Hvordan laste ned fler enn 2 filer samtidig?
Gjest Slettet+127836
Som tittelen antyder vil jeg veldig gjerne laste ned mer enn 2 filer samtidig. explorer er litt kjedelig akkurat der. mener å huske det var noe jeg kunne gjøre for å fikse det, men husker ikke hva.
På forhånd takk for svar.
Hmm. Hvis du ikke har noe konstruktivt å komme med, så kan du vel heller la være? til din informasjon bruker jeg både opera og IE sammen. det er en kombinasjon jeg er fornøyd med.
http://www.amset.info/tips/internet-explorer.asp
Increase the Download Limit
You may have noticed that Internet Explorer only allows you to download up to two files at any one time with others waiting to start. Whilst this is adequate when you are on a dial up connection, if you are lucky enough to be on broadband, you may want to download more than two things at once.
Fortunately, this limit can be changed by modifying the registry which will increase your limit to a maximum of 10 connections.
As this tip requires a registry change, please see the registry disclaimer at the bottom of the page.
To change Internet Explorer to allow up to the maximum of 10 simultaneous connections, make the following change:
In the following key in the registry:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings
Add the following Registry Values as type DWORD:
DWORD Name:"MaxConnectionsPer1_0Server" Value: 0000000a
DWORD Name:"MaxConnectionsPerServer" Value:0000000a
After entering, you should see (10) after each new entry.
