Xbox 360's Firmware Hacked
gadd ikke se videoen men, det er jo uhyre enkelt og forfalske det der da. en annen 360 kjørende koblet til i en inngang bak tv'n f.eks..
edit: så videoen nå, kan ikke si at jeg er overbevist. viser jo ingenting egentlig.. en åpen 360 med en brent plate som surrer rundt og en tv som viser PGR.. de må nok dokumentere det bedre skal jeg tro på dette.
Endret av phax
direktelink til film? er lat og har hakket for høy promille til og finlese den siden der. :wee:
5775282[/snapback]
her:
http://www.youtube.com/watch?v=XyZQ4k7Bi-8
What is this? A bit more info...
The hack is a modified firmware of the Xbox 360 Hitachi-LG GDR-3120L DVD-ROM drive (the security in the Toshiba/Samsung TS-H943 is said to be similar, so it's probably also possible with this drive ... but it does require it's own hacked firmware of course).
As you (should) know, all Xbox 360 executables (XEX files) are signed by Microsoft (with a private key only MS has). This means that if you try to change anything to the XEX file, the signature will be wrong and the file will not boot.
Now ... to protect from booting an exact copy of a game from a DVD-R or other recordable media, microsoft gave each XEX file a 'mediaflag'. This mediaflag tells the Xbox 360 from which media (cd-r, dvd-r, dvd+r, dvd-rw, hdd, dvdxbox, dvdxbox360, ...) the XEX is allowed to boot. Changing this mediaflag in the XEX header is not an option as it'll break the signature of the file (see above), so ... what's done in this firmware hack is 'break' the detection of the disc.
Retail games usually get a mediaflag where they only allow 'dvdxbox360' (Xbox 360 discs - different than a normal DVD because it has some specific bad sectors and special info in lead-in/out that can't be written with a standard dvd burner). The modified firmware will trick the DVD drive into reporting a DVD-R (or other) as a DVDXBOX360 to the Xbox 360.
How can you do this?
Well, right now you can't. The firmware has not been released to the public because it would mostly be used for piracy for homebrew and linux fun) and that's not what this team wants (unlike the original Xbox hack this can't be used (atleast not directly). But the research done by these guys is public as you can read their discussions of the last few months on the xboxhacker.net forums, so people with good assembly experience should be able to duplicate this hack.
If the firmware was released, what would it mean?
Right now the Xbox 360 DVD firmware can't be flashed via PC, because there's no software to do this. Of course, drivers and flashing software for Xbox360 DVD drives could probably be written (and some people have been working on this), but so far this has not been done (atleast not publicly).
So, that means you'd have to open your Xbox 360, open your DVD drive and desolder the chip where the firmware is stored on.
Each Xbox 360 DVD drive has a unique key, if that key doesn't match what your console is expecting your DVD drive will not work.
So next you will need to read your current firmware chip with special hardware (flash programmer), to find your unique DVD 16 byte key (stored at 0x4F00). Then you'll have to insert this key in the modified firmware (or patch your original firmware) and program this modified firmware back on the firmware chip. Then put the firmware chip back in the drive, close DVD drive and Xbox 360 and I guess you're done.
As said above the hack would allow you to run MS-signed and unmodified XEX files only, so that also means the game must be of right region (as changing the regionflag in the XEX header would break the signature). Unsigned, homebrew executables would of course not work, again because signature check would fail.
LIVE and Updates ...
Could you go on LIVE with this? Well the firmware isn't released, so noone can try, but I'd guess it would work yes. The Xbox 360 is fully in normal state, nothing is modified to the Xbox 360 itself, it just gets 'wrong' info from the DVD drive. Of course if you start modifying non-signed files (like textures, ini files, ...) in order to cheat or so MS could easily check for that.
Can Microsoft stop this firmware hack with forced LIVE updates? They could probably try detect a basic modified DVD firmware, but anything the Xbox 360 asks to the DVD drive goes via the DVD firmware, and if the firmware is 'open' in the hands of the hackers the firmware can probably each time be modified again to give the reply to the console expects. Microsoft could maybe do more with a HW security update ... but I'll let them analyse that.
(Note that all info above is based on all stuff I read ... if I made any mistakes, let me know)
(This news post will be updated often with more info/details, so keep checking if you're interested)
Endret av kewell79
Må bare si at allerede i denne tråden er det folk som jeg refererte til "idioter" i første post. Det er da vel ingen på denne gjord som lager et produkt for at det skal stjeles(da snakker jeg om produkter som er en betalende lisens)? Hadde dere likt at noen hadde stjelt deres produkt så at dere ikke hadde tjent noe på det? Jesus!
Og har ikke råd. BS!! "Har ikke råd til en bil, så jeg like godt stjeler den" eller "Trenger et nytt bopell, så jeg tar vel bare å bryter meg inn og lever livet". Wake up! Slik er ikke hvordan man kommer igjen livet!
5776981[/snapback]
Er det noen som er idiot her så er det deg. Det går ikke ann å sammenligne det å kopiere et spill med å stjele en bil :nei:
Hvis du hadde valget mellom å kjøpe en vanlig xbox 360 og en stabil og godt moddet xbox 360 som kunne spille av backupspill, mulighet for større HD, mulighet til å streame video uten mediacenter osv. Hva ville du ha valgt sett at du måtte betale 500 kr mer for sistnevne?
5776981[/snapback]
Ja om det er din mening så greit nok, men ad regner jeg med at du heller ikke har en piratkopiert sang, en piratkopiert film, et piratkopiert program, et piraktkopiert spill, et bilde du ikke eier rettighetene på osv osv på pc'n din? isåfall er jo det dobbeltmoral av høyest grad.
Men jeg skjønner ikke helt hvordan du kan kalle disse folkene for idioter.. Er du imot all teknologi som kan brukes til piratkopiering kanskje? du hadde vel helst sett at mp3 formatet eller mp3 spillere ikke fantes, at cd/dvd brennere ikke var tilgjengelig for allmennheten, at internett ikke eksisterte osv. De "idiotene" som har utviklet alt dette gjør jo at musikkbransjen, filmbransjen, spillbransjen, etc etc "ikke tjener penger på produktene sine" stakkars.. :cry:
Hacket er "bekreftet" av blant annet Team Xecuter og andre tungvektere innen moddemiljøet(er det ett ord?)... Så det er nok rimelig god sannsynlighet for at dette er ekte.
Info om hvordan hacket er utført ligger også ute på xboxhacker så det er ikke noe problem for folk med rett kunnskap og utstyr å få sjekket/replikert dette hacket.
Det er så vidt jeg har lest ingen av de som virkelig har peiling på dette som betviler ektheten i hacket heller.
Bare det at Team Xecuter gratulerer han som har gjort dette er bevis nok for de fleste.
Selve videoen er jo mest lagt ut for å vise det i aksjon, så lenge oppskriften ligger ute i mer eller mindre klartekst er det jo bare for folk å sjekke om det er sant eller ikke.
Uansett morsomt å se at det er progresjon i hackingen av 360! Jeg sugler nemlig meget etter en framtidig mulighet for Xbmc360 :dribble:
Synes dette er lovende!
Kjøpte selv xbox når det begynte å komme noen gode chipper.
Xbox (1) er jo helt genial når den er modda. Tenker da på xbmc, og andre programmer. Mulighetene er så utrolig mange. Nettopp på grunn av at konsollen er moddet har denne maskinen gitt meg utrolig mye glede for de kronene jeg ga for den.
Xbox360 har dog fått mye mer funksjonalitet enn den orginale xboxen, men jeg ser fortsatt at konsollen ikke er utnyttet maks. Når gode chipper begyner å komme, vil det også poppe opp software i hytt og pine. Dette er en god ting!
At spilleren også vil kunne spille brente spill er bare en bonus. For meg er det fremtidig software som er mest interessant.
Endret av Menkromsen
5776981[/snapback]
5777041[/snapback]
For meg så er du langt ute å kjører nå.
Ingen har vel nevnt eller antydet at de ikke liker at mp3, cd/dvd brennere eller at internett eksisterer!?
Og tror heller ingen har antydet at de er imot all teknologi!?
Og jeg regner med du klarer å se stor forskjell på de som har sneket til seg et par sanger ulovlig, og de som KUN piratkopierer - enten det er filmer, spill, musikk eller whatnot!?
Ja det er fett, kult, billigere og bedre å kopiere spill/filmer/musikk osv,
men det er alikevel ikke lovlig for det. Og dobbeltmoral eller ikke - piratkopiering er ikke lovlig.
Jeg tror desverre at mange shitkids i dag har problemer med å se det kriminelle i å piratkopiere,
rett og slett fordi de ikke har noe erfaring innen business. Hvis jeg sier "Hva om du prøver å selge din ubrukte Xbox360, men så stjeler jeg den i stedet" Sier du da; "Ja greit!, jeg er FOR stjeling av andres produkter så bare ta den" eller forstår man at stjeling ikke er lov, enten man blir merket eller ikke!?
Om man ikke har råd, så har man ikke råd.. kanskje på tide å vokse opp - eller skaffe seg jobb.
Mentaliteten "det er greit å stjele" er jo helt på tryne spør du meg..
Endret av talgmar
5782158[/snapback]
Han kaller de som utvikler modchips o.l for idioter, da regner jeg med at han er imot all utvikling av teknologi som kan brukes til piratkopiering ettersom det nettopp er dette modchip/360 hack dreier seg om.
5782158[/snapback]
Ok, så det er mengden det kommer ann på. ok ja da skjønner jeg. Hvor mange megabyte må det til før det går fra og være helt ok til idiotisk?
5782158[/snapback]
Har jeg sagt noe som helst om at det er greit og stjele/piratkopiere?
5782158[/snapback]
Har jobb, voksen nok, og synes fortsatt det ikke er greit og stjele. Men jeg synes derimot at det er greit og utvikle slike teknologier som også kan brukes til piratkopiering. som f.eks modchips, cd brennere, internett osv osv.
Har sett denne video'en og må si jeg ikke er overbevist (husker da Gamecube ble fake-hacket på samme vis). Det jeg merket på video'en er at de aldri har kamera helt til venstre for kabelen som går inn i TV'en. Det er alltid en liten del som stikker utenfor kamera. Der er det fullstendig mulighet for å ha dyttet en annen xbox under bordet for så å slå på samtidig (Jeg vet jeg er skeptiker, men skal mer enn en liten videosnutt til for at dette overbeviser meg).
En annen ting er at de har koblet denne i front på TV'en. En TV har scart bak den. Kan være en annen xbox koblet til bak og så bare valgt den som video inntak på TV'en.
MEN! Om jeg får en videosnutt hvor de viser xbox konsollen, og viser kabelen og TV'en forann og bak og kjører opp denne så kan jeg tro det mer. Men denne video'en overbeviser ikke meg.
