Nye 9700Pro Drivers Ute nå.
b-real
http://www.ati.com/support/infobase/4081.html
[*]replace the 3D driver patch that was posted as a workaround to the problem described here
[*]are Microsoft Certified on Windows XP, Windows 2000 and Windows Millenium for RADEON 9700 Series graphics adapters
[*]are internal version 7.77-020911x1-005863C-ATI
[*]include ATI Advanced Control Panels
[*]includes support for all languages
Ved Sharkfood:
For those questioning desperately the changes in this driver... the description at ATI describes what this driver is.
It appears (for XP and 2K at least), if you have the previous drivers plus D3D patch released a few weeks ago properly installed, this driver offers nothing over this. It's just the drivers, plus D3D patch plus the control panel all in one convenient form. Nothing new here to "fix" anything that I can tell.
Performing file version checks-
The Direct3D DLL in the D3D Patch- 6.13.10.0126
The Direct3D DLL in these 6178s - 6.13.10.0126
OpenGL DLL in the 6166s - 6.13.3344
OpenGL DLL in the 6178s - 6.13.3344
As the Direct3D and OpenGL files havent changed, as well as the driver description, this is just a single and convenient bundling of what most 9700 Pro owners already have.
So I wouldn't expect improvements in performance, any new issues fixed or other such expectations.. unless of course your drivers are improperly installed now and this single bundle manages to set this straight somehow.
http://www.rage3d.com/board/showthread.php...05&pagenumber=6
[ Denne Melding var redigert av: Robin B på 2002-09-24 20:06 ]
His du har muligheten så øk Agp spenningen fra 1,5 til 1,6v.Det har løst problemet for flere.
Hvis du har SP1 installert så fjern den ved legge til fjern programmer og installere driverne på nytt.
Klarte ikke selv å få kortet stabilt før jeg fjernet XP SP1.My problems was gone.
