Teller bilder hentet fra en hjemmeside som visits?
Jeg har noen bilder på hjemmesiden min som brukes blant annet på dette forumet. Min forrige avatar for eksempel. (som jeg måtte bytte fordi samboer ikke likte David Hasselhoff naken med valper på fanget, hørt sånt!)
Nå ser jeg på webalizer at det har kommet en del hits/visits ekstra på siden min i det siste. Men teller en link til et bilde på mitt domene som en visit eller hit?
http://www.mrunix.net/webalizer/faq.html
. What is the difference between 'HITS' and 'FILES'?
There is an on-line quick help that explains most of the major terms and headings used in the reports. Basically, HITS is the total number of HTTP requests that the server received during the reporting period. Any request made to the server is considered a hit. FILES is the number of hits that actually resulted in something being sent back to the user, such as an HTML page or image. 'Total Files' and '200 - OK' totals should be the same. If you add up the totals in the 'Hits by Response Code' section, it should be the same as the 'Total Hits' figure. For a complete description of what all the numbers mean in the output, see the README file, which is supplied in all distributions and available from our ftp site. There is also an Webalizer Quick Help document on-line that explains the most common terms used in the reports.
Endret av joltaire
Der var det mye interresant lesning.
Fant også denne som besvarer mitt spørsmål godt:
Why do my reports show more Sites than Visits?
Visits are only triggered when a valid request is found for a page, as defined by your PageType setting (or a URL that ends with a slash, which is also considered a page type). Sites however, are counted regardless of the request type. It is very common to have more sites than visits, particularly if you host non-pagetype URLs on your site that are linked to from the outside. If you are not hosting URLs that are linked to from outside sites, then make sure your PageType setting is correct. The default is .htm, .html and .cgi extensions, unless you specify otherwise.
Med andre ord. Bilder blir ikke telt som visits, hvis ikke dette er satt som gyldig filetype.
Endret av XmasB
