Noen som kan forklare detaljene i denne filen?
Dette er brannmuroppsettet "firewall.conf" fra pcworld.no tidligere i år.
Jeg spurte i denne tråden om noen hadde testet den - men nå lurer jeg på om noen kan forklare filen i detalj for meg ettersom jeg ikke finner igjen det aktuelle nummeret av PC World.
# **********IPtables initial configuration file************
# 192.168.1.213 is the address of the "outside" card (eth0)
# This must be replaced by the real address assigned by
# the ISP once the broadband connection is established.
# Our internal network is 192.168.2.x
#Flush all chains
iptables -F FORWARD
iptables -F INPUT
iptables -F OUTPUT
iptables -t nat -F POSTROUTING
# Set default policy of forward, input and output chain to DROP
# (reject everything)
iptables -P FORWARD DROP
iptables -P INPUT DROP
iptables -P OUTPUT DROP
#Allow ftp, mail, HTTP, pop and SSL/TLS
iptables -A FORWARD -p tcp -d 192.168.2.0/24 -m multiport
--sport 21,25,80,110,443 -m state --state ESTABLISHED -j ACCEPT
iptables -A FORWARD -p tcp -s 192.168.2.0/24 -m multiport
--dport 21,25,80,110,443 -m state --state NEW,ESTABLISHED -j ACCEPT
#DNS
iptables -A FORWARD -p udp -d 192.168.2.0/24 --sport 53 -j ACCEPT
iptables -A FORWARD -p udp -s 192.168.2.0/24 --dport 53 -j ACCEPT
#Allow active FTP
iptables -A FORWARD -p tcp -d 192.168.2.0/24 --sport 20 -m state
--state RELATED,ESTABLISHED -j ACCEPT
iptables -A FORWARD -p tcp -s 192.168.2.0/24 --dport 20 -m state
#Allow passive FTP
iptables -A FORWARD -p tcp -s 192.168.2.0/24 -m state
iptables -A FORWARD -p tcp -d 192.168.2.0/24 -m state
#Allow inside users to ping out but not vica versa
iptables -A FORWARD -p ICMP -d 192.168.2.0/24
--icmp-type echo-request -j DROP
iptables -A FORWARD -p ICMP -s 192.168.2.0/24
--icmp-type echo-reply -j DROP
#Allow all other ICMP packets
iptables -A FORWARD -p ICMP -j ACCEPT
#Set up NAT
iptables -t nat -A POSTROUTING -o eth0 -j SNAT --to 192.168.1.213
Quote:
Den 2002-09-21 08:01, skrev Dan Hansen:
Er det noenting som skulle tilsi at dette ikke ville fungere i FreeBSD?
Iptables er en Linux-ting og kan vel ikke kjøres i FreeBSD såvidt jeg vet. Poenget er at selv om iptables ser ut som et vanlig program, er det egentlig bare et grensesnitt fordi selve packet-filter softwaren ligger i Linux-kjernen.
I FreeBSD kan du bruke ipfilter eller ipfw. Sistnevnte er vel standard-programmet, mens førstnevnte er mer avansert (tror jeg da, har liten erfaring med *bsd :smile: )
