NettKid Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 Jeg har følgende maskin. CPU Info CPU 1/1 AMD Athlon XP 2500+ Architecture 32-bit Internal Clock 1.8 GHz Internal Clock Maximum 3.0 GHz (kan jeg overklokke prosesor ?) External Clock 166.0 MHz Socket Designation Socket A Upgrade ZIF Socket HyperThreadingTechnology N/A Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE, PAE Version AMD Athlon XP 2500+ Caches Level 1 128 KB Level 2 512 KB NVIDIA GeForce4 MX 440 Driver 5.2.1.6 Description NVIDIA GeForce4 MX 440 Manufacturer NVIDIA Total Local Video Memory 64 MB Total Local Texture Memory 96 MB VGA Memory Clock 405.0 MHz VGA Core Clock 270.0 MHz Memory Array 1/1 Max Module Capacity 2 MB Location System Board Use System Supported Speeds Supported Types Supported Voltages Memmory 1.5 GB Motherboard Info Supported Slot Types ISA, PCI, AGP Manufacturer ASUSTeK Computer INC. Model A7N8X2.0 Version REV 1.xx BIOS Vendor Phoenix Technologies, LTD BIOS Version ASUS A7N8X2.0 Deluxe ACPI BIOS Rev 1008 BIOS Release Date 08/04/2004 BIOS Properties Plug and Play, Flash, AGP AGP Revision 2.0 Rate 1x, 2x, 4x (1x enabled) Available Rate 0x00000007 Selected Rate 0x00000001 Aperture Size 0 B Sideband Addressing supported (disabled) Fast Write supported (disabled) Det jeg lurer på er om noen kan anbefale et nytt skjermkort slik at jeg får spilt CIV4. Helst AGP og under 1000. Hilsen Truls Lenke til kommentar
nightwo1f Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 (endret) Jeg har følgende maskin. CPU Info CPU 1/1 AMD Athlon XP 2500+ Architecture 32-bit Internal Clock 1.8 GHz Internal Clock Maximum 3.0 GHz (kan jeg overklokke prosesor ?) External Clock 166.0 MHz Socket Designation Socket A Upgrade ZIF Socket HyperThreadingTechnology N/A Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE, PAE Version AMD Athlon XP 2500+ Caches Level 1 128 KB Level 2 512 KB NVIDIA GeForce4 MX 440 Driver 5.2.1.6 Description NVIDIA GeForce4 MX 440 Manufacturer NVIDIA Total Local Video Memory 64 MB Total Local Texture Memory 96 MB VGA Memory Clock 405.0 MHz VGA Core Clock 270.0 MHz Memory Array 1/1 Max Module Capacity 2 MB Location System Board Use System Supported Speeds Supported Types Supported Voltages Memmory 1.5 GB Motherboard Info Supported Slot Types ISA, PCI, AGP Manufacturer ASUSTeK Computer INC. Model A7N8X2.0 Version REV 1.xx BIOS Vendor Phoenix Technologies, LTD BIOS Version ASUS A7N8X2.0 Deluxe ACPI BIOS Rev 1008 BIOS Release Date 08/04/2004 BIOS Properties Plug and Play, Flash, AGP AGP Revision 2.0 Rate 1x, 2x, 4x (1x enabled) Available Rate 0x00000007 Selected Rate 0x00000001 Aperture Size 0 B Sideband Addressing supported (disabled) Fast Write supported (disabled) Det jeg lurer på er om noen kan anbefale et nytt skjermkort slik at jeg får spilt CIV4. Helst AGP og under 1000. Hilsen Truls 5557627[/snapback] ja truls! nu ska du hør! ett kort førr unner 1000krone såmm e bra nokk t å kjør CIV4. d e mange d! mn her e ett æ vill anbefal: http://www.netshop.no/aspx/prdinfo.aspx?plid=1888 Endret 5. februar 2006 av nightwo1f Lenke til kommentar
NettKid Skrevet 5. februar 2006 Forfatter Del Skrevet 5. februar 2006 (endret) Prøver å finne frem til et brukt ett får da får jeg mest for penga. noen tips der mister. Jeg får 201 poeng i 3d Benchmark 03 første test for jeg har ikke regga produkte oppnåde 5000 ca i 01 .. Ekke det dårlig ?? Spiller også C&C GENERALS OG ettervert QUAKE 4 klarer det korte du anbefalte det og eller ? Endret 5. februar 2006 av NettKid Lenke til kommentar
SWAT dude... Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 (endret) jeg vil ikke anbefale kotet som Nightwo1f(elns) fant fram.. dette yter ikke godt nok i dagens spill osv (regner med at det er det som er hoved prior..) Kan absolutt ikke spille Q4 med det. vil heller annbefale det ett 6600GT kort som kansje koster ca 100-200,- mer enn det fyren over annbefalte og gir ca 7k i 3dmark03 (hvor du fikk ca200) med ett athlon XP system. Nightwo1f: gi FAEN i å skrive sånn fucka dialekt!! er jævelig irriterende å lese fjortizzz språk! EDIT: https://prisguiden.no/product.php?product_id=27095 EDIT: https://prisguiden.no/product.php?product_id=39236 med tanke på pris/ytelse er edit nr.1 absolutt beste kjøp! Endret 5. februar 2006 av SWAT dude... Lenke til kommentar
nightwo1f Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 jeg vil ikke anbefale kotet som Nightwo1f(elns) fant fram.. dette yter ikke godt nok i dagens spill osv (regner med at det er det som er hoved prior..) Kan absolutt ikke spille Q4 med det. vil heller annbefale det ett 6600GT kort som kansje koster ca 100-200,- mer enn det fyren over annbefalte og gir ca 7k i 3dmark03 (hvor du fikk ca200) med ett athlon XP system. Nightwo1f: gi FAEN i å skrive sånn fucka dialekt!! er jævelig irriterende å lese fjortizzz språk! EDIT: https://prisguiden.no/product.php?product_id=27095 EDIT: https://prisguiden.no/product.php?product_id=39236 med tanke på pris/ytelse er edit nr.1 absolutt beste kjøp! 5558074[/snapback] jaok! ska l ikke skrive dialekt! og er helt enig i at 6600gt er best! mn koster litt over 1000lappen. mn du blir garantert bedre ytelse! brukt kort vill jeg ikke anbefale! med mindre det er ifra nær kjenning. Lenke til kommentar
NettKid Skrevet 5. februar 2006 Forfatter Del Skrevet 5. februar 2006 jeg vil ikke anbefale kotet som Nightwo1f(elns) fant fram.. dette yter ikke godt nok i dagens spill osv (regner med at det er det som er hoved prior..) Kan absolutt ikke spille Q4 med det. vil heller annbefale det ett 6600GT kort som kansje koster ca 100-200,- mer enn det fyren over annbefalte og gir ca 7k i 3dmark03 (hvor du fikk ca200) med ett athlon XP system. Nightwo1f: gi FAEN i å skrive sånn fucka dialekt!! er jævelig irriterende å lese fjortizzz språk! EDIT: https://prisguiden.no/product.php?product_id=27095 EDIT: https://prisguiden.no/product.php?product_id=39236 med tanke på pris/ytelse er edit nr.1 absolutt beste kjøp! 5558074[/snapback] Jeg synes det er en herlig atmosfære her inne. Lurte også på et 6600 kort seru leste at det hadde slått et 6800 gt kort også her på hardware på test seksjonen. Men tror du det lar seg gjøre å kjøpe brukt. Er det mange som bytter ut gode kort frem over grunnet pci ekspress ?.. Vennlgi hilsen Truls Thunold Lenke til kommentar
SWAT dude... Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 (endret) 100,- for 100-200% høyere ytelse er ABSOLUTT verdt det! EDIT: http://bruktmarked.hardware.no/annonse.php?a=43201 Endret 5. februar 2006 av SWAT dude... Lenke til kommentar
Andrull Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 Som sagt så er 6600GT overlegen i ytelse i dette tilfellet. Gå for det! Brukt kort kan fint anbefales å kjøpe ifra. Men selvfølgelig hvis du er villig til å ta risken. (noe som blir som godt borte, ved gode avtaler på forhånd) Har selv kjøpt brukt skjermkort, og fikk et kort som var bedre enn det som var opplyst. Lenke til kommentar
NettKid Skrevet 5. februar 2006 Forfatter Del Skrevet 5. februar 2006 jeg vil ikke anbefale kotet som Nightwo1f(elns) fant fram.. dette yter ikke godt nok i dagens spill osv (regner med at det er det som er hoved prior..) Kan absolutt ikke spille Q4 med det. vil heller annbefale det ett 6600GT kort som kansje koster ca 100-200,- mer enn det fyren over annbefalte og gir ca 7k i 3dmark03 (hvor du fikk ca200) med ett athlon XP system. Nightwo1f: gi FAEN i å skrive sånn fucka dialekt!! er jævelig irriterende å lese fjortizzz språk! EDIT: https://prisguiden.no/product.php?product_id=27095 EDIT: https://prisguiden.no/product.php?product_id=39236 med tanke på pris/ytelse er edit nr.1 absolutt beste kjøp! 5558074[/snapback] Hvorfor ikke det ? et kort er et kort blir ikke akkurat så veldig slitt kan du si. jaok! ska l ikke skrive dialekt! og er helt enig i at 6600gt er best! mn koster litt over 1000lappen. mn du blir garantert bedre ytelse! brukt kort vill jeg ikke anbefale! med mindre det er ifra nær kjenning. 5558111[/snapback] Lenke til kommentar
nightwo1f Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 ta d 6600gt kortet du! du kan finne ett bedre kort till dn prisen brukt! men da må du som sagt stole 100% på selgeren. Lenke til kommentar
Duqe Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 hva med 9800pro? Du kan biosflashe til XT og klokke en del. http://www.netshop.no/aspx/prdinfo.aspx?plid=7157 Lenke til kommentar
nightwo1f Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 hva med 9800pro? Du kan biosflashe til XT og klokke en del. http://www.netshop.no/aspx/prdinfo.aspx?plid=7157 5558236[/snapback] fint kort det og! Lenke til kommentar
themanfrom Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 duqe77 kom med et greit forslag. nightwolf: Kan du lese retningslinjene, og nettiketten? SMS-språk og dialekt skal ikke brukes her inne. Lenke til kommentar
nightwo1f Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 duqe77 kom med et greit forslag. nightwolf: Kan du lese retningslinjene, og nettiketten? SMS-språk og dialekt skal ikke brukes her inne. 5558276[/snapback] sa jo at jeg ikke skulle bruke det!! blind eller:P ps:kan skrive d istedet for det av og til! uvane:( Lenke til kommentar
NettKid Skrevet 5. februar 2006 Forfatter Del Skrevet 5. februar 2006 Bios var å så på det club korte. kan du flæse biosen i det slik at det blir råere ? Lenke til kommentar
SWAT dude... Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 kan det ja men 6600GT er fortsatt bedere siden det har en del nyere finesser som bla SM3 Lenke til kommentar
Megnus Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 Gp for 6600GT ja.. X800 er jo også ett alternativ, hadde det bare ikke vært for shader model 3 støtten i 6600 som kan bli nyttig i fremtiden. Lenke til kommentar
Brusfantomet Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 6600 GT er vesentelig bedre en vilket som helst 9800 xt kort. 9800 xt korta kan kansje klare og ta igjen 6600 GT hvis de kjøles med flytende nitrogen og klokkes til døde og tilbake igjen. Lenke til kommentar
NettKid Skrevet 5. februar 2006 Forfatter Del Skrevet 5. februar 2006 DAkonkluderer jeg med 6600 gt hvis ikke bedre om man finner brukt ikke sant Takker for alle bra forslaga.. Lenke til kommentar
Megnus Skrevet 5. februar 2006 Del Skrevet 5. februar 2006 Det beste hadde vel egentlig vært å finne ett brukt 6800 kort av hvilket som heldst slag.. Lenke til kommentar
