OV-103 Skrevet 22. mars 2006 Del Skrevet 22. mars 2006 (endret) Prøver å kompilere uw-imap (2004g) på et trustix 3.0 system, men får følgende feil: make[2]: Entering directory `/usr/local/imap-2004g/mtest' `cat ../c-client/CCTYPE` -I../c-client `cat ../c-client/CFLAGS` -c -o mtest.o mtest.c `cat ../c-client/CCTYPE` -I../c-client `cat ../c-client/CFLAGS` -o mtest mtest.o ../c-client/c-client.a `cat ../c-client/LDFLAGS` ../c-client/c-client.a(osdep.o)(.text+0x9369): In function `ssl_onceonlyinit': /usr/local/imap-2004g/c-client/osdep.c:268: warning: the use of `tmpnam' is dangerous, better use `mkstemp' mtest.o(.text+0x1882): In function `smtptest': /usr/local/imap-2004g/mtest/mtest.c:773: warning: the `gets' function is dangerous and should not be used. ../c-client/c-client.a(osdep.o)(.text+0x84df): In function `checkpw': /usr/local/imap-2004g/c-client/osdep.c:119: undefined reference to `crypt' ../c-client/c-client.a(osdep.o)(.text+0x85a5):/usr/local/imap-2004g/c-client/osdep.c:101: undefined reference to `crypt' /usr/local/ssl/lib/libcrypto.a(dso_dlfcn.o)(.text+0x3e): In function `dlfcn_load': : undefined reference to `dlopen' /usr/local/ssl/lib/libcrypto.a(dso_dlfcn.o)(.text+0xab): In function `dlfcn_load': : undefined reference to `dlclose' /usr/local/ssl/lib/libcrypto.a(dso_dlfcn.o)(.text+0xd4): In function `dlfcn_load': : undefined reference to `dlerror' /usr/local/ssl/lib/libcrypto.a(dso_dlfcn.o)(.text+0x14b): In function `dlfcn_unload': : undefined reference to `dlclose' /usr/local/ssl/lib/libcrypto.a(dso_dlfcn.o)(.text+0x20b): In function `dlfcn_bind_var': : undefined reference to `dlsym' /usr/local/ssl/lib/libcrypto.a(dso_dlfcn.o)(.text+0x257): In function `dlfcn_bind_var': : undefined reference to `dlerror' /usr/local/ssl/lib/libcrypto.a(dso_dlfcn.o)(.text+0x2fb): In function `dlfcn_bind_func': : undefined reference to `dlsym' /usr/local/ssl/lib/libcrypto.a(dso_dlfcn.o)(.text+0x347): In function `dlfcn_bind_func': : undefined reference to `dlerror' collect2: ld returned 1 exit status make[2]: *** [mtest] Error 1 make[2]: Leaving directory `/usr/local/imap-2004g/mtest' make[1]: *** [bundled] Error 2 make[1]: Leaving directory `/usr/local/imap-2004g' make: *** [sl5] Error 2 Har søkt på nettet som en gal, men klarer ikke å finne ut hva som er galt. Er det noen glupe hoder her som kan hjelpe? Endret 23. mars 2006 av e_urkedal Lenke til kommentar
OV-103 Skrevet 23. mars 2006 Forfatter Del Skrevet 23. mars 2006 Fant ut at det var pga. noe openssl problemer. Lenke til kommentar
