Test Realmen er oppe!
Quote fra Wow test realm forumet. Var ikke blå så kan ikke garantere at det er sandt. men hørtes litt logisk ut.
Ok, before any of u post any more idiotic threads about the "Retrieving Character List" problem, why are u waiting for it to retrieve an empty list? R u waiting for it to show your level 60 Chars? well guess what, if u had bothered to read the terms of the Test Realm, u would know that the Level 60 template Characters are copied onto the PVP test realm, which isn't up yet. So sitting waiting half an hour for a list that will contain nothig is a bit stupid to say the least.
Just click cancel and then cancel again on the Realm Selection page, this will now let u create new chars, but unfortunately, every time i've tried to create a new char, it says "Error Creating Character" this may be a result of Blizzards new rule on making new chars on full servers.
Now unless Blizzard have changed the way the Test Realms work, and I can't see them doing that, the Level 60's will be available when the PVP Test Realm becomes available, for some reason its always a few hours behind the PVE realm, for patch 1.9 it didn't come up until about 3 hours later.
So please don't make any more posts about the "Retrieving Character Lists" taking forever, as u don't need to sit and wait!
By the looks of things, the PVE Test Realm is full and we won't be able to get on, the best thing is to just keep checking for the PVP realm and be the first to get on that! As everybody on the PVE realm should be running around playing level 1's!
5698822[/snapback]
Tusen takk :D
jeg satte meg i kø som nummer 4500. Var inne i løpet av 45 minutter.
5699086[/snapback]
hmm, rart at dere kommer inn:O står på retreiving chars jeg.. vært det i ca 20min nå:/ valgte tauren shaman btw..
