error når jeg starter Americas Army
instalerte americas army nå nettop og skulle start det, men det bare quitet og jeg fikk en denne feilmeldingen:
Xlib: connection to ":0.0" refused by server
Xlib: No protocol specified
No dynamic GL support in video driver
History:
Exiting due to error
noen ider om hva jeg må gjøre?
edit:
får denne når jeg prøver å start RTCW:ET
Error couldn't open the X display
...WARNING: could not set the given mode (4)
Initializing OpenGL display
...setting mode 3: 640 480
...WARNING: could not set the given mode (3)
----- CL_Shutdown -----
RE_Shutdown( 1 )
Sys_Error: GLimp_Init() - could not load OpenGL subsystem
Endret av Tob2k
lå inn nyeste ati driver nå, testet med glxgears får 300 fps så openglen virker litt, men i aa derimot kommer jeg ikke inn på det og får opp:
tob@localhost:~$ armyops
Xlib:  extension "XFree86-DRI" missing on display ":0.0".
GL_EXT_bgra not supported - bailing out.
History:
Endret av Tob2k
name of display: :0.0
display: :0  screen: 0
direct rendering: No
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
    GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
    GLX_EXT_import_context, GLX_OML_swap_method, GLX_SGI_make_current_read,
    GLX_SGIS_multisample, GLX_SGIX_fbconfig
client glx vendor string: ATI
client glx version string: 1.3
client glx extensions:
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context,
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_ATI_pixel_format_float,
    GLX_ATI_render_texture
GLX extensions:
    GLX_ARB_multisample
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.2 (1.5 Mesa 6.2.1)
OpenGL extensions:
    GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_texture_border_clamp,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
    GL_ARB_transpose_matrix, GL_EXT_abgr, GL_EXT_blend_color,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_lod_bias
glu version: 1.3
glu extensions:
    GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
   visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x23 16 tc  0 16  0 r  y  .  5  6  5  0  0 16  0  0  0  0  0  1 0 None
0x24 16 tc  0 16  0 r  y  .  5  6  5  0  0 16  8 16 16 16  0  1 0 None
0x25 16 tc  0 24  0 r  y  .  5  6  5  8  0 16  8 16 16 16 16  1 0 None
0x26 16 tc  0 24  0 r  .  .  5  6  5  8  0 16  8 16 16 16 16  1 0 None
0x27 16 dc  0 16  0 r  y  .  5  6  5  0  0 16  0  0  0  0  0  1 0 None
0x28 16 dc  0 16  0 r  y  .  5  6  5  0  0 16  8 16 16 16  0  1 0 None
0x29 16 dc  0 24  0 r  y  .  5  6  5  8  0 16  8 16 16 16 16  1 0 None
0x2a 16 dc  0 24  0 r  .  .  5  6  5  8  0 16  8 16 16 16 16  1 0 None
edit: prøvde å sette opp xorgconfig på nytt.... men da vil ikke x starte, og den bare henger seg ved oppstart når den skal starte x :hrm: finnes det noe "safemode" elns så jeg kan få fikset det?
Endret av Tob2k
du har nok ikke fått satt opp driverene til grafikkortet riktig.
oss meg funker opengl og glxinfo gir denne outputten:
direct rendering: Yes
GLX version: 1.2
GLX extensions:
   GLX_ARB_multisample
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: MOBILITY RADEON 9700 Generic
OpenGL version string: 2.0.5582 (8.21.7)
OpenGL extensions:
   GL_ARB_multitexture, GL_EXT_texture_env_add, GL_EXT_compiled_vertex_array,
   GL_S3_s3tc, GL_ARB_depth_texture, GL_ARB_fragment_program,
   GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
   GL_ARB_multisample, GL_ARB_occlusion_query, GL_ARB_point_parameters,
   GL_ARB_point_sprite, GL_ARB_shader_objects, GL_ARB_shading_language_100,
   GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp,
   GL_ARB_texture_compression, GL_ARB_texture_cube_map,
   GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
   GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
   GL_ARB_texture_mirrored_repeat, GL_ARB_transpose_matrix,
   GL_ARB_vertex_blend, GL_ARB_vertex_buffer_object, GL_ARB_vertex_program,
   GL_ARB_vertex_shader, GL_ARB_window_pos, GL_ARB_draw_buffers,
   GL_ATI_draw_buffers, GL_ATI_element_array, GL_ATI_envmap_bumpmap,
   GL_ATI_fragment_shader, GL_ATI_map_object_buffer, GL_ATI_separate_stencil,
   GL_ATI_texture_env_combine3, GL_ATI_texture_float,
   GL_ATI_texture_mirror_once, GL_ATI_vertex_array_object,
   GL_ATI_vertex_attrib_array_object, GL_ATI_vertex_streams,
   GL_ATIX_texture_env_combine3, GL_ATIX_texture_env_route,
   GL_ATIX_vertex_shader_output_point_size, GL_EXT_abgr, GL_EXT_bgra,
   GL_EXT_blend_color, GL_EXT_blend_func_separate, GL_EXT_blend_minmax,
   GL_EXT_blend_subtract, GL_EXT_clip_volume_hint,
   GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_object,
   GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels, GL_EXT_point_parameters,
   GL_EXT_rescale_normal, GL_EXT_secondary_color,
   GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap,
   GL_EXT_texgen_reflection, GL_EXT_texture3D,
   GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
   GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine,
   GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
   GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
   GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array,
   GL_EXT_vertex_shader, GL_HP_occlusion_test, GL_NV_blend_square,
   GL_NV_occlusion_query, GL_NV_texgen_reflection, GL_SGI_color_matrix,
   GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
   GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
glu version: 1.3
glu extensions:
0x23 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x24 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x25 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x26 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x27 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  1 0 None
0x28 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  1 0 None
0x29 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  1 0 None
0x2a 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  1 0 None
0x2b 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x2c 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x2d 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x2e 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x2f 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  1 0 None
0x30 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  1 0 None
0x31 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  1 0 None
0x32 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  1 0 None
Kjører Ubuntu Breezy med Ati Radeon 9700 Mobility, hva med deg?
Endret av PHPdude
