Noen spørsmål om Creative Zen Vison:M
  • 2 uker senere...
Leste på en erfaring at det ikke går ann å sortere sangene etter " artist - album - låt" stemmer dette? i så fall er dette et ekstremt dårlig opplegg!!
5997200[/snapback]
Jo det funker.
Musikkbibliotek -> Artist -> Album -> Alle låtene i albumet
I musikkbiblioteket kan du også velge spillelister, album, sjanger eller alle spor.
Pug!
har du fått den ekstra betteri-tingen du bestillte fra eBay enda?
6003321[/snapback]
Ja! :)
Har bare brukt den en gang enda (batterilevetiden på selve spilleren er veldig seg, bah. *vil teste batteritingen mer*). Men den virket helt utmerket. Bare koblet den til med 4 AA-batterier i, også begynte den å lades som om den var koblet til USB/strømnettet. Kunne bruke den samtidig som den ladet, og den ladet fra (nesten) helt tomt til nesten helt fullt. Regner med at den hadde blitt helt oppladet om jeg ikke hadde brukt spilleren samtidig som jeg ladet.
A plug for mortrar-and-brick stores. I got my ZVM from a shop in Galleriet. An evening of failed attempts to make Windows XP SP2 recognize the player (and googling for possible causes) led me back to the store the next day. They started with trying another USB cable (no-go, naturally), followed by another dongle. Heh, turned out it was that plastic cheapo thing's fault after all :D As a test, I asked them to update the firmware I had on a memory stick with me (the only fruit of my frantic net search the previous night). Took me 50 minutes, including the walk to Torgalmenningen and back. Compared to at least a weak of first getting an RMA, mailing the player to the seller, and getting it back. The only problem I had since then was Creative software suddenly refusing to recognize it, but a Windows reboot cured that.
On the topic of sound volume, flushing it with the US firmware didn't help at all. I read some complaints about ZVM's weak headphone amplifier on other forums as well. Have anyone tried to use replaygain on the file and see if it helps?
Hei, jeg har tenkt å kjøpe spilleren fra hjemmesiden, men er en del ting jeg er usikre på.
1. Er prisen NOK2841.93 total? Ser ut til at det er uten moms men..
2. Under noe som antakelig er fargevalget, får jeg valget mellom
- Black 2 pin EU + 3pin UK English/Norwegian
- Black 2 pin German/EE
- Green
- Pink
- WHITE - 3 Pin UK plug
Hva er forskjellen på disse? Det høres jo ikke bare ut som fargevalg?
3. Er det noen som har bilder tatt av eget digitalkamera, altså ikke noe Photoshop-sminka piss. Har leta kjapt etter noen bilder på google, og da hadde den rosa utrolig stygg farge i forhold til den de reklamerer på på creative.com..
Hvordan er dette med riper på skjermen? Er det så ille som man får inntrykk av?
6055735[/snapback]
Ikke vært noe problem for meg enda. Har vært forsiktig med spilleren min da.
6058416[/snapback]
Samme for meg. Jeg har også tatt godt vare på den. Bruk alltid posen som følger med, så holder du riper unna ;)
