Fre_ZZe Skrevet 17. mars 2006 Del Skrevet 17. mars 2006 (endret) Hey! Trur Cpu'en min er flaskehals i systemet når det gjelder spilling. Er blir avhengig av trackmania osv og trenger flere frames! I korte trekk har eg følgende hardware: EPOX-8KHA+ HK Athlon XP 2100 1733Mhz 1024 MB DDR PC2100 Club3D Geforce 6800NU 128mb 16P, 1.6VP. Vil eg merke 'signifikant' forskjell ved å bytte ut Athlon Xp thoroughbred prosessoren med en Athlon XP Barton ?? - Takker for innspill! Detaljer om nåverende minne, hk, cpu kan dere lese her: Number of CPUs 1 Name AMD Athlon XP Code name Thoroughbred Specification Unknow CPU Type Family/Model/Stepping 681 Extended Family/Model 7/8 Package Socket A Core Stepping B0 Technology 0.13um Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE Features Clock Speed 1737.3 MHz Clock multiplier x13.0 Front Side Bus Frequency 133.6 MHz Bus Speed 267.3 MHz L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size L2 Cache 256 KBytes, 16-way set associative, 64 Bytes line size L2 Speed 1737.3 MHz (Full) L2 Location On Chip L2 Data Prefetch Logic yes L2 Bus Width 64 bits Chipset ------------------------------------------------------------------------------ Northbridge VIA KT266/333 rev. 00 Southbridge VIA VT8233 rev. 00 Graphic Interface AGP AGP Revision 3.0 AGP Transfert Rate 4x AGP SBA supported, enabled Memory Type DDR Memory Size 1024 MBytes Memory Frequency 133.6 MHz (1:1) DRAM Interleave 4-way CAS# 2.5 RAS# to CAS# 3 RAS# Precharge 3 Cycle Time (tRAS) 6 Memory SPD ------------------------------------------------------------------------------ DIMM #1 General Memory type DDR-SDRAM Manufacturer (ID) (0000000000000000) Size 512 MBytes Max bandwidth PC2100 (133 MHz) DIMM #2 General Memory type DDR-SDRAM Manufacturer (ID) (0000000000000000) Size 512 MBytes Max bandwidth PC3200 (200 MHz) Endret 17. mars 2006 av Fre_ZZe Lenke til kommentar
efikkan Skrevet 17. mars 2006 Del Skrevet 17. mars 2006 Jeg tror ikke det vil utgjøre den store forskjellen. Spar litt mer og kjøp en AMD64. Lenke til kommentar
Fre_ZZe Skrevet 17. mars 2006 Forfatter Del Skrevet 17. mars 2006 (endret) Jeg tror ikke det vil utgjøre den store forskjellen. Spar litt mer og kjøp en AMD64. 5770755[/snapback] Jeg kan vel ikke bruke AMD64 på mitt HK ? Med andre ord må eg bytte ut heile røkkla og det blir ALT for dyrt Eller.. ? Forøvrig tror jeg det vil bli litt forskjell fra min prosessor til en Barton. Barton har tross alt 333Mhz FSB og L2 Cache 512kb. Min kjiiiiipe cpu har 266Mhz FSB og L2 Cache 256kb. Men om dette har noe faktisk effekt på mitt system vet jeg ikke ? Endret 17. mars 2006 av Fre_ZZe Lenke til kommentar
efikkan Skrevet 17. mars 2006 Del Skrevet 17. mars 2006 Jeg tror ikke det vil utgjøre den store forskjellen. Spar litt mer og kjøp en AMD64. 5770755[/snapback] Jeg kan vel ikke bruke AMD64 på mitt HK ? Med andre ord må eg bytte ut heile røkkla og det blir ALT for dyrt Eller.. ? Forøvrig tror jeg det vil bli litt forskjell fra min prosessor til en Barton. Barton har tross alt 333Mhz FSB og L2 Cache 512kb. Min kjiiiiipe cpu har 266Mhz FSB og L2 Cache 256kb. Men om dette har noe faktisk effekt på mitt system vet jeg ikke ? 5770780[/snapback] Litt forskjell vil det bli, men minimalt. Bytter du til AMD64 må du også bytte hovedkort og bør bytte minne. Lenke til kommentar
Jarmo Skrevet 18. mars 2006 Del Skrevet 18. mars 2006 VIA KT266A brikkesett støtter ikke Barton så det så... Lenke til kommentar
Fre_ZZe Skrevet 18. mars 2006 Forfatter Del Skrevet 18. mars 2006 VIA KT266A brikkesett støtter ikke Barton så det så... 5771278[/snapback] Huff! Sikker ? Lenke til kommentar
Jarmo Skrevet 18. mars 2006 Del Skrevet 18. mars 2006 VIA KT266A brikkesett støtter ikke Barton så det så... 5771278[/snapback] Huff! Sikker ? 5771285[/snapback] Dette kortet du har eller ? http://www.pcstats.com/articleview.cfm?articleID=887 Lenke til kommentar
Fre_ZZe Skrevet 18. mars 2006 Forfatter Del Skrevet 18. mars 2006 VIA KT266A brikkesett støtter ikke Barton så det så... 5771278[/snapback] Huff! Sikker ? 5771285[/snapback] Dette kortet du har eller ? http://www.pcstats.com/articleview.cfm?articleID=887 5771290[/snapback] Jepp, er akkurat det der. Lenke til kommentar
Jarmo Skrevet 18. mars 2006 Del Skrevet 18. mars 2006 Vel ! Du skal få noen gode råd i morgen, lalla sova nå... Lenke til kommentar
Fre_ZZe Skrevet 18. mars 2006 Forfatter Del Skrevet 18. mars 2006 Vel ! Du skal få noen gode råd i morgen, lalla sova nå... 5771472[/snapback] Takker for det! Kan forøvrig nevne at jeg har tilbud om en amd athlon 2800+ barton socket A til kr 600. Synes det er heilt ok pris om eg får litt bedre ytelse, og det tror jeg at jeg vil få. Om hovedkortet støtter Barton då ? Leste noe om at en Bios upgrade kunne fikse det slik at jeg kunne kjøre barton... ? Lenke til kommentar
Sweet Skrevet 18. mars 2006 Del Skrevet 18. mars 2006 Tingen er heller det at barton over 2500+ kjører på 400FSB. (200DDR) og ditt kort, VIA KT333 bare støtter 333MHZ fsb med andre ord du vil få samme eller dårligere ytelse, ved at CPU blir underklokket, snakker av erfaring. Derimot en ting som kan gjøre litt forskjell er at Barton har 512KB L2 cache, i forhold til Throughbred-B som har 256 Men jeg mener du kan kjøre en 2500+ barton, som har 333FSB på ditt kort. Men du hadde vel kanskje tjent mer på å kjøpre nytt kort , f.eks Abit NF-7 (S) V2.0 som har støtte for både S-ATA og 400FSB. Mvh Sweet. : Lenke til kommentar
Sweet Skrevet 18. mars 2006 Del Skrevet 18. mars 2006 Oi.. leste litt nærmere om det HK ditt, ser at det er VIA KT266A og ikke KT333. Da ville jeg heller anbefalt deg å kjøpe ett nytt kort som støtter 333FSB for den prosessoren du skal kjøpe. Eventuelt kan du få kjøpe et Shuttle AK35GTR/2 selv om det ikke er det beste i verden. Men støtter opptil PC2700 DDR ram, 4GB, 5PCI portet, 1AGP 4X og Socket A opptil 333FSB. Altså, ikke det beste avdet beste Lenke til kommentar
Jarmo Skrevet 18. mars 2006 Del Skrevet 18. mars 2006 (endret) Her er redningen din: DIMM #2 General Memory type DDR-SDRAM Manufacturer (ID) (0000000000000000) Size 512 MBytes Max bandwidth PC3200 (200 MHz) Så dette vil jeg anbafale for deg hvis du har lite med kroner akkurat nå: Lagersalg hos psdata.no for 220,- http://www.psdata.no/ps.asp?it=113038&mlevel= http://www.psdata.no/ps.asp?it=101881&mlevel=011001 Så kjøper du den der 2800+ Barton for 600,- delene dine selger du på QXL for høyeste bud eller sender en PM til meg.. (Skal ha en filserver) Endret 18. mars 2006 av jarmo Lenke til kommentar
svenil73 Skrevet 18. mars 2006 Del Skrevet 18. mars 2006 Tingen er heller det at barton over 2500+ kjører på 400FSB. (200DDR) og ditt kort, VIA KT333 bare støtter 333MHZ fsb 5772808[/snapback] Det stemmer ikke helt.. Du får Athlon opp til 3200+ med 333fsb.. Lenke til kommentar
Jarmo Skrevet 18. mars 2006 Del Skrevet 18. mars 2006 Tingen er heller det at barton over 2500+ kjører på 400FSB. (200DDR) og ditt kort, VIA KT333 bare støtter 333MHZ fsb 5772808[/snapback] Det stemmer ikke helt.. Du får Athlon opp til 3200+ med 333fsb.. 5774573[/snapback] Og så retter vi opp en del feil, XP 3200+ er levert med 200/400 som default. http://www.thedigerati.us/info/amdcpuchart.html#xp Lenke til kommentar
Sweet Skrevet 18. mars 2006 Del Skrevet 18. mars 2006 (endret) Tingen er heller det at barton over 2500+ kjører på 400FSB. (200DDR) og ditt kort, VIA KT333 bare støtter 333MHZ fsb 5772808[/snapback] Det stemmer ikke helt.. Du får Athlon opp til 3200+ med 333fsb.. 5774573[/snapback] Og så retter vi opp en del feil, XP 3200+ er levert med 200/400 som default. http://www.thedigerati.us/info/amdcpuchart.html#xp 5774657[/snapback] Joda .. men ettersom kortet hans bare støtter 133FSB så vil vel han ikke få utnyttet en 400/333 CPU fullt ut.. EDIT: tyrkleif Endret 18. mars 2006 av Sweet Lenke til kommentar
kremt Skrevet 19. mars 2006 Del Skrevet 19. mars 2006 Kan nesten sikkert klokke den opp til 400 FSB, selv om det egentlig ikke er støttet, går det fint å justere opp til den hastigheten på de fleste kort. Lenke til kommentar
Sweet Skrevet 19. mars 2006 Del Skrevet 19. mars 2006 funket ikke på de to VIA kortene jeg har hatt. KT266A og KT333. Svart skjerm på 333 og 400FSB. Lenke til kommentar
X-Fiesta Skrevet 19. mars 2006 Del Skrevet 19. mars 2006 Kan nesten sikkert klokke den opp til 400 FSB, selv om det egentlig ikke er støttet, går det fint å justere opp til den hastigheten på de fleste kort. 5776734[/snapback] IKKE særlig smart på VIA KT266 og KT333, da de ikke har støtte for låsing av PCI- og AGP-bussen til faste frekvenser, og overklokker disse i takt med FSB! Dette fører raskt til ustabilitet, og ofte til skade på hardware, som skjermkort, lydkort og harddisker. Lenke til kommentar
Tokse Skrevet 24. mars 2006 Del Skrevet 24. mars 2006 Det beste du kan ha av cpu som er anbefalt for hk er vel AMD xp 2600+, 266 FSB, 2133 Mhz. Vil kanskje ikke gjøre allverden av forskjell, men.. Lenke til kommentar
