Check Engine og motorfusk
Hei!
I går etter jeg hadde vært på hytta og skulle kjøre ned fra fjellet så skjedde det noe rart med bilen mens jeg kjørte.
Opptill flere ganger dukket det opp en gul text det stod Check Engine på.
Merker at motoren fusket litteranne når den koblet inn virket det som.
Kveler seg på tomgang
(Chrysler Neon 1997)
Hva kan dette skyldes? :hmm:
Endret av Heineoen
Hmm.. Føler du ofte har problemer med Neon'en din :ermm:
To Check your codes:
1. Put the key in the ignition.
2. Turn key all the way forward - not to the point where the car starts, just to the point where all the lights come on. Do it in this sequence: ON-OFF-ON-OFF-ON..
3. Keep a close eye on your odometer. You will see a series of codes display, followed by the word "donE"...
4. These codes will tell you why the "Check Engine Light" is coming on. Someone has a list on the web somewhere of what they mean.
5. Now, I'm going to make you a bet... I bet that the codes you see will be "P1684" followed by "P0456". These codes mean respectively: Bat. has been disconnected within the last 50 starts, EVAP sensor detection...
6. IF IT IS THESE SET OF CODES, fear not - nothing is wrong with your car. Simply...
6a. Tighten your gas cap, then...
7. Pop the hood, disconnect the NEGATIVE battery terminal - DO NOT DISCONNECT THE POSITIVE TERMINAL - FOR THE LOVE OF GOD. You will run the risk of shorting out the electrical system.
8. Wait a couple of minutes, then reconnect.
9. Start the car up and TADA! CEL is gone!
Er ikke sikker på om dette kan hjelpe deg, men skal ifølge dette ihvertfall vise deg hva som er gale :)
