LCD Display med parallellport, overgang til USB?
Product Description
This cable converts USB signals to IEEE-1284 parallel signals, allowing your parallel printers to work in a USB environment. This converter supports virtually all Windows compatible printers. The cable allows the printer to connect to your PC's USB port, freeing the few parallel ports available on your PC for use with other devices such as Zip drives and cameras.
Product Features
USB (Universal Serial Bus) Rev. 1.1 compliant
Bi-directional parallel interface communication
Fully compatible with all parallel printers
Vil den virke på LCD skjerm da?.. virket som den kun var til skrivere.. Ser å sånn ut på pluggen.. Er typisk parallellport på en skriver
