Edmund Blackadder Skrevet 22. februar 2006 Rapporter Del Skrevet 22. februar 2006 Hvordan er DKP systemet til folk her? Vi har noe som heter adjustment. Dvs at du kan ha max 100 dkp, og etter det så er det såkalte adjustment points.. Så det er ikke lov å spare opp til forskjellige ting som du har spesielt lyst på osv. Copy/paste'er fra siden: Ok as announced in the "Status January" post heres some new DKP rules. The change is made to make it simpler to do the DKP's. The rules we currently have with time spend is a hassle to keep track of with people coming and going throughout the raid. With the new system a player participating in all raids should be able to earn arround 50 dkp each week. Currently the number is arround 60-70 dkp depending on what we do. We will try to balance the system arround the maximum of 50 dkp a week so once we get further into BWL we will probably adjust the bosskill value in BWL again. ------------------------------------------------ All raids: On time 5 dkp Raid completion 2 dkp First bosskill 10 dkp MC: Ragnaros 3 dkp BWL: Bosskill 2 dkp Worldbosses: Everything 2 dkp ------------------------------------------------ The minimum bids for items are: Rare: 5 DKP Patterns/plans/schematics/recipes: 10 DKP Epic: 15 DKP Legendary: 25 DKP A player can have 100 DKP points as a maximum to ensure that new players are not at a disadvantage, and to prevent item camping. This means that the maximum amount a player can bid on an item is 100. DKP points above 100 are recorded as an adjustment. Adjustment only comes into play in case of a tie. In that case, the player with the highest adjustment can make a seniority call, since he is the veteran raider. The auction master will publicly annouce the names of the players who are in a tie, and then these players can decide if they make this seniority call. Making such a call will cost him all of his adjustment points though, in other words: you can't bid with adjustment points, it's all or nothing. Example: An item drops and 2 people bid the same, namely 100 points. Player 1 has a -25 adjustment Player 2 has a -12 adjustment Player 1 calls seniority and wins the item for 100 points. He loses his 25 points adjustment and now has 0 DKP and 0 adjustment left. The highest bidder gets the item for the second highest bid +1. If two players are bidding the same, the item goes to the player with the highest total current DKP value. If the players have the same bid and the same DKP, adjustment comes into play: the player with the highest adjustment can make a seniority call. This will cost him all of his adjustment (and the DKP he offered of course). If two players are bidding the same, have the same DKP and the same amount of adjustment, they roll for the item. The winner loses DKPs and adjustment. Example 1: an epic drops, the minimum bid is 15 DKP. Player 1 whispers: 21 DKP - the player has a total of 26 current DKP. Player 2 whispers: 24 DKP - the player has a total of 24 current DKP. Player 2 wins the item for 22 DKP. Example 2: the same situation as above but a third player also bids. Player 3 whispers: 24 DKP - the player has a total of 25 current DKP. Player 3 wins the item for 24 DKP since he has a higher total current DKP value. If no one bids on the item, the auction master should declare this to the raid. The minimum amount of DKP Then someone with less DKPs than the minimum bid can make a bid for the item. Lenke til kommentar
.Marcus Skrevet 22. februar 2006 Rapporter Del Skrevet 22. februar 2006 Vi har et bidding system, som gjør at ingen items har en minimumspris. Du blir da "belønnet" ved å vente til sist for droppet, da du kan få den for 1p. 1p for å joine et raid 1p for å være med hele raidet 1p per boss (MC/Ony) 1+1p per nye boss, første kill 2p for å ikke komme med i raidet (midlertidig, RG2 på vei) Ingen maks-DKP regler, hvis det kommer en tie, /random 100. Ganske lett, men på grunn av uregelmessigheter i set-drops, har noen klasser mye mer poeng enn andre klasser på non-class spesifikt loot, som våpen, ringer osv. Ikke noe system å anbefale egentlig Lenke til kommentar
slazk Skrevet 25. februar 2006 Rapporter Del Skrevet 25. februar 2006 I talenten Master of Deception, gjelder dette kun for mobs? Hvis ikke er ikke dette bedre enn camouflage i PvP? Ser de fleste bruker camouflag i PvP, men jeg synes at Master of Deception er et bedre valg eller? Lenke til kommentar
Pug Skrevet 25. februar 2006 Rapporter Del Skrevet 25. februar 2006 I talenten Master of Deception, gjelder dette kun for mobs? Hvis ikke er ikke dette bedre enn camouflage i PvP? Ser de fleste bruker camouflag i PvP, men jeg synes at Master of Deception er et bedre valg eller? 5665179[/snapback] MoD gjelder i PvP også ja. Personlig synes jeg MoD er bedre enn Camo Men jeg har ingen av delene atm, er speccet 20/31/00 T_T Lenke til kommentar
AvIOn Skrevet 26. februar 2006 Rapporter Del Skrevet 26. februar 2006 (endret) Hei alle sammen Nå har Guildet mitt for første gang kommet seg i MC, med stort hell. På 3 dager, (5 timer hver dag), så klarte vi å ta sulfuron. Neste uke så går vi for golemagg også. Luci - 4 Forsøk Magmadar - 2 forsøk (1 tranq-shot og 35 mennesker) Gehennas - 4 Forsøk (fire-rain er noe dritt av og til) Garr - 1 forsøk Geddon - 5 Forsøk ( SPRING når du er bomba dammit ) Shazzra - 2 forsøk Sulfuron - 3 Forsøk Ok, det var litt "briefe briefe", men det jeg egentlig er ute etter er følgende: Jeg er Rogue, og leter etter den ultimate MC/BWL builden. Jeg vil gjøre så mye skade som mulig her inne, slik at jeg kan være det en rogue SKAL være, en dps'er. Har en "greie" for Sverd, så vil ha en build som er tilpasset dette. Men sliter litt med hva jeg skal velge.... Foreløpig har jeg 20/31/0. Med improved slice and dice, cold blood, 5 poeng i sword spec (nødvendig?)... Agression og.. husker ikke. Men er det noen som har ett godt tips til hvordan jeg skal bygge denne roguen? Endret 26. februar 2006 av AvIOn Lenke til kommentar
Pug Skrevet 26. februar 2006 Rapporter Del Skrevet 26. februar 2006 Hei alle sammen Nå har Guildet mitt for første gang kommet seg i MC, med stort hell. På 3 dager, (5 timer hver dag), så klarte vi å ta sulfuron. Neste uke så går vi for golemagg også. Luci - 4 Forsøk Magmadar - 2 forsøk (1 tranq-shot og 35 mennesker) Gehennas - 4 Forsøk (fire-rain er noe dritt av og til) Garr - 1 forsøk Geddon - 5 Forsøk ( SPRING når du er bomba dammit ) Shazzra - 2 forsøk Sulfuron - 3 Forsøk Ok, det var litt "briefe briefe", men det jeg egentlig er ute etter er følgende: Jeg er Rogue, og leter etter den ultimate MC/BWL builden. Jeg vil gjøre så mye skade som mulig her inne, slik at jeg kan være det en rogue SKAL være, en dps'er. Har en "greie" for Sverd, så vil ha en build som er tilpasset dette. Men sliter litt med hva jeg skal velge.... Foreløpig har jeg 20/31/0. Med improved slice and dice, cold blood, 5 poeng i sword spec (nødvendig?)... Agression og.. husker ikke. Men er det noen som har ett godt tips til hvordan jeg skal bygge denne roguen? 5666913[/snapback] Om du har en 20/31/00 build så kan du vel ikke ha cold blood? Om du vil ha swords er vel 20/31 builden den beste, med points i imp. SnD, Riposte, Blade Flurry, Sword Spec, aggresion og Adrenaline Rush. Lenke til kommentar
Dr.Greve Skrevet 26. februar 2006 Rapporter Del Skrevet 26. februar 2006 Hei alle sammen Nå har Guildet mitt for første gang kommet seg i MC, med stort hell. På 3 dager, (5 timer hver dag), så klarte vi å ta sulfuron. Neste uke så går vi for golemagg også. Luci - 4 Forsøk Magmadar - 2 forsøk (1 tranq-shot og 35 mennesker) Gehennas - 4 Forsøk (fire-rain er noe dritt av og til) Garr - 1 forsøk Geddon - 5 Forsøk ( SPRING når du er bomba dammit ) Shazzra - 2 forsøk Sulfuron - 3 Forsøk Ok, det var litt "briefe briefe", men det jeg egentlig er ute etter er følgende: Jeg er Rogue, og leter etter den ultimate MC/BWL builden. Jeg vil gjøre så mye skade som mulig her inne, slik at jeg kan være det en rogue SKAL være, en dps'er. Har en "greie" for Sverd, så vil ha en build som er tilpasset dette. Men sliter litt med hva jeg skal velge.... Foreløpig har jeg 20/31/0. Med improved slice and dice, cold blood, 5 poeng i sword spec (nødvendig?)... Agression og.. husker ikke. Men er det noen som har ett godt tips til hvordan jeg skal bygge denne roguen? 5666913[/snapback] http://www.worldofwarcraft.com/info/classe...000000000000000 Lenke til kommentar
slazk Skrevet 2. mars 2006 Rapporter Del Skrevet 2. mars 2006 I talenten Master of Deception, gjelder dette kun for mobs? Hvis ikke er ikke dette bedre enn camouflage i PvP? Ser de fleste bruker camouflag i PvP, men jeg synes at Master of Deception er et bedre valg eller? 5665179[/snapback] Skulle hatt et bra svar her Lenke til kommentar
Pug Skrevet 2. mars 2006 Rapporter Del Skrevet 2. mars 2006 (endret) I talenten Master of Deception, gjelder dette kun for mobs? Hvis ikke er ikke dette bedre enn camouflage i PvP? Ser de fleste bruker camouflag i PvP, men jeg synes at Master of Deception er et bedre valg eller? 5665179[/snapback] Skulle hatt et bra svar her 5689535[/snapback] JA, MoD gjelder også i PvP. Jeg merker helt klar forskjell når jeg duellerer rogues med MoD i forhold til de uten MoD. Edit: 5 points i MoD vil si at du får stealth-nivået til en lvl 65 i forhold til lvl 60 om du ikke hadde hatt MoD. Night Elves har også shadowmeld, som gjør at nelf rogues har ett poeng i MoD som racial. Endret 2. mars 2006 av Pug Lenke til kommentar
M@R7!N Skrevet 2. mars 2006 Rapporter Del Skrevet 2. mars 2006 Trodde hvert poeng i MoD var 0.5 Stealthlevel jeg Lenke til kommentar
ugotabanana Skrevet 2. mars 2006 Rapporter Del Skrevet 2. mars 2006 (endret) Dr.Greve said: AvIOn said: Hei alle sammen Nå har Guildet mitt for første gang kommet seg i MC, med stort hell. På 3 dager, (5 timer hver dag), så klarte vi å ta sulfuron. Neste uke så går vi for golemagg også. Luci - 4 Forsøk Magmadar - 2 forsøk (1 tranq-shot og 35 mennesker) Gehennas - 4 Forsøk (fire-rain er noe dritt av og til) Garr - 1 forsøk Geddon - 5 Forsøk ( SPRING når du er bomba dammit ) Shazzra - 2 forsøk Sulfuron - 3 Forsøk Ok, det var litt "briefe briefe", men det jeg egentlig er ute etter er følgende: Jeg er Rogue, og leter etter den ultimate MC/BWL builden. Jeg vil gjøre så mye skade som mulig her inne, slik at jeg kan være det en rogue SKAL være, en dps'er. Har en "greie" for Sverd, så vil ha en build som er tilpasset dette. Men sliter litt med hva jeg skal velge.... Foreløpig har jeg 20/31/0. Med improved slice and dice, cold blood, 5 poeng i sword spec (nødvendig?)... Agression og.. husker ikke. Men er det noen som har ett godt tips til hvordan jeg skal bygge denne roguen? 5666913[/snapback] http://www.worldofwarcraft.com/info/classe...000000000000000 5670182[/snapback] 16-25-10 som gjelder! Endret 19. april 2020 av ugotabanana Lenke til kommentar
henrik_s Skrevet 2. mars 2006 Rapporter Del Skrevet 2. mars 2006 Alle vet da at en hemo-build er tingen! Lenke til kommentar
Canute Skrevet 2. mars 2006 Rapporter Del Skrevet 2. mars 2006 Trodde hvert poeng i MoD var 0.5 Stealthlevel jeg 5689958[/snapback] Trodde 5/5 i MoD ble det samme som 3 stealthlevler altså hver er 0.6 stealthlevel. Kan godt være jeg tar helt feil. Lenke til kommentar
Edmund Blackadder Skrevet 2. mars 2006 Rapporter Del Skrevet 2. mars 2006 Spiller egentlig ingen rolle for meg. I mitt syn, så er MoD et must uansett med mindre du bare raider... Lenke til kommentar
ugotabanana Skrevet 3. mars 2006 Rapporter Del Skrevet 3. mars 2006 Trevakt du spiller ikke rogue, så kanskje ikke du skal uttale deg? (Han har en 49 warrior).. Fist weapons er egentlig ikke noe særlig i forhold til daggers eller swords. 5525022[/snapback] Finnes fist weps. som faktisk duger ta f.eks Claw of the Black Drake. Lenke til kommentar
Sheel Skrevet 3. mars 2006 Rapporter Del Skrevet 3. mars 2006 Trevakt du spiller ikke rogue, så kanskje ikke du skal uttale deg? (Han har en 49 warrior).. Fist weapons er egentlig ikke noe særlig i forhold til daggers eller swords. 5525022[/snapback] Finnes fist weps. som faktisk duger ta f.eks Claw of the Black Drake. 5692589[/snapback] Det er da også eneste Fist weapon utenom Grand Marshal som duger i spillet for en oppegående Combat Rogue og da . Angående MoD/Camo spørsmålet så er MoD klart best i mine øyne, spiller i tillegg Night Elf så det skal mye til før folk ser at jeg er opptil dem og skal hugge til ^_^. Lenke til kommentar
Pug Skrevet 3. mars 2006 Rapporter Del Skrevet 3. mars 2006 Spiller egentlig ingen rolle for meg. I mitt syn, så er MoD et must uansett med mindre du bare raider... 5691306[/snapback] Jepp, sant det =/ Savner MoD i PvP, men når man først er i en end-game PvE-guild må man nesten specce slik også. Er rimelig lei av 20/31 tho, så tenker på å teste enten hemhorrage eller seal fate ^_^ Lenke til kommentar
Edmund Blackadder Skrevet 3. mars 2006 Rapporter Del Skrevet 3. mars 2006 Jeg har alltid hatt lyst til å teste seal fate men har aldri kommet så langt... Lenke til kommentar
ugotabanana Skrevet 3. mars 2006 Rapporter Del Skrevet 3. mars 2006 Spiller egentlig ingen rolle for meg. I mitt syn, så er MoD et must uansett med mindre du bare raider... 5691306[/snapback] Jepp, sant det =/ Savner MoD i PvP, men når man først er i en end-game PvE-guild må man nesten specce slik også. Er rimelig lei av 20/31 tho, så tenker på å teste enten hemhorrage eller seal fate ^_^ 5693666[/snapback] 30/8/13 daggers ftw, funker prima i både PvE og PvP. Lenke til kommentar
Edmund Blackadder Skrevet 3. mars 2006 Rapporter Del Skrevet 3. mars 2006 I raids så er det nesten et must med Adrenaline rush... Guilden min krever iallefall det. Lenke til kommentar
