Greier ikke å POST'e data med c++ sockets
#include <stdio.h>
#include "winsock2.h"
#include <iostream>
#include <fstream>
#include <windows.h>
using namespace std;
int main(int argc, char *argv[]) {
   // MessageBox(NULL, "hallo", "socketIndication", MB_OK);
   // Initialize Winsock.
   WSADATA wsaData;
   int iResult = WSAStartup( MAKEWORD(2,2), &wsaData );
   if ( iResult != NO_ERROR )
       printf("Error at WSAStartup()\n");
   // Create a socket.
   SOCKET m_socket;
   m_socket = socket( AF_INET, SOCK_STREAM, IPPROTO_TCP );
   if ( m_socket == INVALID_SOCKET ) {
       printf( "Error at socket(): %ld\n", WSAGetLastError() );
       WSACleanup();
       return 1;
   // Connect to a server.
   LPHOSTENT hostEntry;
   hostEntry = gethostbyname(argv[1]);
   sockaddr_in clientService;
   clientService.sin_family = AF_INET;
   clientService.sin_addr =  *((LPIN_ADDR)*hostEntry->h_addr_list); // inet_addr("127.0.0.1");
   clientService.sin_port = htons( 80 );
   if ( connect( m_socket, (SOCKADDR*) &clientService, sizeof(clientService) ) == SOCKET_ERROR) {
       printf( "Failed to connect.\n" );
       WSACleanup();
       return 1;
   // Send and receive data.
   if(argc!=3)
              cout<<"Usage:connect_web www.sau.no /index.html";
              return 1;
   char sendbuf[2000]="POST ";
   strcat(sendbuf, argv[2]);
   strcat(sendbuf, " HTTP/1.1\r\nHost: ");
   strcat(sendbuf, argv[1]);
   strcat(sendbuf, "\r\nUser-Agent: who_cares?\r\n");
   strcat(sendbuf, "Referer: google.com\r\n");
   strcat(sendbuf, "Connection: close\r\n");
   strcat(sendbuf, "Content-Type: application/x-www-form-urlencoded\r\n");
   strcat(sendbuf, "Content-Length: 16\r\n");
   strcat(sendbuf, "from=faen\r\n");
   strcat(sendbuf, "submit=\r\n\r\n");
   cout<< sendbuf << "\n";
   char recvbuf[100];
   int bytesRecv;
   send( m_socket, sendbuf, strlen(sendbuf), 0 );
   while(bytesRecv!=SOCKET_ERROR)
   bytesRecv=recv( m_socket, recvbuf, strlen(recvbuf), 0 );
   if(!bytesRecv)
   { break; }
   cout.write(recvbuf, strlen(recvbuf));
   WSACleanup();
   return 1;
Jeg greider å POST'e uten variabler, men når jeg la til
Så fikk jeg:
Request header field is missing ':' separator.<br />
<pre>
from=faen</pre>
Jeg har prøvd å lese litt i http rfc, men fant ingen konkrete eksempler.
Hva er feil skal ikke POST variabler komme til slutt?
http://www.jmarshall.com/easy/http/#othermethods  sjekk denne
i alle de andre headerene dine bruker du : for å skille nøkkler og verdier .. så hvorfor du plutselig går over til å bruke = skjønner jeg ikke helt
5532033[/snapback]
Det skal være = på POST variabler, men hva er feil?
Skal det være
strcat(sendbuf, "Content-Length: 17\r\n");
strcat(sendbuf, "from=faen\r\n\r\n");
Eller
strcat(sendbuf, "Content-Length: 17\r\n\r\n");
Eller skal strcat(sendbuf, "from=faen\r\n\r\n"); komme før alle andre headere?
Noen som vet?
"from" er en del av headerene - altså ikke en variabel (POST-data) ... ta å les det som står i artikkelen jeg linker til da!
edit:
err .. åja, jeg trodde du mente headeren "from" - for den brukes nemlig også..
da er det i såfall den andre versjonen av de du henviser til som er riktig
altså to newlines etter headerene..
uansett er dette veldig greit forklart i den lille teksen jeg linket til over - med eksempler og alt
Endret av dayslepr
