Zungam Skrevet 25. februar 2006 Del Skrevet 25. februar 2006 Hei..Jeg har denne dvd brenneren: ATAPI DVD DUAL 8x4x12 Har hatt denne nesten et halvt år nå...Har for det meste brukt Nero burning rom, men i det siste så har jeg fått opp felmeldinger ved dvd brenning... "Power calibration error"..jeg selv trodde dette hadde med strømledningen så jeg har byttet den, men det samme kommer opp...Vet noen hva som kan være galt? Her er utrag av loggen: AutoRun : 1 Excluded drive IDs: WriteBufferSize: 74448896 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 511MB (523768kB) Free physical memory: 23MB (24164kB) Memory in use : 95 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 25.2.2006 ISO compilation 00:13:58 #1 Text 0 File Isodoc.cpp, Line 6411 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 00:13:58 #2 Text 0 File ThreadedTransfer.cpp, Line 525 ReadBuffer-Pipe got 262144KB of Memory 00:13:58 #3 Text 0 File Reader.cpp, Line 124 Reader running 00:13:58 #4 Text 0 File Writer.cpp, Line 113 Writer E: ATAPI DVD DUAL 8X4X12 running 00:13:58 #5 ISO9660GEN -11 File Geniso.cpp, Line 3312 First writeable address = 0 (0x00000000) 00:13:58 #6 Text 0 File Burncd.cpp, Line 3342 Turn on Disc-At-Once, using DVD media 00:13:58 #7 Text 0 File DlgWaitCD.cpp, Line 279 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 714847 (158:51.22, 1396MB) 00:13:58 #8 Text 0 File DlgWaitCD.cpp, Line 291 Write in overburning mode: NO (enabled: CD) 00:13:58 #9 Text 0 File DlgWaitCD.cpp, Line 2578 Recorder: ATAPI DVD DUAL 8X4X12, Media type: DVD+R 00:13:58 #10 Text 0 File DlgWaitCD.cpp, Line 458 >>> Protocol of DlgWaitCD activities: <<< ========================================= 00:13:58 #11 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 714848 (714848) = #714848/158:51.23 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 714848 blocks [E: ATAPI DVD DUAL 8X4X12] -------------------------------------------------------------- 00:13:58 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [E: ATAPI DVD DUAL 8X4X12] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1464008704, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 714848 | lead-out | 1 | 0x41 | 0x00 00:13:58 #13 Text 0 File SCSIPassThrough.cpp, Line 36 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 00:13:58 #14 Phase 24 File dlgbrnst.cpp, Line 1725 Unknown BurnPhase 00:13:59 #15 Text 0 File Burncd.cpp, Line 4176 Cache writing successful. 00:13:59 #16 Phase 25 File dlgbrnst.cpp, Line 1725 Unknown BurnPhase 00:13:59 #17 Phase 36 File dlgbrnst.cpp, Line 1725 Unknown BurnPhase 00:13:59 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2685 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 00:13:59 #19 SPTI -1066 File SCSIPassThrough.cpp, Line 323 E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x24 Sense Qual: 0x00 CDB Data: 0xAD 00 00 00 00 00 00 00 08 04 00 00 Sense Area: 0x70 00 05 00 00 00 00 12 00 00 00 00 24 Buffer x04751c00: Len x804 00:13:59 #20 Text 0 File DVDPlusRW.cpp, Line 666 Start write address at LBA 0 DVD high compatibility mode: Yes 00:15:11 #21 SPTI -1106 File SCSIPassThrough.cpp, Line 323 E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x70 00 03 00 00 00 00 12 00 00 00 00 73 03 Buffer x05410000: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00:15:11 #22 CDR -1106 File Writer.cpp, Line 302 Unknown CDR error E: ATAPI DVD DUAL 8X4X12 00:15:12 #23 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 00:15:14 #24 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 00:15:15 #25 SPTI -1176 File SCSIPassThrough.cpp, Line 323 E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1176) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x72 Sense Qual: 0x03 CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 12 00 00 00 00 72 03 00:15:15 #26 Phase 127 File dlgbrnst.cpp, Line 1725 Unknown BurnPhase 00:15:15 #27 Phase 129 File dlgbrnst.cpp, Line 1725 Unknown BurnPhase 00:15:15 #28 Phase 38 File dlgbrnst.cpp, Line 1725 Unknown BurnPhase Er det noen som forstår noe av dette? Lenke til kommentar
Booz Skrevet 25. februar 2006 Del Skrevet 25. februar 2006 Har hatt denne feilmeldingen selv, flashet ny firmware så funket det. Har du brent av denne type plater før uten problemer? Lenke til kommentar
Zungam Skrevet 25. februar 2006 Forfatter Del Skrevet 25. februar 2006 Ja jeg har klart å brenne de samme platene mange ganger før..men hva mener du med "flashet ny firmware så funket det"? mener du at du installerte ny driver? Lenke til kommentar
Booz Skrevet 25. februar 2006 Del Skrevet 25. februar 2006 Ja jeg har klart å brenne de samme platene mange ganger før..men hva mener du med "flashet ny firmware så funket det"? mener du at du installerte ny driver? 5662599[/snapback] Firmware er "software" som ligger lagret inni dvd-brenneren. Du kan oppdatere firmwaren for og få bla støtte til mer brenneplater. firmware side Lenke til kommentar
Booz Skrevet 25. februar 2006 Del Skrevet 25. februar 2006 Men det er ikke sikkert det er firmwaren. nero fix POWER CALIBRATION ERRORS ARE CAUSED MOSTLY BY POOR MEDIA. (CHEAP BRANDED CD'S IE. PROMEDIA) - TRY USING A DIFFERENT BRAND (COMPUSA, TDK'S, MEMOREX, SONY) ARE THE BEST BET; DON'T WASTE YOUR MONEY ON CHEAP DISKS - YOULL JUST WASTE THEM. If everything is to no avail, then maybe a firmware upgrade will do the trick. Have a look at firmware Prøv dette Lenke til kommentar
Zungam Skrevet 27. februar 2006 Forfatter Del Skrevet 27. februar 2006 Har prøvd å flashe firmwaren men , en melding om at den eksisterende firmwaren ikke kan oppdateres kommer opp...prøvde dessuten ut det som stod på "nero fix" om å deaktivere imapi cd-brenning fra kontrollpanelet..men brenningen går fortsatt på dvd..cd-brenningen funker...Har dere andre noen tips?? Lenke til kommentar
Psh Skrevet 27. februar 2006 Del Skrevet 27. februar 2006 (endret) Fortell oss litt om platene du bruker: Merke og mediakode er av interesse. Klarer du å finne ut hviken brenner du har? Det står som regel på toppen av brenneren. ("ATAPI DVD DUAL 8x4x12" forteller oss ingeting om produsent) Edit: Har en misstanke om at det er en BenQ DW822A. Endret 27. februar 2006 av Psh Lenke til kommentar
Zungam Skrevet 27. februar 2006 Forfatter Del Skrevet 27. februar 2006 (endret) Brenneren jeg har er en BenQ DW800A Har brukt Verbatim dvd-r (16x certified) med advanced AZO+ Mediakode: MCC 03RG20 Også brukt Act storage DVD+r (noen billige kjøpr på rimi, har funket helt greit) mediakode: YUDEN000T02 Kjøpte også idag Dvd +r fra tdk med en hastighet fra 1-16 x som er RW(rewritable) for å se om disse kunne virke, men fikk samme resultat og brenningen stoppet opp... Mediakode: TDK.....003 Endret 27. februar 2006 av Magt87 Lenke til kommentar
Psh Skrevet 28. februar 2006 Del Skrevet 28. februar 2006 Act Storage platene burde du absolutt ikke bruke til noe viktig, dette er falske YUDEN000T02 plater av værste sort.(om disse feiler er det ingen bombe) Verbatim platene er meget bra, det er også de TDK platene, men de er ikke RW plater!(DVD+R standarden har RW som logo) Hvilken version av Nero bruker du? 7 eller 6? Oppdater til siste version, annbefaler deg 6.6.1.4 da det har vært mye problemer med version 7. Det kan ofte bli problemer med å bruke 16x plater på en brenner som kun støtter 8x, dette fordi firmware ikke har støtte for disse platene. Så da kommer spørsmålet om hvilken firmware du har? Dette kan du finne ut ved bruk av Nero InfoTool. Lenke til kommentar
Zungam Skrevet 28. februar 2006 Forfatter Del Skrevet 28. februar 2006 (endret) Jeg bruker nero 6 ultra edition 6.61.4 .. Act storage platene funket før, men ikke nå....det gjør heller ikke Tdk platene..har faktiskt ikke flere igjen av verbatim platene.. Min firmware er nå B5N7 Denne firmware ligger bla. her : http://tdb.rpc1.org/ lEGGER VED INFOTOOL FILEN SOM VISER INFO OM MIN DVD BRENNER InfoTool2.TXT Endret 28. februar 2006 av Magt87 Lenke til kommentar
Psh Skrevet 28. februar 2006 Del Skrevet 28. februar 2006 Det er et hav av firmwares til denne brenneren, men jeg finner ingen som er nyere en den du allerede har. Etter hva jeg kan se har du 2 valg... 1. Kjøpe 8x plater (Ikke Act Storage) 2. Kjøpe ny brenner (annbefaler BenQ DW1650) Det at Act Storage platene har funket før er ren flaks, fikk bare brent ca. halvparten av en spinndel her(og disse med meget dårlig resultat) Lenke til kommentar
Psh Skrevet 28. februar 2006 Del Skrevet 28. februar 2006 Du har en mulighet til... Det er å flashe til DW822 firmware. Lenke til kommentar
Zungam Skrevet 28. februar 2006 Forfatter Del Skrevet 28. februar 2006 Når jeg prøver å flashe kommer bare denne meldingen opp: The enter firmware version can't upgrade this drive! Lenke til kommentar
Zungam Skrevet 1. mars 2006 Forfatter Del Skrevet 1. mars 2006 Takk for all hjelp, desverre har ingenting funket... Kontaktet derfor Benq`s service og har fått beskjed om at jeg kan bytte den...Heldigvis har jeg bare hatt brenneren et halvt år så garantien på 2 år funker fortsatt...Håper jeg får en som kan virke litt lenger denne gangen Lenke til kommentar
