Jorek Skrevet 15. februar 2006 Del Skrevet 15. februar 2006 (endret) Jeg har funnet en flott side angående iptables. http://www.iptablesrocks.org/guide/ruleset.php Jeg prøver det scriptet som er oppført, bare noe modifisert, men jeg får denne feilen: root@darkstar:~# iptables-restore < /home/jorek/Firewall/firewall iptables-restore: line 3 failed Her er scriptet: #The Mangle portion of the ruleset. Here is where unwanted packet #types get dropped. #This helps in making port scans against your server a bit more #time consuming and difficult, but not impossible. *mangle :PREROUTING ACCEPT [444:43563] :INPUT ACCEPT [444:43563] :FORWARD ACCEPT [0:0] :OUTPUT ACCEPT [402:144198] :POSTROUTING ACCEPT [402:144198] -A PREROUTING -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG FIN,PSH,URG -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG NONE -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags SYN,RST SYN,RST -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags FIN,SYN FIN,SYN -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG FIN,PSH,URG -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG NONE -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags SYN,RST SYN,RST -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags FIN,SYN FIN,SYN -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG FIN,PSH,URG -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG NONE -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags SYN,RST SYN,RST -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags FIN,SYN FIN,SYN -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG FIN,PSH,URG -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG NONE -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags SYN,RST SYN,RST -j DROP -A PREROUTING -p tcp -m tcp --tcp-flags FIN,SYN FIN,SYN -j DROP COMMIT #The FILTER section of the ruleset is where we initially drop all #packets and then #selectively open certain ports. #We will also enable logging of all dropped requests. *filter :INPUT DROP [1:242] :FORWARD DROP [0:0] :OUTPUT DROP [0:0] :LOG_DROP - [0:0] :LOG_ACCEPT - [0:0] :icmp_packets - [0:0] #First, we cover the INPUT rules, or the rules for incoming requests. #Note how at the end we log any incoming packets that are not accepted. -A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT -A INPUT -p tcp -m tcp --dport 20 -j ACCEPT -A INPUT -p tcp -m tcp --dport 21 -j ACCEPT -A INPUT -p tcp -m tcp --dport 22 -j LOG_ACCEPT -A INPUT -p tcp -m tcp --dport 25 -j LOG_ACCEPT -A INPUT -p tcp -m tcp --dport 43 -j ACCEPT -A INPUT -p udp -m udp --dport 53 -j ACCEPT -A INPUT -p tcp -m tcp --dport 80 -j ACCEPT -A INPUT -p tcp -m tcp --dport 110 -j ACCEPT -A INPUT -p tcp -m tcp --dport 143 -j ACCEPT -A INPUT -p tcp -m tcp --dport 443 -j ACCEPT #uncomment the next line if you are running Spamassassin on your server #-A INPUT -p tcp -m tcp --dport 783 -j ACCEPT -A INPUT -p tcp -m tcp --dport 993 -j ACCEPT -A INPUT -p tcp -m tcp --dport 3306 -j ACCEPT -A INPUT -s 127.0.0.1 -j ACCEPT -A INPUT -p icmp -j icmp_packets -A INPUT -j LOG_DROP #Next, we cover the OUTPUT rules, or the rules for all outgoing traffic. #Note how at the end we log any outbound packets that are not accepted. -A OUTPUT -m state --state RELATED,ESTABLISHED -j ACCEPT -A OUTPUT -p tcp -m tcp --dport 20 -j ACCEPT -A OUTPUT -p tcp -m tcp --dport 21 -j ACCEPT -A OUTPUT -p tcp -m tcp --dport 22 -j ACCEPT -A OUTPUT -p tcp -m tcp --dport 23 -j ACCEPT -A OUTPUT -p tcp -m tcp --dport 25 -j ACCEPT -A OUTPUT -p tcp -m tcp --dport 43 -j ACCEPT -A OUTPUT -p udp -m udp --dport 53 -j ACCEPT -A OUTPUT -p tcp -m tcp --dport 80 -j ACCEPT -A OUTPUT -p tcp -m tcp --dport 110 -j ACCEPT -A OUTPUT -p tcp -m tcp --dport 143 -j ACCEPT -A OUTPUT -p tcp -m tcp --dport 443 -j ACCEPT #uncomment the next line if you are running Spamassassin on your server #-A OUTPUT -p tcp -m tcp --dport 783 -j ACCEPT -A OUTPUT -p tcp -m tcp --dport 993 -j ACCEPT -A OUTPUT -p tcp -m tcp --dport 3306 -j ACCEPT -A OUTPUT -d 127.0.0.1 -j ACCEPT -A OUTPUT -p icmp -j icmp_packets -A OUTPUT -j LOG_DROP #Here we have 2 sets of logging rules. One for dropped packets to log all dropped #requests and one for accepted packets, should we wish to log any accepted requesets. -A LOG_DROP -j LOG --log-prefix "[IPTABLES DROP] : " --log-tcp-options --log-ip-options -A LOG_DROP -j DROP -A LOG_ACCEPT -j LOG --log-prefix "[IPTABLES ACCEPT] : " --log-tcp-options --log-ip-options -A LOG_ACCEPT -j ACCEPT #And finally, a rule to deal with ICMP requests. We drop all ping requests except from #our own server. # Make sure you replace 1.2.3.4 with the IP address of your server. -A icmp_packets -p icmp -m icmp --icmp-type 0 -j ACCEPT # -A icmp_packets -s 1.2.3.4 -p icmp -m icmp --icmp-type 8 -j ACCEPT # -A icmp_packets -p icmp -m icmp --icmp-type 8 -j DROP # -A icmp_packets -p icmp -m icmp --icmp-type 3 -j ACCEPT # -A icmp_packets -p icmp -m icmp --icmp-type 11 -j ACCEPT COMMIT Skjønner at noe er galt på linje 3, man hva? Takker for all hjelp Endret 15. februar 2006 av Jorek Lenke til kommentar
Gjest Slettet+432 Skrevet 15. februar 2006 Del Skrevet 15. februar 2006 Det må være # foran alle linjer med kommentarer... Men det ble kanskje sånn når du limte det inn her? Lenke til kommentar
pgdx Skrevet 15. februar 2006 Del Skrevet 15. februar 2006 Ja, det er jo én ting, men jeg er usikker på om de linjene som er kommentert ut blir telt som linjer. Lenke til kommentar
Jorek Skrevet 15. februar 2006 Forfatter Del Skrevet 15. februar 2006 Det ble til når jeg la det ut her ja... Lenke til kommentar
Silvester Skrevet 16. februar 2006 Del Skrevet 16. februar 2006 Jeg ville heller anbefalt å lage to shellscript, en som rensker alle tables og plotter inn alt på nytt, og en som bare rensker. Da har du mer oversikt over hva du egentlig har. Lenke til kommentar
Jorek Skrevet 16. februar 2006 Forfatter Del Skrevet 16. februar 2006 Hmm, ok... Det er vel ikke tilfeldigvis noen som har noen enkle konfiger som tillater websurfing, MSN, osv, så jeg har noe å se på når jeg skriver mitt eget script? Jeg har prøvd en del ganger selv, men jeg får alltid et script som ikke funker... Hvis noen bare kunne pasta et script dem bruker ikke her, så hadde det hjulpet meg mye. Lenke til kommentar
