Radeon XPRESS 200M og Intel NIC problemer
Jeg har akkurat skaffet meg et mATX hovedkort med RADEON XPRESS 200M
MSI RS482M-IL
http://www.pcutstyr.no/main.php3?PI=info&P...59825X621624420
Har problemer med nettverket, både innebygd og et Intel PRO 1000-MT PCI bruker 70-90% CPU (kernel/driver time) når jeg overfører data.
Overføring går tregt, bare 11-13 MB/s
Sandra 2004 scorer 24MB/s
Kan det være fordi jeg har Enable SATA as IDE på i BIOS, eller er det bare svært dårlige chipset-drivere fra ATI?
Testet mot en MSI K8N Neo Platinum med nForce3 med Gigabit ethernet, og den bruker bare 10% CPU under testingen. Jeg trodde Intel NIC var så gode på CPU bruk.
The PRO/1000 drivers appear to be much more optimized and use far less CPU
Bruker seneste drivere fra ATI.com og Intel.com
Windows XP Pro
Windows XP Pro x64 edition (samme resultat)
AMD Sempron 2800+ 64bit
Intel PRO 1000-MT
SATA Samsung WriteMaster DVD-brenner
SATA Seagate 7200.8 NCQ
256MB RAM
  • 3 uker senere...
En oppdatering:
Ser ut til å være et problem med Radeon Xpress 200 brikkesettet:
http://episteme.arstechnica.com/groupee/fo.../m/883001067731
Yes. It's an old problem. I posted a while ago that I couldn't understand why the Ars System Guide recommended the Xpress 200 with this and other known problems. (USB)
http://episteme.arstechnica.com/groupee/fo.../m/813006824731
They did not plan to address the PCI bus throughput issues, a problem they said only affects GigE cards (mostly). I wouldn't put a RAID card on the PCI bus on that thing, though. (PCI-E seems OK.)
http://techreport.com/reviews/2004q4/radeo...0/index.x?pg=17
Here we have a bit of a problem. The USB controller in the Radeon Xpress 200 south bridge is about half the speed of the Intel and VIA solutions, and it uses twice as much CPU time. This may not be a showstopper, but I wouldn't recommend using this chipset extensively with an external hard drive or the like.
http://jooh.no/radeon_xpress_200.html
Har sendt tilbake kortet til PCutstyr.no og bedt om et Asus K8N-VM i steden.
