Intel snuser på DDR3
Takk for linkene Capo Crimini.
Jeg bet meg merke i dette:
05/31/2005
Desi Rhoden, chairman of the JC-42 Memory Committee at JEDEC, said in an interview with a Taiwanese web-site that DDR2 memory will continue performance scaling even beyond 800MHz, towards over 1GHz, whereas next-generation DDR3 SDRAM standard will support clock-rates of over 1.5GHz.
DDR2 to Reach 1066MHz "Officially"
“DDR2-800 is on its way and will become widespread, especially with the shift in DRAM technology to 90nm. The timeframe is mostly driven by fab timing and the availability of controllers and systems to support DDR2-800, which will possibly arrive at around the end of 2005 or beginning of 2006. The next speed grade will likely be 1066MHz and because of internal limitations that performance range will probably be limited to the overclocking and gaming markets,” Desi Rhoden said in an interview with DigiTimes web-site.
Standarisert DDR2-800 er altså like rundt hjørnet nå. Da håper jeg AMD får støtte for det via AM2-sokkelen.
DDR2-1066 vil nok bli vanlig overklokkingsminne, men neppe JEDEC-godkjent. DDR3 skal vist starte på DDR3-800 (JEDEC-godkjent) i 2007, men trolig etter hvert komme i utgaver med DDR3-1066 og DDR3-1333 (også JEDEC-godkjent). Overklokkingsminne kommer kanskje opp i DDR3-1600.
