DWPG.com: Dual Power Guide
Novec
DWPG.com har tatt en titt på hva Dual AMD kan være hvis det gjøres riktig - en kraftig arbeidsstasjon til uslåelig pris:
After using more "Build Your Own PC" web-applications and badly designed e-shops than I care to remember, I realized that consistently a dual AMD-rig seemed to offer by far the most performance for the buck -- in the high- end performance range at least. Curiously enough, these machines may not only be the cheapest, but also the most powerful.
Les hele artikkelen
