firewall.conf fra pcworld.no
Noen som har testet denne?
# **********IPtables initial configuration file************
# 192.168.1.213 is the address of the "outside" card (eth0)
# This must be replaced by the real address assigned by
# the ISP once the broadband connection is established.
# Our internal network is 192.168.2.x
#Flush all chains
iptables -F FORWARD
iptables -F INPUT
iptables -F OUTPUT
iptables -t nat -F POSTROUTING
# Set default policy of forward, input and output chain to DROP
# (reject everything)
iptables -P FORWARD DROP
iptables -P INPUT DROP
iptables -P OUTPUT DROP
#Allow ftp, mail, HTTP, pop and SSL/TLS
iptables -A FORWARD -p tcp -d 192.168.2.0/24 -m multiport
--sport 21,25,80,110,443 -m state --state ESTABLISHED -j ACCEPT
iptables -A FORWARD -p tcp -s 192.168.2.0/24 -m multiport
--dport 21,25,80,110,443 -m state --state NEW,ESTABLISHED -j ACCEPT
#DNS
iptables -A FORWARD -p udp -d 192.168.2.0/24 --sport 53 -j ACCEPT
iptables -A FORWARD -p udp -s 192.168.2.0/24 --dport 53 -j ACCEPT
#Allow active FTP
iptables -A FORWARD -p tcp -d 192.168.2.0/24 --sport 20 -m state
--state RELATED,ESTABLISHED -j ACCEPT
iptables -A FORWARD -p tcp -s 192.168.2.0/24 --dport 20 -m state
#Allow passive FTP
iptables -A FORWARD -p tcp -s 192.168.2.0/24 -m state
iptables -A FORWARD -p tcp -d 192.168.2.0/24 -m state
#Allow inside users to ping out but not vica versa
iptables -A FORWARD -p ICMP -d 192.168.2.0/24
--icmp-type echo-request -j DROP
iptables -A FORWARD -p ICMP -s 192.168.2.0/24
--icmp-type echo-reply -j DROP
#Allow all other ICMP packets
iptables -A FORWARD -p ICMP -j ACCEPT
#Set up NAT
iptables -t nat -A POSTROUTING -o eth0 -j SNAT --to 192.168.1.213
Quote:
Den 2002-09-15 14:38, skrev Dan Hansen:
Ingen?
det ser ut som om du må eksplisitt åpne porter, selv på trafikk initiert innenfra. dette kan fort bli pain in the ass, hvis du f.eks skal kjøre opp ntpdate , så må du åpne opp port 123. skal du lese news så må du åpne opp port 119 osv. sikkert greit om du skal kjøre litt nazistil på nettet, men ellers vil jeg hatt en mindre hissig brannvegg
