Problem med opengl
Jeg har også litt problemer med GF2ti kortet mitt i Linux.
etter kjører "sudo nvidia-glx-config enable" får jeg:
Error: your X configuration has been altered.
This script cannot proceed automatically. If you believe that this
not correct, you can update the md5sum entry executing the following
command:
md5sum /etc/X11/xorg.conf | sudo tee /var/lib/xfree86/xorg.conf.md5sum
otherwise edit manually /etc/X11/xorg.conf to change the Driver section
from nv to nvidia.
Får ikke opp X når jeg skifter til nvidia i xorg heller.
Og når jeg prøver og installere driveren fra nvidia.com får jeg mye feil om kernel osv. og log fila ser slik ut:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sun Mar  5 20:32:31 2006
option status:
  license pre-accepted    : false
  update                  : false
  force update            : false
  expert                  : false
  uninstall              : false
  driver info            : false
  no precompiled interface: false
  no ncurses color        : false
  query latest driver ver : false
  OpenGL header files    : false
  no questions            : false
  silent                  : false
  X install prefix        : /usr/X11R6
  OpenGL install prefix  : /usr
  Installer install prefix: /usr
  kernel source path      : (not specified)
  kernel install path    : (not specified)
  proc mount point        : /proc
  ui                      : (not specified)
  tmpdir                  : /tmp
  ftp site                : ftp://download.nvidia.com
Using: nvidia-installer ncurses user interface
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you li
  ke the installer to attempt to download a kernel interface for your kernel f
  rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: Yes)
-> No matching precompiled kernel interface was found on the NVIDIA ftp site;
  this means that the installer will need to compile a kernel interface for
  your kernel.
ERROR: Unable to find the kernel source tree for the currently running kernel.
      Please make sure you have installed the kernel source files for your
      kernel; on Red Hat Linux systems, for example, be sure you have the
      'kernel-source' rpm installed.  If you know the correct kernel source
      files are installed, you may specify the kernel source path with the
      '--kernel-source-path' commandline option.
ERROR: Installation has failed.  Please see the file
      '/var/log/nvidia-installer.log' for details.  You may find suggestions
      on fixing installation problems in the README available on the Linux
      driver download page at www.nvidia.com.
Endret av Gakkakk
Kortet ditt er ikke lengre støttet av nVIDIA. Du må bruke eldre drivere.
Når det gjelder kompilering så står det jo hva som er feil, du trenger kernel-header/source.
5706326[/snapback]
Ja, jeg bruker eldre drivere som jeg mener skal støtte kortet
Har fått installert kernel-source2.6.11 med apt-get, men den vil ikke installere headers. Finner ikke kernel-header på pakkesøk hos packages.ubuntu.com heller
Hvis du har installert kildekoden så trenger du ikke headers.
5706417[/snapback]
Har fått installert Kernel-source nå og installasjonen begynner og bygge, men på ca. 75% får jeg no error.
LOG:
-> Building kernel module:
  executing: 'cd ./usr/src/nv; make module SYSSRC=/usr/src/kernel-source-2.6.1
  1'...
  Your kernel was configured to include rivafb support as
  a loadable kernel module.
  The rivafb driver conflicts with the NVIDIA driver; the
  NVIDIA kernel module will still be built and installed,
  but be aware that the NVIDIA driver will not be able to
  function properly if the rivafb module is loaded!
  *** Failed rivafb module sanity check, but continuing! ***
  NVIDIA: calling KBUILD...
  mkdir -p /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/.tmp_ver
  sions
  make -f scripts/Makefile.build obj=/tmp/selfgz28211/NVIDIA-Linux-x86-1.0-610
  6-pkg1/usr/src/nv
  echo \#define NV_COMPILER \"`cc -v 2>&1 | tail -n 1`\" > /tmp/selfgz28211/NV
  IDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv_compiler.h
    cc -Wp,-MD,/tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/.nv.
  o.d -nostdinc -isystem /usr/lib/gcc/i486-linux-gnu/4.0.2/include -D__KERNEL_
  _ -Iinclude  -Wall -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -
  fno-common -ffreestanding -Os    -fomit-frame-pointer -pipe -msoft-float -m
  preferred-stack-boundar
  y=2 -fno-unit-at-a-time -march=athlon -Iinclude/asm-i386/mach-default -Wdecl
  aration-after-statement -Wno-pointer-sign -I/tmp/selfgz28211/NVIDIA-Linux-x8
  6-1.0-6106-pkg1/usr/src/nv -Wall -Wimplicit -Wreturn-type -Wswitch -Wformat
  -Wchar-subscripts -Wparentheses -Wpointer-arith  -Wno-multichar  -Werror -O
  -fno-common -MD  -Wno-cast-qual -Wno-error -D_LOOSE_KERNEL_NAMES -D__KERNEL
  __ -DMODULE  -DNTRM -D_GNU_SOURCE -D_LOOSE_KERNEL_NAMES -D__KERNEL__ -DMODUL
  E  -DNV_MAJOR_VERSION=1 -DNV_MINOR_VERSION=0 -DNV_PATCHLEVEL=6106  -DNV_UNIX
    -DNV_LINUX  -DNV_INT64_OK  -DNVCPU_X86      -DNV_CHANGE_PAGE_ATTR_PRESE
  NT -DNV_CLASS_SIMPLE_PRESENT  -DMODULE -DKBUILD_BASENAME=nv -DKBUILD_MODNAME
  =nvidia -c -o /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/.tm
  p_nv.o /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c
  In file included from include/linux/list.h:7,
                    from include/linux/wait.h:23,
                    from include/asm/semaphore.h:41,
                    from include/linux/sched.h:19,
                    from include/linux/module.h:10,
                    from /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/sr
  c/nv/nv-linux.h:52,
  c/nv/nv.c:14:
  include/linux/prefetch.h: In function ‘prefetch_range’:
  include/linux/prefetch.h:62: warning: pointer of type ‘void *’ used in a
  rithmetic
  In file included from include/linux/dmapool.h:14,
                    from include/linux/pci.h:863,
  c/nv/nv-linux.h:75,
  c/nv/nv.c:14:
  include/asm/io.h: In function ‘check_signature’:
  include/asm/io.h:242: warning: wrong type argument to increment
  /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c: In function
  ‘nvos_find_agp_by_class’:
  /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:642: warning
  : implicit declaration of function ‘pci_find_class’
  : assignment makes pointer from integer without a cast
  /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:653: warning
  ‘nvidia_init_module’:
  /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:1161: warnin
  g: ‘pm_register’ is deprecated (declared at include/linux/pm.h:106)
  ‘nvidia_exit_module’:
  /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:1279: warnin
  g: ‘pm_unregister’ is deprecated (declared at include/linux/pm.h:111)
  ‘nv_kern_mmap’:
  /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:1764: warnin
  g: implicit declaration of function ‘remap_page_range’
  ‘_get_phys_address’:
  /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:2732: warnin
  g: passing argument 1 of ‘pmd_offset’ from incompatible pointer type
  ‘nv_agp_init’:
  /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:3324: warnin
  g: ‘inter_module_put’ is deprecated (declared at include/linux/module.h:
  578)
  ‘nvos_count_devices’:
  /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:3474: warnin
  g: assignment makes pointer from integer without a cast
  /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:3479: warnin
  ‘nv_acpi_event’:
  /tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:3677: error:
  ‘PM_SAVE_STATE’ undeclared (first use in this function)
  (Each undeclared identifier is reported only once
  for each function it appears in.)
  make[3]: *** [/tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.
  o] Error 1
  make[2]: *** [_module_/tmp/selfgz28211/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/sr
  c/nv] Error 2
  NVIDIA: left KBUILD.
  nvidia.ko failed to build!
  make[1]: *** [module] Error 1
  make: *** [module] Error 2
-> Error.
ERROR: Unable to build the NVIDIA kernel module.
Står noe om at jeg må fjerne rivafb modulen.
holder det om jeg fjerner "/lib/modules/2.6.12-9-386/kernel/drivers/video/riva/rivafb.ko" ?
Hei og hopp, nå fikk jeg det til :D stod nettop alle testene på cedega også =)
Her er den magiske howto guiden som hjelpte meg
scroll the file down until you find the line with “Modules” and comment out (by putting a "#" before the line) the 2 lines I put in blue and add Load "glx". It should look like the example below:
Code:
Section "Module"
Load "bitmap"
Load "dbe"
Load "ddc"
#Load "dri"
#Load “GLcore”
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "type1"
Load "vbe"
Vart ikke med farger her da men, sett # foran Load "dri" og Load "GLcore"
Endret av Ole J
Code:
Section "Module"
Load "bitmap"
Load "dbe"
Load "ddc"
#Load "dri"
#Load “GLcore”
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "type1"
Load "vbe"
5709226[/snapback]
Takk! :D Brukte metode 1, og nå funker det som bare det ;)
