wireless nett med d-link dwl-g520
Plages masse med å få mitt d-link dwl-g520 kort på nett o min linux maskin.
Noen som hadde kunne tatt kontakt på pm å hjulpet meg med linux maskinen og netteverkskortet mitt. Kjører med debian. har fått innstalert kortet, men får det ikke på nett, eller det får heller ikke ipadresse
Har plagdes i 1 uke. begynner å bli meget lei
Dmesg gir meg (en liten bit av det)
Linux agpgart interface v0.101 © Dave Jones
e100: Intel® PRO/100 Network Driver, 3.4.8-k2-NAPI
e100: Copyright© 1999-2005 Intel Corporation
PCI: Found IRQ 11 for device 0000:00:03.0
PCI: Sharing IRQ 11 with 0000:00:02.2
e100: eth0: e100_probe: addr 0xf3dff000, irq 11, MAC addr 00:04:AC9:9A:71
ath_hal: module license 'Proprietary' taints kernel.
ath_hal: 0.9.14.9 (AR5210, AR5211, AR5212, RF5111, RF5112, RF2413)
wlan: 0.8.6.0 (EXPERIMENTAL)
ath_rate_sample: 1.2
ath_pci: 0.9.6.0 (EXPERIMENTAL)
PCI: Found IRQ 10 for device 0000:00:10.0
Build date: Feb 4 2006
Debugging version (IEEE80211)
ath0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
ath0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
ath0: turboG rates: 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
ath0: H/W encryption support: WEP AES AES_CCM TKIP
ath0: mac 7.9 phy 4.5 radio 5.6
ath0: Use hw queue 1 for WME_AC_BE traffic
ath0: Use hw queue 0 for WME_AC_BK traffic
ath0: Use hw queue 2 for WME_AC_VI traffic
ath0: Use hw queue 3 for WME_AC_VO traffic
ath0: Use hw queue 8 for CAB traffic
ath0: Use hw queue 9 for beacons
ifconfig:
debian:~# ifconfig
eth0 Link encap:Ethernet HWaddr 00:04:AC9:9A:71
inet addr:192.168.0.103 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::204:acff:fed9:9a71/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:59661 errors:3 dropped:0 overruns:0 frame:3
TX packets:15554 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:39080338 (37.2 MiB) TX bytes:2094348 (1.9 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:39 errors:0 dropped:0 overruns:0 frame:0
TX packets:39 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1967 (1.9 KiB) TX bytes:1967 (1.9 KiB)
Iwconfig ath0:
debian:~# iwconfig ath0
ath0 IEEE 802.11 ESSID:""
Mode:Managed Frequency:2.412 GHz Access Point: 00:00:00:00:00:00
Bit Rate:0 kb/s Tx-Power:20 dBm Sensitivity=0/3
Retryff RTS thrff Fragment thrff
Encryption keyff
Power Managementff
Link Quality=0/94 Signal level=-95 dBm Noise level=-95 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
Jeg bruker debian
Har du forsøkt å sette essid? iwconfig ath0 essid <dinessid>
Også ifup ath0?
Det kan også være en god ide å ta ned eth0 før du tar opp ath0, det har hendt at jeg ikke har fått nett med et trådløst kort når eth0 har vært aktivert.
ifconfig eth0 down
Om du bruker Gnome skal det være mulig å sette opp dette via GUI.
