b-real Skrevet 23. september 2002 Del Skrevet 23. september 2002 Jeg fant denne guiden...hvis noen trenger den... Quote: You can hold down the Shift key when you insert the disc to prevent autoplay (or autorun for that matter).If you want to do it permanently you have to edit the group policies. Do this:Start->Rungpedit.mscExpand Computer ConfigurationExpand Administrative TemplateClick on SystemDouble click Disable AutoplayYou should be able to enable/disable it there.If that doesn't do it there are some registry entries that should do it too. Lenke til kommentar https://www.diskusjon.no/topic/55038-disable-autoplay-guid/
