Feilmelding under kompilering
Saken er at jeg får opp en feilmelding når jeg prøver å kompilere KDM Theme manager, den lyder som følger:
configure: error: C++ preprocessor "/lib/cpp" fails sanity check
See `config.log' for more details
Hva mangler jeg, og hvordan kan jeg få tak i det?
Og mens jeg er her, når jeg starter Xmms fra GUI skjer ingenting, og når jeg starter fra terminal står det bare "Segmentation fault". Noen som vet hva det kan være?
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.59.  Invocation command line was
 $ ./configure
## Platform. ##
hostname = Kim
uname -m = i686
uname -r = 2.6.10-6-386
uname -s = Linux
uname -v = #1 Mon Jan 16 18:19:44 UTC 2006
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = i686
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
hostinfo               = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /sbin
PATH: /bin
PATH: /usr/bin/X11
PATH: /usr/games
## Core tests. ##
configure:1563: checking build system type
configure:1581: result: i686-pc-linux-gnu
configure:1589: checking host system type
configure:1603: result: i686-pc-linux-gnu
configure:1611: checking target system type
configure:1625: result: i686-pc-linux-gnu
configure:1672: checking for a BSD-compatible install
configure:1727: result: /usr/bin/install -c
configure:1742: checking for -p flag to install
configure:1755: result: yes
configure:1766: checking whether build environment is sane
configure:1809: result: yes
configure:1829: checking for gawk
configure:1858: result: no
configure:1829: checking for mawk
configure:1845: found /usr/bin/mawk
configure:1855: result: mawk
configure:1865: checking whether make sets $(MAKE)
configure:1885: result: yes
configure:2048: checking for kde-config
configure:2110: result: /usr/bin/kde-config
configure:2206: checking where to install
configure:2210: result: /usr (as returned by kde-config)
configure:2277: checking for style of include used by make
configure:2305: result: GNU
configure:2453: checking for gcc
configure:2469: found /usr/bin/gcc
configure:2479: result: gcc
configure:2723: checking for C compiler version
configure:2726: gcc --version </dev/null >&5
gcc (GCC) 3.3.5 (Debian 1:3.3.5-8ubuntu2)
Copyright (C) 2003 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:2729: $? = 0
configure:2731: gcc -v </dev/null >&5
Reading specs from /usr/lib/gcc-lib/i486-linux/3.3.5/specs
Configured with: ../src/configure -v --enable-languages=c,c++,java,f77,pascal,objc,ada,treelang --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-gxx-include-dir=/usr/include/c++/3.3 --enable-shared --with-system-zlib --enable-nls --without-included-gettext --enable-__cxa_atexit --enable-clocale=gnu --enable-debug --enable-java-gc=boehm --enable-java-awt=xlib --enable-objc-gc i486-linux
Thread model: posix
gcc version 3.3.5 (Debian 1:3.3.5-8ubuntu2)
configure:2734: $? = 0
configure:2736: gcc -V </dev/null >&5
gcc: `-V' option must have argument
configure:2739: $? = 1
configure:2762: checking for C compiler default output file name
configure:2765: gcc     conftest.c  >&5
configure:2768: $? = 0
configure:2814: result: a.out
configure:2819: checking whether the C compiler works
configure:2825: ./a.out
configure:2828: $? = 0
configure:2845: result: yes
configure:2852: checking whether we are cross compiling
configure:2854: result: no
configure:2857: checking for suffix of executables
configure:2859: gcc -o conftest     conftest.c  >&5
configure:2862: $? = 0
configure:2887: result:
configure:2893: checking for suffix of object files
configure:2914: gcc -c    conftest.c >&5
configure:2917: $? = 0
configure:2939: result: o
configure:2943: checking whether we are using the GNU C compiler
configure:2967: gcc -c    conftest.c >&5
configure:2973: $? = 0
configure:2977: test -z
   || test ! -s conftest.err
configure:2980: $? = 0
configure:2983: test -s conftest.o
configure:2986: $? = 0
configure:2999: result: yes
configure:3005: checking whether gcc accepts -g
configure:3026: gcc -c -g  conftest.c >&5
configure:3032: $? = 0
configure:3036: test -z
configure:3039: $? = 0
configure:3042: test -s conftest.o
configure:3045: $? = 0
configure:3056: result: yes
configure:3073: checking for gcc option to accept ANSI C
configure:3143: gcc  -c    conftest.c >&5
configure:3149: $? = 0
configure:3153: test -z
configure:3156: $? = 0
configure:3159: test -s conftest.o
configure:3162: $? = 0
configure:3180: result: none needed
configure:3198: gcc -c    conftest.c >&5
conftest.c:2: error: syntax error before "me"
configure:3204: $? = 1
configure: failed program was:
| #ifndef __cplusplus
|   choke me
| #endif
configure:3339: checking dependency style of gcc
configure:3401: result: gcc3
configure:3412: checking how to run the C preprocessor
configure:3447: gcc -E  conftest.c
configure:3453: $? = 0
configure:3485: gcc -E  conftest.c
conftest.c:11:28: ac_nonexistent.h: No such file or directory
configure:3491: $? = 1
| /* confdefs.h.  */
Værsågod! Håper det forteller deg noe...
