Kan noen hjelpe..mailformproblem?
Hei.
Prøver ut noe jeg fant på Hotscripts.com.
Jeg har nettop installert http://apache2triad.net/
Har gjort det de ba om i koden....eh tror jeg :blush:
Prøver å sende mail til meg selv...uten resultat. alt funker tilsynelatene da. Noen som kan hjelpe?
Her er Html-koden
<html>
<head>
<title>Test</title>
</head>
<body bgcolor="#ffffff" LEFTMARGIN="0" TOPMARGIN="0" MARGINWIDTH="0" MARGINHEIGHT="0" LINK="#000099" VLINK="#000044" ALINK=
<table border="0" cellpadding="0" cellspacing="0" width="600">
 <tr valign="top"><!-- row 1 -->
  <td rowspan="2" colspan="2"> </td>
  <td> </td>
  <td> </td>
  <td width="100%"> </td>
 </tr>
 <tr valign="top"><!-- row 2 -->
  <td rowspan="2"> </td>
  <td colspan="2" width="100%"> </td>
 </tr>
 <center>
</center>
 <table cellpadding="3" cellspacing="0" width="400" bgcolor="#DFDFDF" border="1">
<tr>
<td><table border="0" cellpadding="3" cellspacing="3">
<FORM ACTION="mail.php" METHOD="POST">
<tr><td colspan="2" valign="top" align="center">
<font face="verdana, arial" size="-1"><b>Please fill in the form to contact us</b></font></td></tr>
<tr>
<td align="right" nowrap><font face="verdana, arial" size="-1">Your Name: </font></td>
<td align="left"><input type="text" name="Name" size="32" value=""></td>
</tr>
<tr>
<td align="right" nowrap><font face="verdana, arial" size="-1">Daytime Phone: </font></td>
<td align="left"><input type="text" name="DayPhone" size="32" value=""></td>
</tr>
<tr>
<td align="right" nowrap><font face="verdana, arial" size="-1">Evening Phone: </font></td>
<td align="left"><input type="text" name="EvePhone" size="32" value=""></td>
</tr>
<tr>
<td align="right" nowrap><font face="verdana, arial" size="-1">Your E-mail: </font></td>
<td align="left"><input type="text" name="Email" size="32" value=""></td>
</tr>
<tr>
<td colspan="2" valign="bottom">
<font face="verdana, arial" size="-1">Extra information to include with your message:</font></td>
</tr>
<tr>
<td colspan="2" valign="top">
<textarea cols="42" rows="5" name="Message" wrap></textarea></td>
</tr>
<tr>
<input type="hidden" name="To" value="[email protected]">
<input type="hidden" name="Returned" value="1">
<input type="submit" value="Send This Information"></form></td>
</tr>
</table></td></tr></table></td>
 </tr>
<tr><td> </td>
<td colspan="3" width="100%">
<p><p>
<center>
</center>
</td></tr>
</body>
</html>
og PHP-kode
$MailToAddress = "[email protected]";
$MailSubject = "YOUR SUBJECT HERE";
   if (!$MailFromAddress) {
   $MailFromAddress = "[email protected]";
$Header = "";
$Footer = "";
<html>
<body bgcolor="#FFFFFF">
<font face="Arial"><center>
The following information has been delivered:
</center>
   if (!is_array($HTTP_POST_VARS))
   return;
reset($HTTP_POST_VARS);
   while(list($key, $val) = each($HTTP_POST_VARS)) {
   $GLOBALS[$key] = $val;
   $val=stripslashes($val);
   echo  "<b>$key</b> = $val<br>";
   $Message .= "$key = $val\n";
   if ($Header) {
   $Message = $Header."\n\n".$Message;
   if ($Footer) {
   $Message .= "\n\n".$Footer;
mail( "$MailToAddress", "$MailSubject", "$Message", "From: $MailFromAddress");
<br><br>
<b>Thank You!</b>
<br><br>
<a href="<? echo  "$HTTP_REFERER"; ?>">Return To The Mail Form</a><br><br>
<a href="/">Home Page</a><br><br>
</body>
</html>
:thumbup: Shonah
Hei.
Her er Html-koden
<html>
<head>
<title>Test</title>
</head>
  <td> </td>
  <td> </td>
 </tr>
 </tr>
 <center>
</center>
<tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
 </tr>
<tr><td> </td>
<p><p>
<center>
</center>
</td></tr>
</body>
</html>
og PHP-kode
$Header = "";
$Footer = "";
<html>
</center>
   return;
   if ($Header) {
   if ($Footer) {
<br><br>
<b>Thank You!</b>
<br><br>
</body>
</html>
:thumbup: Shonah
5695737[/snapback]
Scriptet kjører fint hos meg, sender epost dit den skal osv. Hvilke feilmeldinger får du?
HAr ikke apachetriad alt da...hmmm
hva er  XMAIL?..
5695910[/snapback]
Xmail er en mailserver, så jo- tydligvis har apachetriad alt. Du må vel gjerne åpne porter i router eller lignende for å få brukt serveren. SMTP på port 25, POP3 på port 110 og IMAP4 på port 143
Du må enten ha en mailserver kjørende på localhost som det sikkert er satt opp som standard, eller kan du gå til php mappen din å finne en fil som heter php.ini..
Der skal du kunne sette SMTP server og port, bare trykk Ctrl + F eller B og søk etter SMTP i filen vist du vil bruke en "ekstern" server..
Takk for alle svar!
Det funker fint på webserveren. Men sliter med kofigurering av Xmail på min maskin.
Har googla og lett uten resultat. Aldri installert mailserver og er litt grønn.
Noen forslag her? Kanskje det er noen som kjører apache2triad?
:thumbup: Shonah
Endret av Shonah
Du skriver en SMTP server du har tilgjengelig!
5705758[/snapback]
takk for det!
hæ!?! :hmm: her er hva jeg skrev inn?..er det alt?...jeg har nå trykket og herjet i oppsettet til apache2triad så var det bare det. Jeg vet ikke jeg ...men nå funker det iallefall. :)
[mail function]
; For Win32 only.
SMTP = mail.c2i.net
smtp_port = 25
; For Win32 only.
sendmail_from = admin@localhost
:thumbup: Shonah
