trådløst nett i ubuntu henger etter en stund[løst]
vet noen hva som kan være feilen? trådløst nett har fungert som en drøm, rett ut av boksen og alt, men nå slutter det å virke etter en liten stund. det fungerer igjen etter
sudo ifdown eth1 og
sudo ifup eth1
men det er jo litt plagsomt å gjøre det hvert 10.min.....
kjører ubuntu breezy på en acer med ipw2200.
forslag?
Endret av chrishan
gir dette noen mening?
chris@box:~$ dmesg | grep ipw220
[4294699.458000] ipw2200: Intel® PRO/Wireless 2200/2915 Network Driver, 1.0.6
[4294699.458000] ipw2200: Copyright© 2003-2004 Intel Corporation
[4294699.460000] ipw2200: Detected Intel PRO/Wireless 2200BG Network Connection
[4295884.457000] ipw2200: Firmware error detected. Restarting.
betyr det at jeg må ha ny firmware? hvordan gjør jeg det?
chris@box:~$ tail -f /var/log/messages
Feb 19 12:17:14 localhost kernel: [4294877.884000] atkbd.c: Unknown key released (translated set 2, code 0xaa on isa0060/serio0).
Feb 19 12:17:14 localhost kernel: [4294877.884000] atkbd.c: Use 'setkeycodes e02a <keycode>' to make it known.
Feb 19 12:17:14 localhost kernel: [4294878.014000] atkbd.c: Unknown key pressed (translated set 2, code 0xaa on isa0060/serio0).
Feb 19 12:17:14 localhost kernel: [4294878.014000] atkbd.c: Use 'setkeycodes e02a <keycode>' to make it known.
Feb 19 12:17:47 localhost kernel: [4294910.964000] atkbd.c: Unknown key released (translated set 2, code 0xaa on isa0060/serio0).
Feb 19 12:17:47 localhost kernel: [4294910.964000] atkbd.c: Use 'setkeycodes e02a <keycode>' to make it known.
Feb 19 12:17:47 localhost kernel: [4294911.159000] atkbd.c: Unknown key pressed (translated set 2, code 0xaa on isa0060/serio0).
Feb 19 12:17:47 localhost kernel: [4294911.159000] atkbd.c: Use 'setkeycodes e02a <keycode>' to make it known.
Feb 19 12:20:49 localhost exiting on signal 15
Feb 19 12:20:50 localhost syslogd 1.4.1#17ubuntu3: restart.
