rockybalboa Skrevet 19. februar 2006 Del Skrevet 19. februar 2006 hei har en ide/ata hdd på 200gb, under på kretskortet står det cable select, master, slave og pm2 hva betyr pm2 Lenke til kommentar
Hårek Skrevet 19. februar 2006 Del Skrevet 19. februar 2006 Western Digital disk? PM2 Mode – To designate the drive as power-up in standby (power management 2 or PM2) enabled, install the jumper shunt on pins 3 and 4. The mode enables controlled spinup, mainly used for server/workstation environments operating in multiple drive configurations. IMPORTANT: PM2 mode requires a compatible BIOS that supports this feature. If PM2 is enabled and not supported by BIOS, the drive will not spin up and therefore will not be detected by the system. Lenke til kommentar
