problem med configure
når jeg kjører dette ./confiure scriptet stoper der bare opp.. har googla litt og fant ut av mange har samma problemet. hvis man komenter ut der den ene delen så burde det jo funke..
checking for ping... /bin/ping
checking for ping6... /bin/ping6
checking for ICMP ping syntax... <--- her stopper det
noen som har peil på hvor feilen ligger eller hva jeg kan komentere ut?
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
# Generated automatically using autoconf version 2.13
# Copyright © 1992, 93, 94, 95, 96 Free Software Foundation, Inc.
# This configure script is free software; the Free Software Foundation
# gives unlimited permission to copy, distribute and modify it.
# Defaults:
ac_help=
ac_default_prefix=/usr/local
# Any additions from configure.in:
ac_default_prefix=/usr/local/nagios
ac_help="$ac_help
--with-nagios-user=<user> sets user name to run nagios"
ac_help="$ac_help
--with-nagios-grp=<grp> sets group name to run nagios"
ac_help="$ac_help
--with-mail=<path_to_mail> sets path to equivalent program to mail"
ac_help="$ac_help
--with-command-user=<user> sets user name for command access"
ac_help="$ac_help
--with-command-grp=<grp> sets group name for command access"
ac_help="$ac_help
--with-init-dir=<path> sets directory to place init script into"
ac_help="$ac_help
--with-lockfile=<path> sets path and file name for lock file"
ac_help="$ac_help
--with-mysql-xdata enables use of MySQL database for all external data types except objects"
ac_help="$ac_help
--with-pgsql-xdata enables use of PostgreSQL database for all external data types except objects"
ac_help="$ac_help
--with-mysql-status enables use of MySQL database for storage of status data"
ac_help="$ac_help
--with-pgsql-status enables use of PostgreSQL database for storage of status data"
ac_help="$ac_help
--with-default-status enables use of default status data routines"
ac_help="$ac_help
--with-mysql-comments enables use of MySQL database for storage of comment data"
ac_help="$ac_help
--with-pgsql-comments enables use of PostgreSQL database for storage of comment data"
ac_help="$ac_help
--with-default-comments enables use of default comment data routines"
ac_help="$ac_help
--with-mysql-extinfo enables use of MySQL database for storage of extended data"
ac_help="$ac_help
--with-pgsql-extinfo enables use of PostgreSQL database for storage of extended data"
ac_help="$ac_help
--with-default-extinfo enables use of default extended data routines"
ac_help="$ac_help
--with-template-extinfo enables use of template-based extended info data routines"
ac_help="$ac_help
--with-mysql-retention enables use of MySQL database for storage of retention data"
ac_help="$ac_help
--with-pgsql-retention enables use of PostgresSQL database for storage of retention data"
ac_help="$ac_help
--with-default-retention enables use of default retention data routines"
ac_help="$ac_help
--with-default-objects enables use of default object data routines"
ac_help="$ac_help
--with-template-objects enables use of template-based object data routines"
ac_help="$ac_help
--with-default-perfdata enables use of default performance data routines"
ac_help="$ac_help
--with-file-perfdata enables use of file-based performance data routines"
ac_help="$ac_help
--with-mysql-downtime enables use of MySQL database for storage of scheduled downtime data"
ac_help="$ac_help
--with-pgsql-downtime enables use of PostgreSQL database for storage of scheduled downtime data"
ac_help="$ac_help
--with-default-downtime enables use of default scheduled downtime data routines"
ac_help="$ac_help
--with-mysql-lib=DIR sets location of the MySQL client library"
ac_help="$ac_help
--with-mysql-inc=DIR sets location of the MySQL client include files"
ac_help="$ac_help
--with-pgsql-lib=DIR sets location of the PostgreSQL client library"
ac_help="$ac_help
--with-pgsql-inc=DIR sets location of the PostgreSQL client include files"
ac_help="$ac_help
--with-gd-lib=DIR sets location of the gd library"
ac_help="$ac_help
--with-gd-inc=DIR sets location of the gd include files"
ac_help="$ac_help
--disable-statusmap=disables compilation of statusmap CGI"
ac_help="$ac_help
--disable-statuswrl=disables compilation of statuswrl (VRML) CGI"
ac_help="$ac_help
--with-cgiurl=<local-url> sets URL for cgi programs (do not use a trailing slash)"
ac_help="$ac_help
--with-htmurl=<local-url> sets URL for public html"
ac_help="$ac_help
--enable-DEBUG0 shows function entry and exit"
ac_help="$ac_help
--enable-DEBUG1 shows general info messages"
ac_help="$ac_help
--enable-DEBUG2 shows warning messages"
ac_help="$ac_help
--enable-DEBUG3 shows scheduled events (service and host checks... etc)"
ac_help="$ac_help
--enable-DEBUG4 shows service and host notifications"
ac_help="$ac_help
--enable-DEBUG5 shows SQL queries"
ac_help="$ac_help
--enable-embedded-perl will enable embedded Perl interpreter"
ac_help="$ac_help
--with-perlcache turns on cacheing of internally compiled Perl scripts"
ac_help="$ac_help
--enable-cygwin enables building under the CYGWIN environment"
# Initialize some variables set by options.
# The variables have the same names as the options, with
# dashes changed to underlines.
build=NONE
cache_file=./config.cache
exec_prefix=NONE
host=NONE
no_create=
nonopt=NONE
no_recursion=
prefix=NONE
program_prefix=NONE
program_suffix=NONE
program_transform_name=s,x,x,
silent=
site=
srcdir=
target=NONE
verbose=
x_includes=NONE
x_libraries=NONE
bindir='${exec_prefix}/bin'
sbindir='${exec_prefix}/sbin'
libexecdir='${exec_prefix}/libexec'
datadir='${prefix}/share'
sysconfdir='${prefix}/etc'
sharedstatedir='${prefix}/com'
localstatedir='${prefix}/var'
libdir='${exec_prefix}/lib'
includedir='${prefix}/include'
oldincludedir='/usr/include'
infodir='${prefix}/info'
mandir='${prefix}/man'
# Initialize some other variables.
subdirs=
MFLAGS= MAKEFLAGS=
SHELL=${CONFIG_SHELL-/bin/sh}
# Maximum number of lines to put in a shell here document.
ac_max_here_lines=12
ac_prev=
for ac_option
do
  # If the previous option needs an argument, assign it.
  if test -n "$ac_prev"; then
    eval "$ac_prev=\$ac_option"
    ac_prev=
    continue
  fi
  case "$ac_option" in
  -*=*) ac_optarg=`echo "$ac_option" | sed 's/[-_a-zA-Z0-9]*=//'` ;;
  *) ac_optarg= ;;
  esac
  # Accept the important Cygnus configure options, so we can diagnose typos.
  -bindir | --bindir | --bindi | --bind | --bin | --bi)
    ac_prev=bindir ;;
  -bindir=* | --bindir=* | --bindi=* | --bind=* | --bin=* | --bi=*)
    bindir="$ac_optarg" ;;
  -build | --build | --buil | --bui | --bu)
    ac_prev=build ;;
  -build=* | --build=* | --buil=* | --bui=* | --bu=*)
    build="$ac_optarg" ;;
  -cache-file | --cache-file | --cache-fil | --cache-fi \
  | --cache-f | --cache- | --cache | --cach | --cac | --ca | --c)
    ac_prev=cache_file ;;
  -cache-file=* | --cache-file=* | --cache-fil=* | --cache-fi=* \
  | --cache-f=* | --cache-=* | --cache=* | --cach=* | --cac=* | --ca=* | --c=*)
    cache_file="$ac_optarg" ;;
  -datadir | --datadir | --datadi | --datad | --data | --dat | --da)
    ac_prev=datadir ;;
  -datadir=* | --datadir=* | --datadi=* | --datad=* | --data=* | --dat=* \
  | --da=*)
    datadir="$ac_optarg" ;;
  -disable-* | --disable-*)
    ac_feature=`echo $ac_option|sed -e 's/-*disable-//'`
    # Reject names that are not valid shell variable names.
    if test -n "`echo $ac_feature| sed 's/[-a-zA-Z0-9_]//g'`"; then
      { echo "configure: error: $ac_feature: invalid feature name" 1>&2; exit 1; }
    fi
    ac_feature=`echo $ac_feature| sed 's/-/_/g'`
    eval "enable_${ac_feature}=no" ;;
  -enable-* | --enable-*)
    ac_feature=`echo $ac_option|sed -e 's/-*enable-//' -e 's/=.*//'`
    if test -n "`echo $ac_feature| sed 's/[-_a-zA-Z0-9]//g'`"; then
    fi
      *) ac_optarg=yes ;;
    esac
    eval "enable_${ac_feature}='$ac_optarg'" ;;
  -exec-prefix | --exec_prefix | --exec-prefix | --exec-prefi \
  | --exec-pref | --exec-pre | --exec-pr | --exec-p | --exec- \
  | --exec | --exe | --ex)
    ac_prev=exec_prefix ;;
  -exec-prefix=* | --exec_prefix=* | --exec-prefix=* | --exec-prefi=* \
  | --exec-pref=* | --exec-pre=* | --exec-pr=* | --exec-p=* | --exec-=* \
  | --exec=* | --exe=* | --ex=*)
    exec_prefix="$ac_optarg" ;;
  -gas | --gas | --ga | --g)
    # Obsolete; use --with-gas.
    with_gas=yes ;;
  -help | --help | --hel | --he)
    # Omit some internal or obsolete options to make the list less imposing.
    # This message is too long to be a string in the A/UX 3.1 sh.
    cat << EOF
Usage: configure [options] [host]
Options: [defaults in brackets after descriptions]
Configuration:
  --cache-file=FILE      cache test results in FILE
  --help                  print this message
  --no-create            do not create output files
  --quiet, --silent      do not print \`checking...' messages
  --version              print the version of autoconf that created configure
Directory and file names:
  --prefix=PREFIX        install architecture-independent files in PREFIX
                          [$ac_default_prefix]
  --exec-prefix=EPREFIX  install architecture-dependent files in EPREFIX
                          [same as prefix]
  --bindir=DIR            user executables in DIR [EPREFIX/bin]
  --sbindir=DIR          system admin executables in DIR [EPREFIX/sbin]
  --libexecdir=DIR        program executables in DIR [EPREFIX/libexec]
  --datadir=DIR          read-only architecture-independent data in DIR
                          [PREFIX/share]
  --sysconfdir=DIR        read-only single-machine data in DIR [PREFIX/etc]
  --sharedstatedir=DIR    modifiable architecture-independent data in DIR
                          [PREFIX/com]
  --localstatedir=DIR    modifiable single-machine data in DIR [PREFIX/var]
  --libdir=DIR            object code libraries in DIR [EPREFIX/lib]
  --includedir=DIR        C header files in DIR [PREFIX/include]
  --oldincludedir=DIR    C header files for non-gcc in DIR [/usr/include]
  --infodir=DIR          info documentation in DIR [PREFIX/info]
  --mandir=DIR            man documentation in DIR [PREFIX/man]
  --srcdir=DIR            find the sources in DIR [configure dir or ..]
  --program-prefix=PREFIX prepend PREFIX to installed program names
  --program-suffix=SUFFIX append SUFFIX to installed program names
  --program-transform-name=PROGRAM
                          run sed PROGRAM on installed program names
EOF
    cat << EOF
Host type:
  --build=BUILD          configure for building on BUILD [bUILD=HOST]
  --host=HOST            configure for HOST [guessed]
  --target=TARGET        configure for TARGET [TARGET=HOST]
Features and packages:
  --disable-FEATURE      do not include FEATURE (same as --enable-FEATURE=no)
  --enable-FEATURE[=ARG]  include FEATURE [ARG=yes]
  --with-PACKAGE[=ARG]    use PACKAGE [ARG=yes]
  --without-PACKAGE      do not use PACKAGE (same as --with-PACKAGE=no)
  --x-includes=DIR        X include files are in DIR
  --x-libraries=DIR      X library files are in DIR
EOF
    if test -n "$ac_help"; then
      echo "--enable and --with options recognized:$ac_help"
    fi
    exit 0 ;;
  -host | --host | --hos | --ho)
    ac_prev=host ;;
  -host=* | --host=* | --hos=* | --ho=*)
    host="$ac_optarg" ;;
  -includedir | --includedir | --includedi | --included | --include \
  | --includ | --inclu | --incl | --inc)
    ac_prev=includedir ;;
  -includedir=* | --includedir=* | --includedi=* | --included=* | --include=* \
  | --includ=* | --inclu=* | --incl=* | --inc=*)
    includedir="$ac_optarg" ;;
  -infodir | --infodir | --infodi | --infod | --info | --inf)
    ac_prev=infodir ;;
  -infodir=* | --infodir=* | --infodi=* | --infod=* | --info=* | --inf=*)
    infodir="$ac_optarg" ;;
  -libdir | --libdir | --libdi | --libd)
    ac_prev=libdir ;;
  -libdir=* | --libdir=* | --libdi=* | --libd=*)
    libdir="$ac_optarg" ;;
  -libexecdir | --libexecdir | --libexecdi | --libexecd | --libexec \
  | --libexe | --libex | --libe)
    ac_prev=libexecdir ;;
  -libexecdir=* | --libexecdir=* | --libexecdi=* | --libexecd=* | --libexec=* \
  | --libexe=* | --libex=* | --libe=*)
    libexecdir="$ac_optarg" ;;
  -localstatedir | --localstatedir | --localstatedi | --localstated \
  | --localstate | --localstat | --localsta | --localst \
  | --locals | --local | --loca | --loc | --lo)
    ac_prev=localstatedir ;;
  -localstatedir=* | --localstatedir=* | --localstatedi=* | --localstated=* \
  | --localstate=* | --localstat=* | --localsta=* | --localst=* \
  | --locals=* | --local=* | --loca=* | --loc=* | --lo=*)
    localstatedir="$ac_optarg" ;;
  -mandir | --mandir | --mandi | --mand | --man | --ma | --m)
    ac_prev=mandir ;;
  -mandir=* | --mandir=* | --mandi=* | --mand=* | --man=* | --ma=* | --m=*)
    mandir="$ac_optarg" ;;
  -nfp | --nfp | --nf)
    # Obsolete; use --without-fp.
    with_fp=no ;;
  -no-create | --no-create | --no-creat | --no-crea | --no-cre \
  | --no-cr | --no-c)
    no_create=yes ;;
  -no-recursion | --no-recursion | --no-recursio | --no-recursi \
  | --no-recurs | --no-recur | --no-recu | --no-rec | --no-re | --no-r)
    no_recursion=yes ;;
  -oldincludedir | --oldincludedir | --oldincludedi | --oldincluded \
  | --oldinclude | --oldinclud | --oldinclu | --oldincl | --oldinc \
  | --oldin | --oldi | --old | --ol | --o)
    ac_prev=oldincludedir ;;
  -oldincludedir=* | --oldincludedir=* | --oldincludedi=* | --oldincluded=* \
  | --oldinclude=* | --oldinclud=* | --oldinclu=* | --oldincl=* | --oldinc=* \
  | --oldin=* | --oldi=* | --old=* | --ol=* | --o=*)
    oldincludedir="$ac_optarg" ;;
  -prefix | --prefix | --prefi | --pref | --pre | --pr | --p)
    ac_prev=prefix ;;
  -prefix=* | --prefix=* | --prefi=* | --pref=* | --pre=* | --pr=* | --p=*)
  -program-prefix | --program-prefix | --program-prefi | --program-pref \
  | --program-pre | --program-pr | --program-p)
    ac_prev=program_prefix ;;
  -program-prefix=* | --program-prefix=* | --program-prefi=* \
  | --program-pref=* | --program-pre=* | --program-pr=* | --program-p=*)
    program_prefix="$ac_optarg" ;;
  -program-suffix | --program-suffix | --program-suffi | --program-suff \
  | --program-suf | --program-su | --program-s)
    ac_prev=program_suffix ;;
  -program-suffix=* | --program-suffix=* | --program-suffi=* \
  | --program-suff=* | --program-suf=* | --program-su=* | --program-s=*)
    program_suffix="$ac_optarg" ;;
  -program-transform-name | --program-transform-name \
  | --program-transform-nam | --program-transform-na \
  | --program-transform-n | --program-transform- \
  | --program-transform | --program-transfor \
  | --program-transfo | --program-transf \
  | --program-trans | --program-tran \
  | --progr-tra | --program-tr | --program-t)
    ac_prev=program_transform_name ;;
  -program-transform-name=* | --program-transform-name=* \
  | --program-transform-nam=* | --program-transform-na=* \
  | --program-transform-n=* | --program-transform-=* \
  | --program-transform=* | --program-transfor=* \
  | --program-transfo=* | --program-transf=* \
  | --program-trans=* | --program-tran=* \
  | --progr-tra=* | --program-tr=* | --program-t=*)
    program_transform_name="$ac_optarg" ;;
  -q | -quiet | --quiet | --quie | --qui | --qu | --q \
  | -silent | --silent | --silen | --sile | --sil)
    silent=yes ;;
  -sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb)
    ac_prev=sbindir ;;
  -sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \
  | --sbi=* | --sb=*)
    sbindir="$ac_optarg" ;;
  -sharedstatedir | --sharedstatedir | --sharedstatedi \
  | --sharedstated | --sharedstate | --sharedstat | --sharedsta \
  | --sharedst | --shareds | --shared | --share | --shar \
  | --sha | --sh)
    ac_prev=sharedstatedir ;;
  -sharedstatedir=* | --sharedstatedir=* | --sharedstatedi=* \
  | --sharedstated=* | --sharedstate=* | --sharedstat=* | --sharedsta=* \
  | --sharedst=* | --shareds=* | --shared=* | --share=* | --shar=* \
  | --sha=* | --sh=*)
    sharedstatedir="$ac_optarg" ;;
  -site | --site | --sit)
    ac_prev=site ;;
  -site=* | --site=* | --sit=*)
    site="$ac_optarg" ;;
  -srcdir | --srcdir | --srcdi | --srcd | --src | --sr)
    ac_prev=srcdir ;;
  -srcdir=* | --srcdir=* | --srcdi=* | --srcd=* | --src=* | --sr=*)
    srcdir="$ac_optarg" ;;
  -sysconfdir | --sysconfdir | --sysconfdi | --sysconfd | --sysconf \
  | --syscon | --sysco | --sysc | --sys | --sy)
    ac_prev=sysconfdir ;;
  -sysconfdir=* | --sysconfdir=* | --sysconfdi=* | --sysconfd=* | --sysconf=* \
  | --syscon=* | --sysco=* | --sysc=* | --sys=* | --sy=*)
    sysconfdir="$ac_optarg" ;;
  -target | --target | --targe | --targ | --tar | --ta | --t)
    ac_prev=target ;;
  -target=* | --target=* | --targe=* | --targ=* | --tar=* | --ta=* | --t=*)
    target="$ac_optarg" ;;
  -v | -verbose | --verbose | --verbos | --verbo | --verb)
    verbose=yes ;;
  -version | --version | --versio | --versi | --vers)
    echo "configure generated by autoconf version 2.13"
    exit 0 ;;
  -with-* | --with-*)
    ac_package=`echo $ac_option|sed -e 's/-*with-//' -e 's/=.*//'`
    if test -n "`echo $ac_package| sed 's/[-_a-zA-Z0-9]//g'`"; then
      { echo "configure: error: $ac_package: invalid package name" 1>&2; exit 1; }
    fi
    ac_package=`echo $ac_package| sed 's/-/_/g'`
      *) ac_optarg=yes ;;
    esac
    eval "with_${ac_package}='$ac_optarg'" ;;
  -without-* | --without-*)
    ac_package=`echo $ac_option|sed -e 's/-*without-//'`
    if test -n "`echo $ac_package| sed 's/[-a-zA-Z0-9_]//g'`"; then
    fi
    eval "with_${ac_package}=no" ;;
  --x)
    # Obsolete; use --with-x.
    with_x=yes ;;
  -x-includes | --x-includes | --x-include | --x-includ | --x-inclu \
  | --x-incl | --x-inc | --x-in | --x-i)
    ac_prev=x_includes ;;
  -x-includes=* | --x-includes=* | --x-include=* | --x-includ=* | --x-inclu=* \
  | --x-incl=* | --x-inc=* | --x-in=* | --x-i=*)
    x_includes="$ac_optarg" ;;
  -x-libraries | --x-libraries | --x-librarie | --x-librari \
  | --x-librar | --x-libra | --x-libr | --x-lib | --x-li | --x-l)
    ac_prev=x_libraries ;;
  -x-libraries=* | --x-libraries=* | --x-librarie=* | --x-librari=* \
  | --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*)
    x_libraries="$ac_optarg" ;;
  -*) { echo "configure: error: $ac_option: invalid option; use --help to show usage" 1>&2; exit 1; }
    if test -n "`echo $ac_option| sed 's/[-a-z0-9.]//g'`"; then
      echo "configure: warning: $ac_option: invalid host type" 1>&2
    fi
    if test "x$nonopt" != xNONE; then
      { echo "configure: error: can only configure for one host and one target at a time" 1>&2; exit 1; }
    fi
    nonopt="$ac_option"
  esac
done
  { echo "configure: error: missing argument to --`echo $ac_prev | sed 's/_/-/g'`" 1>&2; exit 1; }
fi
trap 'rm -fr conftest* confdefs* core core.* *.core $ac_clean_files; exit 1' 1 2 15
# File descriptor usage:
# 0 standard input
# 1 file creation
# 2 errors and warnings
# 3 some systems may open it to /dev/tty
# 4 used on the Kubota Titan
# 6 checking for... messages and results
# 5 compiler messages saved in config.log
if test "$silent" = yes; then
  exec 6>/dev/null
else
  exec 6>&1
fi
exec 5>./config.log
echo "\
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
" 1>&5
# Strip out --no-create and --no-recursion so they do not pile up.
# Also quote any args containing shell metacharacters.
ac_configure_args=
for ac_arg
do
  case "$ac_arg" in
  | --no-cr | --no-c) ;;
  | --no-recurs | --no-recur | --no-recu | --no-rec | --no-re | --no-r) ;;
  ac_configure_args="$ac_configure_args '$ac_arg'" ;;
  *) ac_configure_args="$ac_configure_args $ac_arg" ;;
  esac
done
# NLS nuisances.
# Only set these to C if already set.  These must not be set unconditionally
# because not all systems understand e.g. LANG=C (notably SCO).
# Fixing LC_MESSAGES prevents Solaris sh from translating var values in `set'!
# Non-C LC_CTYPE values break the ctype check.
if test "${LANG+set}"  = set; then LANG=C;  export LANG;  fi
if test "${LC_ALL+set}" = set; then LC_ALL=C; export LC_ALL; fi
if test "${LC_MESSAGES+set}" = set; then LC_MESSAGES=C; export LC_MESSAGES; fi
if test "${LC_CTYPE+set}"    = set; then LC_CTYPE=C;    export LC_CTYPE;    fi
# confdefs.h avoids OS command line length limits that DEFS can exceed.
rm -rf conftest* confdefs.h
# AIX cpp loses on an empty file, so make sure it contains at least a newline.
echo > confdefs.h
# A filename unique to this package, relative to the directory that
# configure is in, which we can look for to find out if srcdir is correct.
ac_unique_file=base/nagios.c
# Find the source files, if location was not specified.
if test -z "$srcdir"; then
  ac_srcdir_defaulted=yes
  # Try the directory containing this script, then its parent.
  ac_prog=$0
  ac_confdir=`echo $ac_prog|sed 's%/[^/][^/]*$%%'`
  test "x$ac_confdir" = "x$ac_prog" && ac_confdir=.
  srcdir=$ac_confdir
  if test ! -r $srcdir/$ac_unique_file; then
    srcdir=..
  fi
else
  ac_srcdir_defaulted=no
fi
  if test "$ac_srcdir_defaulted" = yes; then
    { echo "configure: error: can not find sources in $ac_confdir or .." 1>&2; exit 1; }
  else
    { echo "configure: error: can not find sources in $srcdir" 1>&2; exit 1; }
  fi
fi
srcdir=`echo "${srcdir}" | sed 's%\([^/]\)/*$%\1%'`
# Prefer explicitly selected file to automatically selected ones.
if test -z "$CONFIG_SITE"; then
  if test "x$prefix" != xNONE; then
    CONFIG_SITE="$prefix/share/config.site $prefix/etc/config.site"
  else
    CONFIG_SITE="$ac_default_prefix/share/config.site $ac_default_prefix/etc/config.site"
  fi
fi
for ac_site_file in $CONFIG_SITE; do
  if test -r "$ac_site_file"; then
    echo "loading site script $ac_site_file"
    . "$ac_site_file"
  fi
done
if test -r "$cache_file"; then
  echo "loading cache $cache_file"
  . $cache_file
else
  echo "creating cache $cache_file"
  > $cache_file
fi
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
ac_cpp='$CPP $CPPFLAGS'
ac_compile='${CC-cc} -c $CFLAGS $CPPFLAGS conftest.$ac_ext 1>&5'
ac_link='${CC-cc} -o conftest${ac_exeext} $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS 1>&5'
cross_compiling=$ac_cv_prog_cc_cross
ac_exeext=
ac_objext=o
if (echo "testing\c"; echo 1,2,3) | grep c >/dev/null; then
  # Stardent Vistra SVR4 grep lacks -e, says [email protected].
  if (echo -n testing; echo 1,2,3) | sed s/-n/xn/ | grep xn >/dev/null; then
    ac_n= ac_c='
' ac_t=' '
  else
    ac_n=-n ac_c= ac_t=
  fi
else
  ac_n= ac_c='\c' ac_t=
fi
PKG_NAME=nagios
PKG_VERSION="1.3"
PKG_HOME_URL="http://www.nagios.org/"
PKG_REL_DATE="11-17-2005"
ac_aux_dir=
for ac_dir in $srcdir $srcdir/.. $srcdir/../..; do
  if test -f $ac_dir/install-sh; then
    ac_aux_dir=$ac_dir
    ac_install_sh="$ac_aux_dir/install-sh -c"
    break
  elif test -f $ac_dir/install.sh; then
    ac_aux_dir=$ac_dir
    ac_install_sh="$ac_aux_dir/install.sh -c"
    break
  fi
done
if test -z "$ac_aux_dir"; then
  { echo "configure: error: can not find install-sh or install.sh in $srcdir $srcdir/.. $srcdir/../.." 1>&2; exit 1; }
fi
ac_config_guess=$ac_aux_dir/config.guess
ac_config_sub=$ac_aux_dir/config.sub
ac_configure=$ac_aux_dir/configure # This should be Cygnus configure.
# Find a good install program.  We prefer a C program (faster),
# so one script is as good as another.  But avoid the broken or
# incompatible versions:
# SysV /etc/install, /usr/sbin/install
# SunOS /usr/etc/install
# IRIX /sbin/install
# AIX /bin/install
# AIX 4 /usr/bin/installbsd, which doesn't work without a -g flag
# AFS /usr/afsws/bin/install, which mishandles nonexistent args
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
echo "configure:661: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
if eval "test \"`echo '$''{'ac_cv_path_install'+set}'`\" = set"; then
  echo $ac_n "(cached) $ac_c" 1>&6
else
    IFS="${IFS=  }"; ac_save_IFS="$IFS"; IFS=":"
  for ac_dir in $PATH; do
    # Account for people who put trailing slashes in PATH elements.
    case "$ac_dir/" in
    /|./|.//|/etc/*|/usr/sbin/*|/usr/etc/*|/sbin/*|/usr/afsws/bin/*|/usr/ucb/*) ;;
      # OSF1 and SCO ODT 3.0 have their own names for install.
      # Don't use installbsd from OSF since it installs stuff as root
      # by default.
      for ac_prog in ginstall scoinst install; do
        if test -f $ac_dir/$ac_prog; then
  if test $ac_prog = install &&
            grep dspmsg $ac_dir/$ac_prog >/dev/null 2>&1; then
    # AIX install.  It has an incompatible calling convention.
  else
    ac_cv_path_install="$ac_dir/$ac_prog -c"
    break 2
  fi
fi
      done
    esac
  done
  IFS="$ac_save_IFS"
fi
  if test "${ac_cv_path_install+set}" = set; then
    INSTALL="$ac_cv_path_install"
  else
    # As a last resort, use the slow shell script.  We don't cache a
    # path for INSTALL within a source directory, because that will
    # break other packages using the cache if that directory is
    # removed, or if the path is relative.
    INSTALL="$ac_install_sh"
  fi
fi
echo "$ac_t""$INSTALL" 1>&6
# Use test -z because SunOS4 sh mishandles braces in ${var-val}.
# It thinks the first close brace ends the variable substitution.
test -z "$INSTALL_PROGRAM" && INSTALL_PROGRAM='${INSTALL}'
test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL_PROGRAM}'
test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644'
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
echo "configure:719: checking for $ac_word" >&5
if eval "test \"`echo '$''{'ac_cv_prog_CC'+set}'`\" = set"; then
else
  if test -n "$CC"; then
  ac_cv_prog_CC="$CC" # Let the user override the test.
else
  IFS="${IFS=  }"; ac_save_ifs="$IFS"; IFS=":"
  ac_dummy="$PATH"
  for ac_dir in $ac_dummy; do
    test -z "$ac_dir" && ac_dir=.
    if test -f $ac_dir/$ac_word; then
      ac_cv_prog_CC="gcc"
      break
    fi
  done
  IFS="$ac_save_ifs"
fi
fi
CC="$ac_cv_prog_CC"
  echo "$ac_t""$CC" 1>&6
else
  echo "$ac_t""no" 1>&6
fi
if test -z "$CC"; then
  # Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
echo "configure:749: checking for $ac_word" >&5
else
else
  ac_prog_rejected=no
  ac_dummy="$PATH"
      if test "$ac_dir/$ac_word" = "/usr/ucb/cc"; then
        ac_prog_rejected=yes
continue
      fi
      ac_cv_prog_CC="cc"
      break
    fi
  done
  IFS="$ac_save_ifs"
if test $ac_prog_rejected = yes; then
  # We found a bogon in the path, so make sure we never use it.
  set dummy $ac_cv_prog_CC
  shift
  if test $# -gt 0; then
    # We chose a different compiler from the bogus one.
    # However, it has the same basename, so the bogon will be chosen
    # first if we set CC to just the basename; use the full file name.
    shift
    set dummy "$ac_dir/$ac_word" "$@"
    shift
    ac_cv_prog_CC="$@"
  fi
fi
fi
fi
CC="$ac_cv_prog_CC"
else
fi
    case "`uname -s`" in
    *win32* | *WIN32*)
      # Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
echo "configure:800: checking for $ac_word" >&5
else
else
  ac_dummy="$PATH"
      ac_cv_prog_CC="cl"
      break
    fi
  done
  IFS="$ac_save_ifs"
fi
fi
CC="$ac_cv_prog_CC"
else
fi
    esac
  fi
  test -z "$CC" && { echo "configure: error: no acceptable cc found in \$PATH" 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
echo "configure:832: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
cat > conftest.$ac_ext << EOF
#line 843 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
if { (eval echo configure:848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
  ac_cv_prog_cc_works=yes
  # If we can't run a trivial program, we are probably using a cross compiler.
  if (./conftest; exit) 2>/dev/null; then
    ac_cv_prog_cc_cross=no
  else
    ac_cv_prog_cc_cross=yes
  fi
else
  echo "configure: failed program was:" >&5
  cat conftest.$ac_ext >&5
  ac_cv_prog_cc_works=no
fi
rm -fr conftest*
ac_ext=c
echo "$ac_t""$ac_cv_prog_cc_works" 1>&6
if test $ac_cv_prog_cc_works = no; then
  { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
echo "configure:874: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
echo "configure:879: checking whether we are using GNU C" >&5
if eval "test \"`echo '$''{'ac_cv_prog_gcc'+set}'`\" = set"; then
else
  cat > conftest.c <<EOF
#ifdef __GNUC__
  yes;
#endif
EOF
if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:888: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
  ac_cv_prog_gcc=yes
else
  ac_cv_prog_gcc=no
fi
fi
echo "$ac_t""$ac_cv_prog_gcc" 1>&6
if test $ac_cv_prog_gcc = yes; then
  GCC=yes
else
  GCC=
fi
ac_test_CFLAGS="${CFLAGS+set}"
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
echo "configure:907: checking whether ${CC-cc} accepts -g" >&5
if eval "test \"`echo '$''{'ac_cv_prog_cc_g'+set}'`\" = set"; then
else
  echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
  ac_cv_prog_cc_g=yes
else
  ac_cv_prog_cc_g=no
fi
rm -f conftest*
fi
echo "$ac_t""$ac_cv_prog_cc_g" 1>&6
if test "$ac_test_CFLAGS" = set; then
  CFLAGS="$ac_save_CFLAGS"
elif test $ac_cv_prog_cc_g = yes; then
  if test "$GCC" = yes; then
    CFLAGS="-g -O2"
  else
    CFLAGS="-g"
  fi
else
    CFLAGS="-O2"
  else
    CFLAGS=
  fi
fi
echo $ac_n "checking whether ${MAKE-make} sets \${MAKE}""... $ac_c" 1>&6
echo "configure:939: checking whether ${MAKE-make} sets \${MAKE}" >&5
set dummy ${MAKE-make}; ac_make=`echo "$2" | sed 'y%./+-%__p_%'`
if eval "test \"`echo '$''{'ac_cv_prog_make_${ac_make}_set'+set}'`\" = set"; then
else
  cat > conftestmake <<\EOF
all:
@echo 'ac_maketemp="${MAKE}"'
EOF
# GNU make sometimes prints "make[1]: Entering...", which would confuse us.
eval `${MAKE-make} -f conftestmake 2>/dev/null | grep temp=`
if test -n "$ac_maketemp"; then
  eval ac_cv_prog_make_${ac_make}_set=yes
else
  eval ac_cv_prog_make_${ac_make}_set=no
fi
rm -f conftestmake
fi
if eval "test \"`echo '$ac_cv_prog_make_'${ac_make}_set`\" = yes"; then
  echo "$ac_t""yes" 1>&6
  SET_MAKE=
else
  SET_MAKE="MAKE=${MAKE-make}"
fi
# Extract the first word of "strip", so it can be a program name with args.
set dummy strip; ac_word=$2
echo "configure:968: checking for $ac_word" >&5
if eval "test \"`echo '$''{'ac_cv_path_STRIP'+set}'`\" = set"; then
else
  case "$STRIP" in
  ac_cv_path_STRIP="$STRIP" # Let the user override the test with a path.
  ac_cv_path_STRIP="$STRIP" # Let the user override the test with a dos path.
  ac_dummy="$PATH"
      ac_cv_path_STRIP="$ac_dir/$ac_word"
      break
    fi
  done
  IFS="$ac_save_ifs"
  test -z "$ac_cv_path_STRIP" && ac_cv_path_STRIP="true"
esac
fi
STRIP="$ac_cv_path_STRIP"
if test -n "$STRIP"; then
  echo "$ac_t""$STRIP" 1>&6
else
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
echo "configure:1003: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
  CPP=
fi
if test -z "$CPP"; then
if eval "test \"`echo '$''{'ac_cv_prog_CPP'+set}'`\" = set"; then
else
    # This must be in double quotes, not single quotes, because CPP may get
  # substituted into the Makefile and "${CC-cc}" will confuse make.
  CPP="${CC-cc} -E"
  # On the NeXT, cc -E runs the code through the compiler's parser,
  # not just through cpp.
  cat > conftest.$ac_ext <<EOF
#line 1018 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
{ (eval echo configure:1024: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
else
  echo "$ac_err" >&5
  rm -rf conftest*
  CPP="${CC-cc} -E -traditional-cpp"
#line 1035 "configure"
#include <assert.h>
Syntax Error
EOF
{ (eval echo configure:1041: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
else
  echo "$ac_err" >&5
  rm -rf conftest*
  CPP="${CC-cc} -nologo -E"
#line 1052 "configure"
#include <assert.h>
Syntax Error
EOF
{ (eval echo configure:1058: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
else
  echo "$ac_err" >&5
  rm -rf conftest*
  CPP=/lib/cpp
fi
rm -f conftest*
fi
rm -f conftest*
fi
rm -f conftest*
  ac_cv_prog_CPP="$CPP"
fi
  CPP="$ac_cv_prog_CPP"
else
fi
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
echo "configure:1083: checking for ANSI C header files" >&5
if eval "test \"`echo '$''{'ac_cv_header_stdc'+set}'`\" = set"; then
else
#line 1088 "configure"
#include <stdlib.h>
#include <stdarg.h>
#include <string.h>
#include <float.h>
EOF
{ (eval echo configure:1096: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
  rm -rf conftest*
  ac_cv_header_stdc=yes
else
  echo "$ac_err" >&5
  rm -rf conftest*
  ac_cv_header_stdc=no
fi
rm -f conftest*
if test $ac_cv_header_stdc = yes; then
  # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
#line 1113 "configure"
#include <string.h>
EOF
if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
  egrep "memchr" >/dev/null 2>&1; then
else
  rm -rf conftest*
fi
rm -f conftest*
fi
  # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
#line 1131 "configure"
#include <stdlib.h>
EOF
  egrep "free" >/dev/null 2>&1; then
else
  rm -rf conftest*
fi
rm -f conftest*
fi
  # /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
if test "$cross_compiling" = yes; then
else
#line 1152 "configure"
#include <ctype.h>
#define ISLOWER© ('a' <= © && © <= 'z')
#define TOUPPER© (ISLOWER© ? 'A' + (© - 'a') : ©)
#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
int main () { int i; for (i = 0; i < 256; i++)
if (XOR (islower (i), ISLOWER (i)) || toupper (i) != TOUPPER (i)) exit(2);
exit (0); }
EOF
if { (eval echo configure:1163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
  rm -fr conftest*
fi
rm -fr conftest*
fi
fi
fi
echo "$ac_t""$ac_cv_header_stdc" 1>&6
  cat >> confdefs.h <<\EOF
#define STDC_HEADERS 1
EOF
fi
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
echo "configure:1187: checking whether time.h and sys/time.h may both be included" >&5
if eval "test \"`echo '$''{'ac_cv_header_time'+set}'`\" = set"; then
else
#line 1192 "configure"
#include <sys/types.h>
#include <sys/time.h>
#include <time.h>
int main() {
struct tm *tp;
; return 0; }
EOF
if { (eval echo configure:1201: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
  rm -rf conftest*
  ac_cv_header_time=yes
else
  rm -rf conftest*
  ac_cv_header_time=no
fi
rm -f conftest*
fi
echo "$ac_t""$ac_cv_header_time" 1>&6
if test $ac_cv_header_time = yes; then
#define TIME_WITH_SYS_TIME 1
EOF
fi
echo $ac_n "checking for sys/wait.h that is POSIX.1 compatible""... $ac_c" 1>&6
echo "configure:1222: checking for sys/wait.h that is POSIX.1 compatible" >&5
if eval "test \"`echo '$''{'ac_cv_header_sys_wait_h'+set}'`\" = set"; then
else
#line 1227 "configure"
#include <sys/wait.h>
#ifndef WEXITSTATUS
#define WEXITSTATUS(stat_val) ((unsigned)(stat_val) >> 8)
#endif
#ifndef WIFEXITED
#define WIFEXITED(stat_val) (((stat_val) & 255) == 0)
#endif
int main() {
int s;
wait (&s);
s = WIFEXITED (s) ? WEXITSTATUS (s) : 1;
; return 0; }
EOF
if { (eval echo configure:1243: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
  rm -rf conftest*
  ac_cv_header_sys_wait_h=yes
else
  rm -rf conftest*
  ac_cv_header_sys_wait_h=no
fi
rm -f conftest*
fi
echo "$ac_t""$ac_cv_header_sys_wait_h" 1>&6
if test $ac_cv_header_sys_wait_h = yes; then
#define HAVE_SYS_WAIT_H 1
EOF
fi
for ac_hdr in ctype.h dirent.h errno.h fcntl.h getopt.h grp.h limits.h math.h pwd.h signal.h strings.h string.h syslog.h unistd.h uio.h sys/types.h sys/time.h sys/resource.h sys/wait.h sys/stat.h sys/ipc.h sys/msg.h
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
echo "configure:1267: checking for $ac_hdr" >&5
if eval "test \"`echo '$''{'ac_cv_header_$ac_safe'+set}'`\" = set"; then
else
#line 1272 "configure"
#include <$ac_hdr>
EOF
{ (eval echo configure:1277: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
  rm -rf conftest*
  eval "ac_cv_header_$ac_safe=yes"
else
  echo "$ac_err" >&5
  rm -rf conftest*
  eval "ac_cv_header_$ac_safe=no"
fi
rm -f conftest*
fi
if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
  cat >> confdefs.h <<EOF
#define $ac_tr_hdr 1
EOF
else
fi
done
echo $ac_n "checking for working const""... $ac_c" 1>&6
echo "configure:1305: checking for working const" >&5
if eval "test \"`echo '$''{'ac_cv_c_const'+set}'`\" = set"; then
else
#line 1310 "configure"
int main() {
/* Ultrix mips cc rejects this.  */
typedef int charset[2]; const charset x;
/* SunOS 4.1.1 cc rejects this.  */
char const *const *ccp;
char **p;
/* NEC SVR4.0.2 mips cc rejects this.&nbsp
