Timere events og objekter:(
Har store problemer med og sette teksten pa lblCurrentTime labelen, her er koden:
* frmMain.java
* Created on March 4, 2006, 8:41 PM
* @author  Richard
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.util.Date;
import java.util.GregorianCalendar;
import java.util.Calendar;
import java.text.SimpleDateFormat;
import javax.swing.JOptionPane;
import javax.swing.Timer;
public class frmMain extends javax.swing.JFrame
  private void TimerEvent(ActionEvent e){
        gCal.add(Calendar.SECOND, 1);
        String TimeTxt = formmater.format(gCal.getTime());
        lblCurrentTime.SetText(TimeTxt);
  /** Creates new form frmMain */
  public frmMain()
     initComponents();
     timer.addActionListener(new ActionListener()
        public void actionPerformed(ActionEvent e)
           TimerEvent(e);
     timer.start();
  /** This method is called from within the constructor to
   * initialize the form.
   * WARNING: Do NOT modify this code. The content of this method is
   * always regenerated by the Form Editor.
  // <editor-fold defaultstate="collapsed" desc=" Generated Code ">
  private void initComponents()
     javax.swing.JLabel lblCurrentTime;
     lblCurrentTime = new javax.swing.JLabel();
     setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
     lblCurrentTime.setFont(new java.awt.Font("Times New Roman", 1, 36));
     lblCurrentTime.setHorizontalAlignment(javax.swing.SwingConstants.CENTER);
     lblCurrentTime.setText("00:00:00");
     lblCurrentTime.setFocusable(false);
     org.jdesktop.layout.GroupLayout layout = new org.jdesktop.layout.GroupLayout(getContentPane());
     getContentPane().setLayout(layout);
     layout.setHorizontalGroup(
        layout.createParallelGroup(org.jdesktop.layout.GroupLayout.LEADING)
        .add(layout.createSequentialGroup()
           .addContainerGap()
           .add(lblCurrentTime)
           .addContainerGap(258, Short.MAX_VALUE))
     layout.setVerticalGroup(
           .add(19, 19, 19)
           .addContainerGap(239, Short.MAX_VALUE))
     pack();
  }// </editor-fold>
   * @param args the command line arguments
  public static void main(String args[])
     java.awt.EventQueue.invokeLater(new Runnable()
        public void run()
           new frmMain().setVisible(true);
  // Variables declaration - do not modify
  // End of variables declaration
  private GregorianCalendar gCal = new GregorianCalendar();
  private String TimeFormat = "HH:MM:SS";
  private SimpleDateFormat formmater = new SimpleDateFormat(TimeFormat);
  private Timer timer;
Noen ide hvorfor jeg ikke kan sette teksten pa lblCurrentTime? jeg far feilmelding i TimerEvent funksjonen pa linjen "lblCurrentTime.SetText(TimeTxt);"
Feilmeldingen jeg far er Cannot Find symbol, lblCurrentTime
Hva er galt?
Problemet er at lblCurrentTime bare er deklarert i initComponents().
Du kan endre dette manuelt ved å flytte linja
ned til resten av deklarasjonene dine i bunn. Du kan også prøve å gjøre dette i Form Editoren din. Egenskapen burde hete noe sånt som variable scope e.l.
hehe, Jeg bruker NetBeans 5, den linja er merket med blatt, eg kan ikke redigere noe der... hvor finner jeg variable scope?
Finner kun 'Change Variable name", ikke noe som har med scope og gjore...
BTW, vil Timeren min virke? (Jeg kommenterte ut lblCurrentTime.SetText kommandoen, og satte in this.SetTitle(TimeTxt); istedenfor, men jeg far en del feilmeldinger;)
init:
deps-jar:
compile:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
        at frmMain.<init>(frmMain.java:35)
        at frmMain$2.run(frmMain.java:96)
        at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
        at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:242)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:163)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:157)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:149)
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
noen ide?
[EDIT] Fins det noen gode tutorial'er p a Events(hvordan bruke dem, lage egne etc)
Endret av Richard87
