AM2 med støtte for 800MHz DDR2
deep750
WE ALL expected that AMD planned to support DDR 2 400, 533 and 667 but very few of us expected that the firm plans to include DDR 2 800 MHz on its list. Before February, the plan was to support all memories up to DDR 667 but AMD eventually decided that it can and will support DDR 2 800 MHz from the outset. Now the migration to DDR 2 finally makes sense, as DDR 2 800 MHz can sure show sume difference compared with DDR 1 400 or even DDR 1 overclocked to 667.
It will simply offer more bandwidth and knowing that AMD places its memory controllers on the CPU it also means that it will show a bigger difference than Intel's DDR 2 capable chipsets.
Memory manufactures are thrilled as they will benefit the most. They will sell more DDR 2 800 than they ever imagined and the high end market along with mainstream will go toward the fast adoption of this fast memory.
AMD advises its partners to get some DDR 2 800 memory and to include it in DVT testing. It wants to be ready for all of the modules out there. DDR 2 also operates at a lower power level and it will indeed offer greater bandwidth. AMD thinks that the time is right for DDR 2. The desired speeds are there, it is available and the cost is just a little bit higher than DDR one. So there
Inquirer
Men alle tester viser jo at det er timing som er tingen for AMD sine CPU'er... ikke båndbredden... så why bother?  :ermm:
5621432[/snapback]
Raskere minne vil nok også føre til bedre ytelse, noe som AMD vil trenge mot Intel utover i året. Jeg tror nok at den integrérte minnekontrolleren til AMD har bidratt til suksess, og det vil muligens bli bedre med raskere minne?
