Gateway NX860XL (Yonah) v. Hypersonic CX7 (Sonoma)
Jeg har bestemt meg for aa kjope en av disse pcene. Gateway NX860XL eller Hypersonic Aviatior CX7.
Forskjellen paa de to er:
Hypersonic har hoyere skjermopplosning
Gateway har nyere CPU teknologi
Hypersonic har en bedre men mindre harddisk
Azalia vs. Sigmatel lyd, hva er best?
URL til de to selskapene er:
http://www.hypersonic-pc.com
http://www.gateway.com
Hvilken av de to ville du valgt, vennligst inkluder en saklig begrunnelse i tillegg, da gjor inlegget ditt mye nyttigere for meg. :)
Dere faar unskylde at jeg ikke har ae, o eller aa, da jeg befinner meg i usa for tiden.
Specs finner dere under.
Processor & Chipset
2.0GHz Intel® Pentium® M-760 Processor w/2MB Cache
Intel 915PM + ICH6M Chipset
533MHz Front Side Bus
Memory
533MHz PC4200 DDR-2 SODIMMS
2x512MB PC4200 DDR2-533
Dual Channel Memory Architecture (Memory must be selected in pairs)
Graphics
NVIDIA GeForce Go 7800 GTX High-Performance Graphics Processor
256B DDR SGRAM on board
16X PCI-Express Architecture
Display
17.0" WUXGA Wide Screen (16:10)
1920x1200 Native Resolution
Communication
IrDA 1.1
10/100/1000Mb Ethernet LAN built-in
Built-in 802.11g Wireless LAN
Built-in 1.3MP Video Camera
56K Modem with V.90&V.92
Connectivity
1 x External CRT Monitor (DVI and Analog
4 x USB 2.0 ports
1 x Headphone, Mic & Line-in jack
1 x RJ45 for 10/100Mb LAN
1 x RJ11 Jack for 56K (V.92) Modem
1 x mini IEEE 1394a FireWire port
1 x SP/DIF Jack
1 x infrared file transfer, IrDA 1.1
1 x S-Video jack for TV output
1 x Type II PCMCIA Slot (PCMCIA 3.0 Standard Compliant)
1 x S-Video In
1 x S-Video Out
Sound System
Built-in 8ch Azalia Sound System
3D Stereo enhanced sound system
Front Panel AUDIO DJ CD Player with MP3 Support
S/PDIF Digital output (5.1CH)
Built-in 4 speakers
Storage
DVD-RW/CD-RW/Combo Drive DualLayer
60GB 7200RPM S-ATA HDD w/NCQ & 8MB Cache
Built-in 4-in-1 Card Reader (MS/MSPRO/SD/MMC)
Weight and Dimensions
15.6" Wide
11.5" Deep
1." ~ 1.7" High
8.3lbs (including battery)
Gateway NX860XL
Processor and Chipset
Intel® Core™ Duo Processor T2500 (2.00 GHz, 667MHz FSB, 2MB L2 Cache)
Intel 945PM Chipset
Memory
1024MB 533MHz DDR2 SDRAM (2-512MB modules)
Storage
100GB 5400rpm Serial ATA hard drive
6-in-1 media card reader
8x Multi-Format Double Layer DVD Writer (DVD±R/±RW/CD-RW)
Display
17" Ultrabright WSXGA+ TFT Active Matrix
1680 x 1050 max. resolution
Graphics
NVIDIA GeForce Go 7800 Graphics w/ 256MB DDR Video Memory
Communication
Integrated V.92 56K modem
Integrated Intel® 10/100/1000 Ethernet Adapter
Integrated Intel® 802.11a/b/g wireless networking card
Audio
Integrated sound and stereo speakers
Audio Chipset-SigmaTel 9250
SoundBlaster® Pro, MIDI and Windows® Sound System Compatible
3D Sound Support
Connectivity
One Type II PC Card Bus Slot
VGA Port
IEEE 1394 (4 pin)
4 version 2.0 USB Ports
RJ-45 Port
RJ-11 Port
16.06" x 10.89" x 1.24" – 1.42"
Approx. 7.7 lbs w/6-Cell Battery
Husk å plusse på 25% merverdihetssuperduperavgiftdrit..
5649205[/snapback]
Du har tydeligvis ikke lest traaden grundig nok, da jeg skriver at jeg er bosatt i USA.
Har ellers bestemt meg for og bestillt Hypersonic Laptopen da jeg onsker aa prioritere skjerm og batteri fremfor cpu teknologi.
Jeg vil tro ordet bosatt konkluderer den diskusjonen.
Uansett, saa ville den gaatt glatt gjennom toll saa lenge den er aapnet og brukt dersom jeg reiser inn sammen med minst en annen person.
Total kvote pr. person ved opphold utenfor norge i minst 24 timer er 6000,- kroner pr. pers.
En baerbar pc verdsatt til 14,000,- taper seg til godt under 12,000,- ved foerste gangs bruk, noe som gjor at den gaar under tollgrensen dersom jeg reiser sammen med en annen person (og hvor vanskelig er det aa finne en fremmed paa flyet som sier seg villig til aa la deg bruke hans/hennes del av kvoten? ikke saerlig vanskelig). Uansett, selv om jeg reiste alene ville jeg kun ha maattet betale delvis toll da det kun er verdi over 6000,- som det skal betales toll for.
Som sagt bor jeg i usa, saa dette er absolutt irrelevant.
En annen sak er at om jeg transporterer en baerbar pc i baereveske inn i Norge ville ikke tollen sett to ganger paa meg, da dette er en saapass vanlig ting aa ha med paa reise at de ikke vil anta at den er kjoept i utlandet og at jeg forsoeker aa "smugle" inn en pc.
Litt nyttig lesning finnes her til de som er spesiellt interessert i emnet: http://www.lovdata.no/cgi-wift/ldles?doc=/...110-0032.html#4
