Hva er "Hydravision?"
Denne skulle vel ha vært postet i programvare... Men føler meg tryggere på og poste den her=).. Greit, jeg har lest litt om Hydravision... Men jeg vil ha en litt mer detaljert beskrivelse av det.. Hva nøyaktigt er det? Hva er positivt/negativt med det?...
Endret av Crom-Ag3
Visstnok et program for å utvide skrivebordet til 2 skjermer og slikt.
Kopiert fra ati.com:
Hydravision™- Expand your horizons
overview
Hydravision™ Multi-monitor Management Software enables you to tailor your desktop to the way you work, so you can manage increased amounts of information and improve your productivity. Your productivity is increased thanks to two aspects Hydravision™:
Breadth - increase your desktop work space by using up to two monitors
Depth - create multiple layers of desktop workspace with Multi-Desk
Flexible and easy to use
Within minutes Hydravision™ gives you the power to manage independent monitor display features and:
Determine the behavior of pop-up windows and dialog boxes in different applications
Switch between desktop with a mouse click or "Hot Key"
Vary your settings from one application to the next
Customize the features of Hydravision™ to an application
Increase your productivity
ATI wanted to increase your productivity even more, so we have introduced more cool features in version 3 of Hydravision™:
Transparent windows and menus
"Always-on-Top"
Multi-Desk properties
Cycle through desktops view
Move To Monitor
Internet Explorer extension
Hydravision Basic Edition
ATI is introducing a new easy-to-use and intuitive version of Hydravision™. Using a redesigned user interface, Hydravision Basic Edition will provide users with the essential features required to configure and easily use a multiple display setup.
