skrevet 1. april 2006 Del Skrevet 1. april 2006 Hvilken Mediacode har "That's Crap" platene dine? De skifter produsent ofte...Har du prøvd å brenne på noen kvalitets plater, for å sjekke om det funker? 5846177[/snapback] Haha! thats crap faktisk Jeg tror jeg har funnet feilen.. TROR.. Brant samme fila om igjen på alcohol 120% på MAX speed, istedenfor 5x.. Da gikk 2 plater, tester mer idag.. Hvor står mediacoden? 5848057[/snapback] Du trenger et program som f.eks.dvdidentifier. Lenke til kommentar
charlie di meola Skrevet 1. april 2006 Del Skrevet 1. april 2006 sjekk om du har starforce drivere installert (ser du har noen sf*.sys som kan være starforce). de kan skape brenneproblemer med noen drev/oppsett. Lenke til kommentar
KVTL Skrevet 1. april 2006 Del Skrevet 1. april 2006 Prøv å kvitt deg med starforce, som du tydeligvis har. http://www.glop.org/starforce/remove.php Lenke til kommentar
MeSs Skrevet 1. april 2006 Forfatter Del Skrevet 1. april 2006 Prøv å kvitt deg med starforce, som du tydeligvis har. http://www.glop.org/starforce/remove.php 5850252[/snapback] jeg har jo spill som bruker starforce?... Som tilogmed er kjøpt Lenke til kommentar
KVTL Skrevet 1. april 2006 Del Skrevet 1. april 2006 Da burde du skaffe deg så mye informasjon som mulig at det er StarForce som gjør dette på systemet ditt. Masse beviser. Så reklamerer du ovenfor importør at du vil ha tilbake pengene eller få vekk StarForce. nekter de det så send inn en klage til forbrukerrådet. Du kan sikkert bare fjerne Starforce og brenne en kopi uten, men slikt er fy fy på boardet her. Lenke til kommentar
MeSs Skrevet 8. april 2006 Forfatter Del Skrevet 8. april 2006 Da burde du skaffe deg så mye informasjon som mulig at det er StarForce som gjør dette på systemet ditt. Masse beviser. Så reklamerer du ovenfor importør at du vil ha tilbake pengene eller få vekk StarForce. nekter de det så send inn en klage til forbrukerrådet. Du kan sikkert bare fjerne Starforce og brenne en kopi uten, men slikt er fy fy på boardet her. 5850462[/snapback] hvordan?? Mvh Marius Lenke til kommentar
