Rate og cl_updaterate i CS..
Jauda, gjorde det søket, fant dette:
http://www.planethardware.com/features/twe...ak/index5.shtml
Quote:
The next set of tweaks have to do with how much data the server is sending to your machine across your 'net connection. First up is 'cl_updaterate', which tells the server how many updates to send per second to your machine. Modem users will want to set this somewhere between 15-25, while the default is 20. Broadband users can bump this up to 25-40 in order to ensure smooth play - though decrease this setting if you are playing on servers that are heavily populated.
Og enda mer :smile:
Quote:
'cl_cmdrate' is the opposite of updaterate, it tells your machine how many updates to send to the server per second. The default is 30 here, which modem users will want to keep. Broadband users might want to bump this up to the 40-50 range though.
Og det du nevnte spesifikt:
Quote:
The last setting in this grouping that we want to cover is the 'rate' command. This tells Half Life exactly how much data it should be trying to download from the server at any given time, which is extremely important. This setting might have to be changed on the fly depending on how bandwidth fluctuations and the like, so keep this one in mind if you're experiencing in game lag - often times a quick change makes a big difference. Modem users will want to set their rate in the 2,500-4,000 range, broadband anywhere from the 4,000-20,000(for T1 size lines) depending on the quality of your line. Obviously 256kbps DSL users will want to aim lower than T1 users. For broadband users we recommend setting this to between 7000 and 10,000.
Sånn, fornøyd? ;P
Et enkelt google søk og du hadde spart MYE tid!
Whatever :smile:
Gjest Slettet+1374861
ikke glemme å sette 'cl_rate' til samme som 'rate' da. ofte en glemt kommando.
btw, jeg får best resultat ved å gjøre noe så enkelt som å gå inn på "play online" og velge "T3/LAN" eller hva det nederste valget heter. faktisk minst loss/choke og ping. ;)
interp er slemmt!
Viss du skulle finne deg til å spille på en server som ikke har en så altfor bra og stabil linje så kan det å sette cl_updaterate ned til så lite som 10 hjelpe på ganske bra... er ingen tweakmester nåe det kommer til CS men gikk ifra 60 i choke til 15 på en server og oppdaget generellt en nedgang i choke og loss på dårlige servere, men som sagt... er serveren ustabil så finn en annen å spille på!
cl_cmdrate kan settes opp til 101 for folk med gode linjer som SDSL evt også 2mbit NGT eller liknende. Det samme gjelder cl_updaterate.
For å tweake connection korrekt:
1: Still rate så høyt som mulig opp mot 25000 uten at du får pingjumps, pl/choke eller liknende irriterende bi-effekter.
2: Still cmdrate gradvis oppover mot max lowFPSn din. Hvis du har 99 FPS stabilt sett cmdrate til 101, har du 70-99 sett den til 70 etc. Det viktigste er at du IKKE får packetloss eller choke.
3: Updaterate, still den opp mot 101 uten å få choke/pl.
Jeg f, eks på min SDSL kjører 25000/101/101 så lenge det ikke er på 32 player servere.
  • 10 måneder senere...
interp er slemmt!
cl_rate og rate er ikke det samme. cl_rate har en maxverdi på 20000, mens rate 25000
over til topic: med den linja kan du kjøre cpl.cfg, dvs. rate 25000, cl_cmdrate 101 og cl_updaterate 101
